ScreenProTech - Gen3 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by HGParrish004, Jan 22, 2025.
  1. Aug 12, 2025 at 10:02 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I think Eurodriver once posted a pic of his un-protected dash display. It looked like he had cleaned with steel wool. LOL!
    After seeing that, the ScreenProTech kit was the first thing I installed on mine. It's been perfect. I highly recommend the matte finish for both the infotainment screen and the dash display. It cuts down on the sun glare a bunch.
  2. Aug 12, 2025 at 10:03 AM
    Breathing Borla
    AZ
    ya, on any vehicle Ive ever had its impossible to not scratch that dash area, just buy the set and you'll be good, it also hides some light scratches if you have any, great product
    just dont be shy with the lube you use when you install it, it will then take a week or so to clear up but it will
    Matt2015Tundra likes this.
  3. Aug 12, 2025 at 1:07 PM
    NimbusDog
    NimbusDog New Member
    Tampa, FL
    2022 Tundra
    Yeah, that product is so far overpriced it isn't funny. Tempered glass does come in curved applications, although I get that one likely doesn't exist for the Tundra, it can't hurt to ask.
    As I already have the 14" center screen protected, if anyone finds a gauge cluster protector only please post the link here.
  4. Aug 12, 2025 at 2:33 PM
    g4waldo
    g4waldo Professional Looking CSM Owner
    2023 Celestial Silver Metallic Tundra Platinum 4x4
    When I went to install my tempered glass I realized I was pre-cleaning the original cover. Never noticed it was there, but luckily I figured it out before I tried to stick my protector on there. I only noticed it was there because I was trying to clean what I thought was a smudge or small scratch, then the whole thing moved.
  5. Aug 12, 2025 at 2:44 PM
    Matt2015Tundra
    2023 1794 CrewMax
    The thin factory protective cover on the 14" screen is intended just for shipping. The dealership is suppose to remove that as part of their pre-delivery check list.
    Breathing Borla likes this.
  6. Aug 13, 2025 at 4:05 PM
    SoAzTundy
    SoAzTundy New Member
    2024 WCP Platinum TRD OR
    Hey all. Quick update. I received an email from screenprotech about my inquiry into buying just a gauge protector. They said they'd help me out. Ill let you all know when I hear more but it sounds promising.
  7. Aug 13, 2025 at 4:14 PM
    NimbusDog
    Tampa, FL
    2022 Tundra
    I'll save you the trouble. I emailed them as well about this... Here is their reply...
    See any problems here? It's just a $15 off coupon code. $40 for just the cluster cover is insanity.
  8. Aug 13, 2025 at 8:30 PM
    SoAzTundy
    I just got that same email. Not sure i want to spend $40 either.
  9. Aug 13, 2025 at 9:26 PM
    Breathing Borla
    AZ
    It’s worth that
    eddiefromcali and akira like this.
  10. Aug 14, 2025 at 1:08 AM
    NimbusDog
    Tampa, FL
    2022 Tundra
    Respectfully, 100% disagree.
  11. Aug 14, 2025 at 6:32 AM
    Matt2015Tundra
    2023 1794 CrewMax
    You own a $70K truck, and you won't spend $40 to protect the dash display? Hmmm....
    Breathing Borla and akira like this.
  12. Aug 14, 2025 at 6:38 AM
    akira
    akira 25 Tundra Limited TRD OffRoad
    San Diego
    Agree. I see those fine scratches in the gauge display everyday! Ordered the gauge display and a backup using the code DRIVERONLY...$54 for 2 and I will have a backup.
  13. Aug 14, 2025 at 7:44 AM
    SoAzTundy
    Alright I went and ordered the screen and a spare. $25 ish each sounds better in my mind. Haha
    akira and Breathing Borla like this.
  14. Aug 14, 2025 at 8:01 AM
    Breathing Borla
    AZ
    its worth it, put plenty of spray lube on when you put it on dont be shy. that way you can move it around a bunch to get it perfect
    it will dry up and be clear over a few days
    I made the mistake of not enough the first time I tried and had to start over
  15. Aug 14, 2025 at 8:02 AM
    Breathing Borla
    AZ
    I wasnt going to say it, but since you did, HA :rofl:
  16. Aug 14, 2025 at 8:06 AM
    SoAzTundy
    You can just put mine on for me then! ill buy you a beer.
  17. Aug 14, 2025 at 8:16 AM
    Breathing Borla
    AZ
    sure, I just saw your in AZ ha
    I work cheap, coors light
  18. Aug 14, 2025 at 8:18 AM
    NimbusDog
    Tampa, FL
    2022 Tundra
    Cost of vehicle is irrelevant to price gouging. Bold of you to assume I paid 70k.. And also wrong. Your logic...:monocle:
  19. Aug 14, 2025 at 8:30 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Ummm...OK
  20. Aug 14, 2025 at 8:46 AM
    #50
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Are you guys polishing the cluster before installing the protector?
  21. Aug 14, 2025 at 9:10 AM
    #51
    Breathing Borla
    AZ
    no, don't do that.
    if you even touch it it scratches, I would really just do the absolute minimum to clean it before install.
    the nice thing is the protector will makes the really fine scratches go away
    eddiefromcali[QUOTED] likes this.
  22. Aug 14, 2025 at 9:50 AM
    #52
    Matt2015Tundra
    2023 1794 CrewMax
    No. Just follow the installation instructions to a T.
    If your infotainment screen and dash display are dusty, I recommend using compressed air to blow the dust off. The worst thing you can do is try to remove the dust by wiping it off with a micro-fiber cloth. And as Borla said, don't be shy with the spray lube.
    I took my time and was very careful when I installed my ScreenProTech kit. The results were perfect except for one tiny bubble that I couldn't squeegee out of my 14" screen. That went away in a couple of days. I think it took me a total about 20-25 minutes.
  23. Aug 15, 2025 at 4:37 PM
    #53
    jaxadam
    jaxadam New Member
    This has me interested.
