General Supercharger Thread
  1. Aug 14, 2025 at 10:14 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    what were you waiting for from Whipple?
    nags[QUOTED] likes this.
  2. Aug 14, 2025 at 1:42 PM
    nags
    nags New Member
    The heat exchange came damaged and apparently was missing a bunch of other parts including the injectors.
  3. Aug 14, 2025 at 1:45 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    BOO, BOOOOOOO
    BOOOOOOOOOOOOOOOOOOOOOOOOOOOO
    Did they apologize? Offer anything? Hearty handshake? pat on the back? anything???
    nags[QUOTED] and Tripleconpanna like this.
  4. Aug 14, 2025 at 2:06 PM
    Danimal86
    Daniel
    Sacramento, CA
    second one that said there are missing parts.
    gonna have to really go through all my parts before install
  5. Aug 14, 2025 at 2:10 PM
    nags
    nags New Member
    I know Andrew at XAT had to email them and stay on top of them to get replacements shipped out ASAP.
  6. Aug 14, 2025 at 7:28 PM
    ARES35
    ARES35 New member for life
    Mile high
    Truck been in the shop for 7 weeks to get roof replaced from hail. Really missing it at this point. Have a 1500 sst rental but its to damn quiet although it's got some go. Tundra is rowdy in comparison.
  7. Aug 15, 2025 at 6:55 AM
    e30cabrio
    A bit over 400 miles in consultation with @snivilous I decided to live dangerously & went wot, it feels good, shame it's 110+ which kills boost (6.5 highest I saw) Trans oddness gets better & then there is a weird upshift delay, hopefully it's almost all learned, temps are good & it has sub 2k Amsoil fluid.
  8. Aug 15, 2025 at 8:02 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I'm willing to bet a paycheck that ANY vehicle that Sniv personally tunes will see WOT prior it leaving his possession!!! :burnrubber:
  9. Aug 15, 2025 at 8:06 AM
    e30cabrio
    I was thinking, seeing as the issue with the Viktor reservoir was causing a vacuum, can I plumb it sealed in & use the Magnuson reservoir as the fill/release as it's cap vents? If so would I just T in the big reservoir into the existing hoses?
    In retrospect, I could have saved a bunch had I shipped it to him in December :(
  10. Aug 15, 2025 at 8:20 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I don't remember if the Tundras have the same issue, but the Tacoma's with the 750e/f transmission are notorious for having a 4th to 5th gear lag. OTT was able to mostly tune that out
  11. Aug 15, 2025 at 8:57 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    You could probably just epoxy over that hole, sand it before, sand it after and give it a lick of paint. You can use both reservoirs in the loop, just make sure the Maggy res is the highest point for filling.
  12. Aug 15, 2025 at 9:12 AM
    e30cabrio
    I filled it in when it seeped, which caused the vacuum. I'm concerned about causing flow issues. What would be the best way to route the hoses?
    HulkSmurf14 likes this.
  13. Aug 15, 2025 at 9:39 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Would be
    Similar to what I posted earlier and there room by the radiator like the first 1900 location? I have that bracket if needed. It'll be above the pump and should be even with the return off the tank. The big tank might be a bit higher?
  14. Aug 15, 2025 at 10:04 AM
    e30cabrio
    So, cut the hose currently going to the top of the SC, connect it to the top of the big tank, run the part going to the pump to the bottom of the big tank, and make sure the original Maggy reservoir is the highest point in the system.
  15. Aug 15, 2025 at 10:37 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I would route from heat exchanger top to SC intercooler driver's side, from SC intercooler passenger side to bottom port on big res, top port of big res to rear port of Maggy res, front port of Maggy res back to pump. Yes, make sure Maggy res is highest point.
  16. Aug 15, 2025 at 10:53 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    You might also want to tilt the port-side of the big res up while filling, then lower and secure it after filling.
    e30cabrio and Mdl like this.
  17. Aug 15, 2025 at 11:14 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    400 mile break in ✅
  18. Aug 15, 2025 at 11:45 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
  19. Aug 15, 2025 at 11:58 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    That's more like it!!
  20. Aug 15, 2025 at 1:12 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    Break in ???
    My tuner said STAND ON IT!!!
  21. Aug 15, 2025 at 1:18 PM
    e30cabrio
    This is a rebuilt motor, not SC install. If I broke it in 1/2 an hour after being told to break it in, I'd have no warranty. I need a warranty this time, sniv just gave me a clean bill of health on my tune so it's game on!.
  22. Aug 15, 2025 at 1:19 PM
    HulkSmurf14
    2014 Tundra Limited
    Lol, your tuner has good swag, too!
  23. Aug 16, 2025 at 7:54 AM
    nags
    nags New Member
    Aaaand she's in. Going into limp mode after getting on it hard at around 70 though.
    Still needs the headers installed.
  24. Aug 16, 2025 at 7:57 AM
    snivilous
    SW UT
    If you/shop are having issues you can send me a log to look at
  25. Aug 16, 2025 at 8:02 AM
    nags
    nags New Member
    Will grab you some later today
  26. Aug 16, 2025 at 8:03 AM
    e30cabrio
    First oil change done, installed the new drain.
  27. Aug 16, 2025 at 8:16 AM
    e30cabrio
    Anyone want a Fumoto or metal filter housing?
    Who knew Van Halen made parts??
  28. Aug 16, 2025 at 11:30 AM
    snivilous
    SW UT
    I'll take the filter housing. Been meaning to swap out the wife's GX one.
  29. Aug 16, 2025 at 11:38 AM
    nags
    nags New Member
    I didn't realize, but they forgot to install the bung and wideband. Any sense in doing logging without it?
  30. Aug 16, 2025 at 11:56 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yea you can still log and send the file
