Do first GEN tundras any”secret” features?
Discussion in '1st Gen Tundras (2000-2006)' started by Redoak, Aug 16, 2025.
  1. Aug 16, 2025 at 6:52 PM
    Redoak
    Redoak [OP] New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    One Example of what I mean is little known feature of GMC, Chevys starting about the year 1998: push the light button fast 3 times, and it disables all lights until pushed 3 times again.
    Do first Ginn tundras have any little known features?
    PNW15 likes this.
  2. Aug 16, 2025 at 7:05 PM
    2mchfun
    Secrets aren't secret if discussed openly on the web.:rofl::rofl::rofl:
  3. Aug 16, 2025 at 7:10 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    If you don't change your lower ball joints with OEM units, your truck turns into Lightnin' McQueen.
    Dustdog, ATV25, HulkSmurf14 and 22 others like this.
  4. Aug 16, 2025 at 7:11 PM
    And when it happens ... you get to sing along.
  5. Aug 16, 2025 at 7:14 PM
    Riverdale21
    OTP ATL
    If you press the gas, brake, and e-stop pedals at the same time your truck takes a screen shot.
  6. Aug 16, 2025 at 7:15 PM
    Riverdale21
    OTP ATL
    If you run out of gas turn your gas cap clockwise three clicks. That should give you another three miles of fuel to get to the gas station.
  7. Aug 16, 2025 at 7:16 PM
    Riverdale21
    OTP ATL
    Your truck has a secret smoke machine function. Simply fill your muffler with transmission fluid.
  8. Aug 16, 2025 at 7:18 PM
    Riverdale21
    OTP ATL
    Another secret feature, if you hold down all the window buttons for 10 seconds, it gets windy.
  9. Aug 16, 2025 at 7:28 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Wouldn't call it a secret, but as long as you're going over 25mph and already have the cruise control set previously, it will accelerate up to speed for you when you turn it back on.
  10. Aug 16, 2025 at 8:03 PM
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    Not a secret, but the ball cooler is a pretty cool feature
    M14 EBR, Weagle, bmf4069 and 18 others like this.
  11. Aug 16, 2025 at 8:38 PM
    With proper(ish) maintenance they run forever.
  12. Aug 17, 2025 at 6:23 AM
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd tow package
    60/40 fold out makes a good dedicated dog perch for riding shotgun.
    M14 EBR, BroHon, bmf4069 and 8 others like this.
  13. Aug 17, 2025 at 6:38 AM
    ChattanoogaPhil
    Also, there's a super secret place in the rear fold out to stash a few bucks and forget about for 20 years.
  14. Aug 19, 2025 at 4:06 AM
    Aerindel
    Aerindel New Member
    Montana
    The ABS system really sucks and will try to kill you on snow or gravel. It's easily disabled by pulling the relays.
    You can disable the daytime running lights by unplugging a grey connector between the battery and the fender.
    The valve cover bolts often become extremely loose, literally finger tight, and you can fix a leak just by tightening them even hand tight with a ratchet.
  15. Aug 19, 2025 at 6:11 AM
    FTFY.
  16. Aug 19, 2025 at 8:53 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    The front cupholders with the center console will fit a full sized nalgene bottle.
  17. Aug 19, 2025 at 11:07 AM
    ChattanoogaPhil
    Gen1 bro!
    Dustdog and MrFeldman like this.
  18. Aug 19, 2025 at 1:20 PM
    a_tundra
    a_tundra New Member
    Now I'm sold on buying one of these. Back when the Gen 1 was out I don't remember anyone having big water bottles, but now everyone has them and none of the modern cars fit them in their cupholders.
    Bought2Pull likes this.
  19. Aug 19, 2025 at 3:19 PM
    des2mtn
    Shady Grove
    Tonto cover
    Think it depends on trim/ front seat configuration. My cupholders fit a Nalgene or a 40oz Hydroflask just fine.
  20. Aug 19, 2025 at 3:28 PM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    The fold down center arm rest with the 60/40 bench seat easily holds my giant yeti coffee mug and a normal sized water bottle.
  21. Aug 19, 2025 at 8:11 PM
    BadBryan
    BadBryan New Member
    05 Tundra SR5 2WD DC V8 Silver Sky Metallic
    My 1st-Gen Tundra came with a hidden factory option I didn’t even know about — the ‘California Comfort Package.’ Turns out the air intake and A/C/cowl double as a luxury condo for homeless rodents. Guess Toyota was way ahead of the whole ‘tiny homes’ movement…
  22. Aug 19, 2025 at 8:29 PM
    Turning the passenger airbag off with your spare key in front of your obnoxious passenger WILL prompt them to not ride with you again.
    Ask me how I know. ;)
    M14 EBR, BroHon, Kalannar97 and 6 others like this.
  23. Aug 19, 2025 at 8:31 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    HOLY CRAP! I guess one of the previous 6 owners did that. I just thought "nice, no daytime running lights, hate those things."
    Today I learned if I get out of the truck and lock it with the auto lock button, my wife cannot use the same button to let me back in. I guess that's there to prevent a coat hanger and slightly down window being used to break into the truck. (Both good and bad).
  24. Aug 20, 2025 at 3:16 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    credit @assdog:
    With the cargo light on, quickly switch it off and back on again to get the cargo light to stay on for about 15 minutes.
    BroHon, Redoak[OP], bmf4069 and 2 others like this.
  25. Aug 20, 2025 at 3:22 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    At least with my 00 model, if the headlights are in the "on" position while the engine is running, they will turn off when the ignition is switched "off" and will turn back on the next time the ignition is switched "on" so in the winter time when I go to work in the dark and leave in the dark I do not have to switch them on and off using the stalk. They automatically come on with the ignition when left in the "on" position.
    FrenchToasty and whodatschrome like this.
  26. Aug 20, 2025 at 3:36 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    If you have the big center console in your access cab, you also have a secret compartment for smuggling contraband. :laugh:20250820_054328.jpg
    Or random parts.
    BroHon and AWilliams like this.
  27. Aug 20, 2025 at 4:26 AM
    bmf4069 Captain wtf
    What are wow jeans?
  28. Aug 20, 2025 at 4:27 AM
    bmf4069 Captain wtf
    I wondered why you had a block of wood in your cubby. Then I realized it was a book. :facepalm:
  29. Aug 20, 2025 at 4:29 AM
    bmf4069 Captain wtf
    Mine will just leave you stranded if you do that. AMHIK.
    Kalannar97 likes this.
  30. Aug 20, 2025 at 4:52 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    If you unlock the door with the key, turn to unlock twice to unlock all doors
    AnnDee4444, Dook55, BroHon and 7 others like this.
