Using OEM dash cam connector for after-market dash cam
Discussion in '3rd Gen Tundras (2022+)' started by JustDrivinAround, May 12, 2025.
  1. May 12, 2025 at 6:35 PM
    JustDrivinAround
    JustDrivinAround [OP] New Member
    24 CrewMax
    I'd like to wire up my after-market dash cam to plug into the same connector that Toyota uses for their dash cam. I think this is the 5-pin connector in the roof cavity/ dome light.
    I have a Viofo dash cam and their hard-wire kit allows for switching between parking mode and driving mode if correctly wired to both a constant and an ignition controlled power source.
    I can't imagine that the connector or a pig tail would be more than a couple of bucks, but I haven't been able to find the type of connector that I need.
    Does anyone know where to find these or a part number to search for?
    Thanks.
    This is for a 2024 Limited.
  2. May 12, 2025 at 6:59 PM
    Wade23454
    Wade23454 New Member
    Wade
    2025 TRD Pro
    None
  3. May 20, 2025 at 8:06 PM
    JustDrivinAround
    24 CrewMax
    Thanks for the tip. I might have to try that.
    What I would really like is just this connector or pigtail:
    The Viofo hardwire kit can switch to parking mode, but I am not sure that the Dongar one will do that.
    If anyone has a lead on just the connector, please let me know.
  4. May 20, 2025 at 8:19 PM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
  5. Aug 14, 2025 at 2:56 PM
    waldeck1
    waldeck1 New Member
    2016 Tundra
  6. Aug 14, 2025 at 3:05 PM
    60centenergy
    60centenergy Mods Member
    Zack
    GVL
    ‘24 Lunar Rock SR5 TRD Sport
  7. Aug 14, 2025 at 3:56 PM
    NimbusDog
    NimbusDog New Member
    Tampa, FL
    2022 Tundra
    These work too, and not expensive... And plug into the dash cam connector up inside the headliner under the overhead console.
  8. Aug 14, 2025 at 3:58 PM
    60centenergy
    Zack
    GVL
    Are those the ones from Aliexpress?
  9. Aug 14, 2025 at 4:12 PM
    NimbusDog
    Tampa, FL
    2022 Tundra
    Yep. They plug right in. Installed my Blackvue using this. I have 2 left.
    60centenergy likes this.
