Dobinsons MRR lift settings
Discussion in 'Suspension' started by ToyoWorld786, Dec 9, 2023.
  1. Dec 9, 2023 at 10:42 PM
    ToyoWorld786
    ToyoWorld786 [OP] New Member
    2023 Black Limited TRD Off Road
    Hi all just got the Dobinsons MRR 3/2 kit put on my 2023 Tundra wanted to see what combination of settings folks are running for daily driving and how you like the ride to be. Are most of you adjusting rebound often or mainly just high speed and low speed? I’ll adjust accordingly off road but wanted to see if there were any preferred settings for normal everyday driving.
  2. Dec 12, 2023 at 3:59 PM
    tuansmith
    tuansmith New Member
    Tuan
    2023 Tundra Limited TRD-Offroad
    Does anybody know what the recommended shock settings are for front and rear for the MRR? I dont have the paper anymore.
  3. Dec 12, 2023 at 7:00 PM
    blenton
    blenton New Member
    I have a second Gen tundra, but the recommended settings from the book were WAY off my for truck. I runs stock wheels and tire size (which I was later told was not acceptable for these shocks, along with the factory UCA), but have a camper shell, bed slide, and 800 lbs of gear in the bed for a vehicle weight north of 7k. I also have an icon 3 leaf add a a leaf and air bags that sit between 5 and 20 psi depending on how I’m feeling that day and whether or not I plan on towing something.
    I installed the rears while waiting for the fronts to come back in stock. They ended up with lots of rebound (almost maxed) one or two clicks of high speed compression, and 4 or 5 clicks of slow speed compression. Once I installed the fronts, it was a pain to get tuned correctly. The factory settings per the loading of the truck were horribly bad; so bad that I actually pulled the solid off-road motor mounts off and reinstalled the factory mounts, thinking they were the problem. Every bump sent a resonating shimmy through the chassis, up in to the seats, and in to my chest. It was physically uncomfortable to drive the truck. So I turned everything down to the the light load/comfort recommended settings and it was still horrible. I even called dobinson direct and they just told me that I needed to change wheels to a set with more negative offset, put bigger tires on, and replace the UCA with an aftermarket unit. Until I did that, they wouldn’t talk shop with me. When I mentioned that I used an Eibach 650 lb/in coil (Dobinsons coils were out of stock, and I was told that any coil of such and such dimension would work) and that I had them set for just over an inch of lift (actually ended up with 1.7” or so since they didn’t settle, which means the coil was correctly setup and sized according to the preload instructions in the book and resultant lift), Dobinson flat refused to talk and told me I HAD to run 2.5” of lift or more.
    So I turned all the dials back to zero and started from scratch. The fronts ended up with 1 click of high speed compression, 5 clicks low speed, and 6 or so clicks of rebound. I turned down the rebound on the rears a few turns and am still fiddling with rebound front and rear. It makes for a solid, active ride with decent handling in the twisties, but certainly not plush.
  4. Jul 28, 2024 at 5:21 AM
    samibo34
    samibo34 New Member
    2023 Toyota Tundra SR5 TRD Off-Road
    AFE Pro 5R Cold Air Intake AFE Turbo Inlet Pipes AFE Hot Charge Pipes Carven Cat-Back Exhaust JB4 Tuner JB4 Throttle Response Modulator
    I have a 2023 Tundra. I run my MRAs at
    Front&Rear
    LS:3
    HS:7
    RB:6
    This is pretty comfortable for me but it’s somewhat boaty. If I’m gonna be on more curvy roads i turn it up quite a bit to give me a more planted feel although it does come with a cost to ride comfort. I run the Icon Billet UCAs, Dobinson rear panhard rod and king rear sway links. Those made up for the boaty feel quite a bit. Also Method 18x9 +18 wrapped in Falken wildpeak r/ts at 35psi all 4 corners.
  5. Jun 27, 2025 at 6:48 AM
    Dew
    Dew New Member
    I have the kit for my 2014. Right now for daily driving I'm at 3 for high compression, 5 for low compression, 6 clicks for rebound on front and 8 clicks for the rear. I change it up a bit when I'm towing my bass boat. I run SPC upper control arms, I have 18" method 304s with 285/75R18 Toyo Open Countrys they are stiff as they are 10 ply.
    crikeymike likes this.
  6. Aug 13, 2025 at 10:30 AM
    martinejes
    martinejes New Member
    Jesse
    here is what i run currently, it seems like a great mid point for both onroad and offroad.
    front: LSC 5, HSC 3, Reb 10, 1.5 turns.
    rear: LSC 1, HSC, 3, Reb 6
    if i am towing like a heavy trailer here is what i run:
    front: LSC 10, HSC 7, Reb 15 2.5 turns
    rear: LSC 6, HSC 8, reb 10
    the rear adjustment obviously need to differ considering there is hardly any weight in the back. up front carries alot of the weight so it differs as well.
    This suspension kit is really really really nice! like it better than the kings. I also like it better than what i have on my 4runner which is the bilsteins 6112. Spring recommendation also plays a key roll, i just ordered whatever the stock spring rate is.
    My tundra is the TRD offroad package limited. So i didnt need to purchase any extended front drive shafts. and since its just a 3" lift, i also didnt need to front stabilizer links, front extended drive shafts, front bump stops, or extended brake flex hoses. If your truck doesnt have the TRD offroad package, you will need upgrade these parts. The Dobinsons UCAs are REALLY nice..especially for climates like Utah, and they look legit. I would consider this suspension over the TRD Pro hands down.
