Gen 3 5100s and 275/70-18
Discussion in 'Suspension' started by ullmsie, May 13, 2025.
  1. May 13, 2025 at 3:44 AM
    ullmsie
    ullmsie [OP] New Member
    Limited DC TRDOR
    I’ve been fighting the urge to do a level and tires for a long time but finally went though with it. Work was done at OK4wd in north NJ and they were awesome. It’s sitting about 1/2” higher in the rear with the 1.8” lift setting.
    I didn’t want 35s or LT tires so I went with the g3 Terra grapplers in 275/70-18SL on OEM trd pro 18s.
  2. Aug 12, 2025 at 7:32 AM
    ullmsie
    Limited DC TRDOR
    The more I looked at it the more I wanted a little rake back. Ended up installing bilstein rear springs and then swapping them out for OEM springs with cornfed 1” spacers. The bilstein springs lifted the rear 2.5” over stock which was way more than I wanted. They were +500lbs capacity but even with weight in the bed they were still super high.
    Bisltein springs:
    cornfed spacers:
    Griff, KNABORES and BlackNBlu like this.
