Tundra engine recall - interesting news
Discussion in '3rd Gen Tundras (2022+)' started by katekebo, Jul 25, 2024.
  1. Aug 12, 2025 at 4:53 PM
    #4891
    FrankG
    FrankG New Member
    Francois
    2022 Lunar Rock Sr5 TRD Off Road
    To each his own. I wanted to push the replacement off as long as possible as well but changed my mind when reports of the new engines started coming in. Didn’t want to miss out on a revised design and potentially better fuel economy. Also figured 125000kms for free was a good deal. Made sense to get it replaced while I had the time in stead of it letting go in winter and SOL. Also figured I’d I had a failure on a motor with a known issue that would be on me but if the replacement failed, then I did my due diligence and I can blame someone else.
    Edit: There should also be a sweet spot where the dealer techs did enough replacements so they know what they’re doing but not so many where it starts to be too easy and they lose focus. Mine was around #20 at my dealership.
    Breathing Borla likes this.
  2. Aug 12, 2025 at 4:54 PM
    #4892
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield
    Or he must not drive through the middle of nowhere Alabama 1000 miles from home with wife, dog, and tons of gear. But hey, if you drive only 5 miles from home by all means delay as long as possible.
    woods, AZBoatHauler and kirkb like this.
  3. Aug 12, 2025 at 5:09 PM
    #4893
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I've seen no evidence the replacement engines are immune to the same bearing failures. So the "what ifs" are really no different, IMO.
    If my truck was on the recall list, I'd milk the bonus miles as long as possible. If I made it to 100K miles without failure, I might consider getting my new engine then.
  4. Aug 12, 2025 at 5:12 PM
    #4894
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR5
    He's not kidding! Not fun in ATL. And thinking possible failure - not good
  5. Aug 12, 2025 at 5:14 PM
    #4895
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    are there reports of the recall motor failing?
  6. Aug 12, 2025 at 6:24 PM
    #4896
    Rb123
    Rb123 New Member
    Washington
    22 trd off-road crewmax mgm
    Bfg at 275/70r18 Lowmax Bumpershellz grill
    Its a 1% failure rate. I will take those odds. You probably have at least the same odds they screw something up on the install.
    Tundrastruck91 likes this.
  7. Aug 12, 2025 at 6:30 PM
    #4897
    Doofus
    Doofus New Member
    Why is the engine primarily failing in the Tundra? I know it has failed in the Lexus LS to some degree, but seems to perform better in the GX, and has been around longer than both. Right? What is special about the Tundra tuning? Is it simply that the Tundra is produced in larger numbers and therefore is discussed more? Are Tundras put under greater duress?
  8. Aug 12, 2025 at 6:45 PM
    #4898
    Matt2015Tundra
    2023 1794 CrewMax
    Yes.
  9. Aug 12, 2025 at 7:11 PM
    #4899
    LionsFan20
    Josh
    24 Tundra
    Okay thank you. I did not know that
  10. Aug 13, 2025 at 3:28 AM
    #4900
    balong48
    balong48 New Member
    2011 Classic Silver Metallic 4Runner Limited
    Source?
    Woodrow bangs likes this.
  11. Aug 13, 2025 at 4:12 AM
    #4901
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    I live in Metro ATL as well.
    Engine failure could be fatal.
    Frankly if I have a failure and survive the first call I make after get truck back with new engine is Carvana. Thankfully I am in a position I dont have to wait and find out if Toyota fixed the problem
    oddhours[QUOTED] likes this.
  12. Aug 13, 2025 at 4:37 AM
    #4902
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    With all the 3rd gen’s dropping like flies on busy freeways, I would expect ambulance sirens blaring and headline news on primetime tv.
    hyperbole abounds…
  13. Aug 13, 2025 at 4:57 AM
    #4903
    Fatone
    Fatone New Member
    To each his own is the point which you missed.
    If you do happen to live in an area where 2/3 of the people think wide open is a safe speed, you quickly realize how poor an arbitir of risk the general population is.
    In terms of big crash ups I invite you to watch the Atlanta news. Like most big cities they report the ones where people die or close the interstate for hours if it's a slow day and there are not 6 murders or an active shooter situation that takes the air time
    oddhours likes this.
  14. Aug 13, 2025 at 5:00 AM
    #4904
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR5
    :frusty:
    best of luck with your truck, just know you are not immune.
  15. Aug 13, 2025 at 5:13 AM
    #4905
    Matt2015Tundra
    2023 1794 CrewMax
    This forum. I don't have time to search for you.
    We road-trip cross country typically 2 times a year, and I can confirm that Atlanta drivers are the worst of any place we've been. I try to time our route so we are traveling thru that shit-hole in the middle of the night.
  16. Aug 13, 2025 at 5:14 AM
    #4906
    Fatone
    Fatone New Member
    My only experience with Toyota roadside assistance was 15 years ago with 1-800 Lexus. Back then and I think now Toyota subbed it out to AAA whose service is just awful. They throw you tow request on the tow truck service queue and never check it gets fulfilled. AAA pays so little every operator takes other jobs first. I spent 5 hours on the side of the road for that one .
    My truck is mainly local. But occasionally I do a 4 hr round trip to a work site. Everytime I leave it enter my mind is this the day I am going to camp out for 6 hours on the side of the road in 100 degrees heat? I find myself just saying screw it and take the wife's vehicle.
    kirkb likes this.
  17. Aug 13, 2025 at 5:30 AM
    #4907
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR5
  18. Aug 13, 2025 at 5:43 AM
    #4908
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    lvl 7.
    Cast by a war mage. A cleric will bungle it and turn the entire party into newts.
  19. Aug 13, 2025 at 5:56 AM
    #4909
    Retired...finally
    I sure see a lot of 3rd gens safely and happily cruising the nations highways. If you read some of the opinions on here you'd swear someone found a cheap and simple way to retrofit the boat anchor 5.7 in place of the ittly bitty 3.4.
    mrlittlejohn likes this.
  20. Aug 13, 2025 at 6:11 AM
    #4910
    raylo
    Frederick, MD
    On some of my road trips to FL I pass through ATL. So I get to do the Capital Beltway and other DC Metro nightmares like I-270 and I-95 AND the ATL mess in the same day. LOL. Fun, fun fun. Fatone is correct, if your truck dies on any of these you are in a world of hurt. And we do not know that the failure rate is 1% since Toyota never said that or told us anything. And for a high consequence result, a 1% probability is a lot. Heck, if the lottery was 1% chance to win, I'd play every day. Unlike the extremely low odds reality where I haven't played ever.
    kirkb likes this.
  21. Aug 13, 2025 at 6:27 AM
    #4911
    2wheelsforfun
    2wheelsforfun New Member
    Foothills AB Canada
    We also had very bad service from AAA when our daughters Santa Fe engine exploded on a busy freeway (sound familiar?). We switched to Coachnet and have had to use it twice and have had excellent service both times, with them checking in with expected arrival times and follow up call to make sure they did arrive etc. Highly recommended.
  22. Aug 13, 2025 at 6:52 AM
    #4912
    raylo
    Frederick, MD
    What are you smoking this morning? ;-)
  23. Aug 13, 2025 at 7:16 AM
    #4913
    balong48
    balong48 New Member
    I ask because I’ve been monitoring this forum - I’ve yet to see a report of a long block replacement failing.
    Unless I’m missing it, which I could be, I don’t see anything that highlights long block replacement failures.
    I’m trying to play Toyota PR boy here, I’m genuinely curious as I haven’t seen anything pointing to long block failures.
  24. Aug 13, 2025 at 7:32 AM
    #4914
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Here's a couple of "Possibles" ... of course could be a dealer install issues.
  25. Aug 13, 2025 at 7:46 AM
    #4915
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR5
    In reference to the spreadsheet I would assume the first replacement engine was a long block as per recall... a second failure would be said long block? Or am I confused?
    @balong48
  26. Aug 13, 2025 at 7:50 AM
    #4916
    LionsFan20
    Josh
    24 Tundra
    Unless the motor was replaced under the recall, it only got a short block rebuild(most likely)
  27. Aug 13, 2025 at 7:51 AM
    #4917
    LionsFan20
    Josh
    24 Tundra
    So no evidence of a long block failing...just speculation on our part so far
    Not saying its impossible
  28. Aug 13, 2025 at 7:54 AM
    #4918
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Both engines were replaced under recall so one would assume long block
  29. Aug 13, 2025 at 7:57 AM
    #4919
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR5
    all three were 22' non hybrids on the spreadsheet... ? So they would have received long blocks?
  30. Aug 13, 2025 at 7:59 AM
    #4920
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    As long as it was done during the recall window and not prior to the recall, yes
