Scangauge 3 Sleep Mode
Discussion in '2.5 Gen Tundras (2014-2021)' started by TRDSport888, Jul 3, 2025.
  1. Jul 3, 2025 at 8:33 PM
    TRDSport888
    TRDSport888 [OP] New Member
    Ivan
    Tint
    Just got a new Scangauge 3 and noticed the scangauge does not turn off when I shut off the ignition. It just goes into sleep mode.
    I noticed that the screen stays on for quite a while and when I was cleaning my truck and it was still plugged in the screen turned on while the truck was off an hour after I shutoff the truck.
    Anyone experience any major battery drain when you leave it plugged in?
    Is there a way to make it turn off when the truck is turned off.
    Any information would be great. Thanks!
  2. Jul 3, 2025 at 9:27 PM
    Unfortunate Confusion
    Unfortunate Confusion Founder of the cult of Confusionism
    2020 White SR5 DC 4x4 6-seater, 2018 Gray SR5 CM 4x4 6-seater
    Per page 7 of the user manual (https://www.scangauge.com/wp-content/uploads/2022/10/SG3_User_Manual_1.2.pdf), it should go into sleep mode 12 seconds after the vehicle is powered down. It then says that starting the engine, or tapping the scangauge twice will cause it to turn back on. Did you happen to touch it while your truck was off?
    Additionally, on page 18 of the manual it mentions that there is a risk of drain if the sleep event settings have been altered for a hybrid vehicle. I'm assuming you do not have a hybrid given the forum you're posting this in, but it would be worth checking to see if that is your issue.
    TRDSport888[OP] likes this.
  3. Aug 15, 2025 at 6:12 PM
    BonesATX
    BonesATX Never enough money
    Adolfo
    Austin
    2017 Tundra SR5
    TRD intake, Icon lift 35’s, stainless works long tube headers, CMC,Tuned
    I've had it on my truck for more than a year haven't had any battery issues always leave it plugged in, it should stay on for a bit then turn off
  4. Aug 15, 2025 at 6:32 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    No battery drainage here. Works as it should.
    It goes into sleep mode few seconds after I shut off the truck n boots right up when I start up. Also as stated, double tapping will turn the screen on.
  5. Aug 16, 2025 at 6:49 AM
    No issues with mine either.
