Very slow throttle response...
Discussion in '3rd Gen Tundras (2022+)' started by CringyDad, Nov 21, 2024.
  1. Nov 21, 2024 at 10:05 AM
    CringyDad
    CringyDad [OP] New Member
    Scott
    Fresno, CA
    2024 Tundra 1794 TRD (blueprint/saddle tan)
    Nothing.
    Maybe this was discussed before but this morning I was changing lanes on the freeway and no sooner did I signal and start changing lanes than and kid in a POS Civic came screaming up behind me. I stepped on the gas to create some space (I was already going 70) and the truck had almost no response other than a mild acceleration - no downshift, no surge of power...just kinda said, "Nope, not today!". I have definitely experienced the pedal lag from a stop multiple times but never this failure to respond at speed. Is this 3rd gen computer nonsense or something else?
  2. Nov 21, 2024 at 11:32 AM
    Jymbeux
    Jymbeux New Member
    James
    Washington
    2022 MGM Tundra DC limited TRD OR
    It's pretty sporadic. Sometimes it's nice and responsive, other times it leaves you wondering if you hit the right pedal. It's not like regular turbo lag either. I've heard pedal commanders can help - I believe there are a few threads about them.
    CringyDad[OP] likes this.
  3. Nov 22, 2024 at 3:34 AM
    Dtedog
    Dtedog New Member
    MICHELLE
    2022 Toyota Tundra SR5 TRD Sport
    I have the 2022 and it does this. If you have not yet had your first oil change, have the used oil checked for metal. Just saying... it has happened before.
  4. Nov 22, 2024 at 5:23 AM
    JayDee
    JayDee New Member
    I think it has to do with how much you press down the gas pedal. A slight press will get you instant power, but an aggressive press and you'll have to wait for the transmission to downshift.
  5. Nov 23, 2024 at 5:44 AM
    Dtedog
    Dtedog New Member
    MICHELLE
    JayDee this is not what he is describing. If you have loss off momentum like CringyDad or myself you know it has nothing to do with how you "push on the pedal".
  6. Nov 23, 2024 at 7:07 AM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Tow/Haul or Sport
    mve and j-utah like this.
  7. Nov 26, 2024 at 8:04 AM
    Dtedog
    Dtedog New Member
    MICHELLE
    Mode has no effect
  8. Nov 27, 2024 at 10:36 AM
    CringyDad
    Scott
    Fresno, CA
    Nothing.
    I appreciate the responses to this, added some clarity to the comments, above:
    I'm at 5,500 miles and have changed the oil 3x already. Nothing out of the ordinary in the old oil or filters. And this isn't an issue where the motor is getting fuel but can't spin, it's like the computer is seeing the change of input from the pedal and simply not altering the throttle position.
    I did depress the pedal firmly, not to the floor at first but eventually went all the way and the truck only mildly accelerated, gradually, not immediately. And while this all happened inside of 2-3 seconds, the transmission never downshifted.
    I am not sure if the mode makes a different (I drive in Normal 100% of the time), but I certainly hope the programming isn't expecting drivers to change modes before needing to quickly accelerate. And I really don't want to have to buy a Pedal Commander or other accessory to "fix" this.
  9. Nov 28, 2024 at 1:45 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
  10. Nov 28, 2024 at 5:07 AM
    Alden
    Alden New Member
    I have experienced the same delayed pedal response on my non-hybrid. It is definitely not turbo lag. Some owners have described it as being SECONDS long and almost causing accidents.
    The occasional delay I experience is usually just a split second delay and then when the drivetrain finally responds, it can sometimes be more aggressive/jerky and not as smooth as a normal initial acceleration.
    It happens to me mostly at stop signs, when I come up to a four way stop. I stop and pause for a second, and then when I try to accelerate from the quick stop, that's when I will sporadically experience the pedal lag.
    My truck is not a hybrid, but I feel like the occasional hesitation is programmed by Toyota for hybrid models. It's as if my drivetrain hesitates, expecting output from the hybrid motor, and when that output isn't there, then I finally get feedback from my motor and acceleration occurs.
    I could be way off base with this, but I swear it feels like a programming/software issue. I think my truck is confused that there isn't output from an electric motor.
    I have not had the TSB performed.
  11. Nov 28, 2024 at 5:34 AM
    JayDee
    JayDee New Member
    I can't say that I've ever experienced that with my 2024 (non-hybrid). It definitely starts off easier than my old 2005 V8 Tundra as that truck would give you neck jerking acceleration right from the start.
    I wonder if your trucks ECU detected pre-detonation and reacted by limiting acceleration? You can read out the number of pre-detonation's detected on each cylinder with an OBDII tool. Last time I checked my truck had a few on a couple cylinders but 0 on most.
    I've been running mid-grade fuel (89 octane) for the last several fill-ups and since then (and the transmission software update) it seems the engine has more power and minimal lag.
    CringyDad[QUOTED][OP] likes this.
  12. Dec 10, 2024 at 5:11 PM
    CringyDad
    Scott
    Fresno, CA
    Nothing.
  13. Dec 10, 2024 at 5:12 PM
    CringyDad
    Scott
    Fresno, CA
    Nothing.
    Terrific suggestion, thanks, I'll look into this.
  14. Dec 10, 2024 at 5:16 PM
    Hella Krusty
    Hella Krusty New Member
    I have a 2022 and it doesn't do this. My oil has been changed lots, everything Okee Dokkee. Just saying it isn't every vehicle
  15. Aug 16, 2025 at 5:56 PM
    Talkin_Tundras
    Talkin_Tundras New Member
    ‘22 Tundra Limited
    Mine seems to be much worse after I got my new engine. It damn near caused an accident a couple weeks ago. I was trying to pull out quickly - nothing too crazy, I had enough room between me and the approaching vehicle - but it bogged down so much that it legit scared me for a sec. I don’t really recall it doing this with my old engine. Seems like it’s some weird programming issue. Might contact the service advisor and see what they say.
