Alpine ILX-F511. Game Changer
Discussion in 'Audio & Video' started by running214, Mar 2, 2023.
  1. Aug 9, 2025 at 9:13 PM
    #1831
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I went all through the settings and only saw 1 sub box to check in the menu. I checked it, but no change.
  2. Aug 9, 2025 at 9:16 PM
    #1832
    Azblue
    The Dirty T ( ^_^)_且
    There is also a sub level, 1-10 if I recall.
  3. Aug 9, 2025 at 9:18 PM
    #1833
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Outside of sub toggle and level, only other thing I can think of is the turn on lead from the HU. Is your sub amp getting power?
  4. Aug 9, 2025 at 9:26 PM
    #1834
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'd say it's too late to go outside and check but 1) it's the weekend, and 2) it ain't 1000° outside right now, so hold up and I'm gonna go check the menu and amp power.
    TRDFerguson and Azblue like this.
  5. Aug 9, 2025 at 9:28 PM
    #1835
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Godspeed sir
    Azblue likes this.
  6. Aug 9, 2025 at 9:31 PM
    #1836
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  7. Aug 9, 2025 at 9:39 PM
    #1837
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This?
  8. Aug 9, 2025 at 9:40 PM
    #1838
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Check your connections off the alpine, specifically to make sure you didn’t hook up the radio antenna instead of the remote turn on lead.
  9. Aug 9, 2025 at 9:41 PM
    #1839
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    If you go to the fade/bal page does that have the sub box checked? But yes that’s the level he’s talking about. I think you have a power issue from your last post though.
  10. Aug 9, 2025 at 9:44 PM
    #1840
    Azblue
    This
  11. Aug 9, 2025 at 9:44 PM
    #1841
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'll do that in the AM. I bet I mixed up the two... Grrrr
  12. Aug 9, 2025 at 9:45 PM
    #1842
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The fact I don't even see that option says something ain't hooked up right
  13. Aug 9, 2025 at 9:46 PM
    #1843
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This?
  14. Aug 9, 2025 at 9:47 PM
    #1844
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Si
  15. Aug 9, 2025 at 9:49 PM
    #1845
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The overall aesthetic and screen response is leaps n bounds better than the Pioneer I had.
    TRDFerguson and FrenchToasty like this.
  16. Aug 9, 2025 at 9:53 PM
    #1846
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Agreed - my Pioneer was hot garbage in a lot of ways. I still miss my Kenwood though. The Alpine isn’t bad by any means. Some minor annoyances is all I’ve ever experienced.
  17. Aug 9, 2025 at 10:00 PM
    #1847
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The dash cam integration is next level
    TRDFerguson[QUOTED] likes this.
  18. Aug 10, 2025 at 9:32 AM
    #1848
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    So I have nothing to connect this little guy to. There's a couple available bullet connectors they included in the dash cam harness (one says Bat and the other Acc). I'm assuming I could connect to Acc and be good to go? I'll have to swap one of them to male because they're both female.
  19. Aug 10, 2025 at 10:18 AM
    #1849
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It worked. Sure glad TGP included those little extra pig tails.
  20. Aug 10, 2025 at 10:26 AM
    #1850
    @AZTundra can you post pics of your settings? I have very little sub out put and no rear speakers either. They are turned on and still nothing.
  21. Aug 10, 2025 at 11:50 AM
    #1851
    AZTundra
    Paul
    Phoenix, AZ
    Here are the ones that might be of help. There is also a volume setting under function for each of the different devices, worth checking, but if you’re only having subwoofer issues probably not the case. Have you also tried turning up the amp gain? Wondering if the output voltage is different and requiring some tuning of the amp settings?
    bulldog93 likes this.
  22. Aug 10, 2025 at 12:22 PM
    #1852
    I dont have rear speakers either. They are checked ro turn on. I also dont have auto dimming when i turn the headlights on.
  23. Aug 12, 2025 at 10:16 AM
    #1853
    Can anyone assist with this? TGP is currently not understanding what I sent to them.
    2020 Toyota Tundra with non-JBL amplified system.
    Pioneer 7600 NEX with MaestroRR
    Rockford R2-300X4 4 channel amp for front and rear
    Rockford R2-1200X1 sub amp
    Speaker wire from amps to speakers
    RCA’s from head unit to both amps
    Removed Pioneer and installed Alpine ILX-F509
    Rear speakers and subwoofers are both checked to “On”
    Front speakers work
    Rear speakers have no input
    Subs are very very low.
    No sound or EQ adjustments have been made to the head unit
    Troubleshooting:
    Front speakers work with RCA in front ports on amp using Front RCA output from head unit
    Front speakers work with RCA in front ports on amp using Rear RCA output from head unit
    Nothing will work connected to Rear RCA input ports on amp
  24. Aug 12, 2025 at 10:55 AM
    #1854
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Are you sure you didn’t blow a fuse on the amp while disconnecting and reconnecting? Have you checked to make sure your wiring harness is seated into the amp properly? Gains turned up? And did you install the in line resistor for the maestro wiring harness?
  25. Aug 12, 2025 at 11:00 AM
    #1855
    The amps were not touched from the previous install. They power up, and gains are up. As far as for a resistor, it was the pre-wired bundle from Trail Grid Pro so I am not familiar with it. I spoke to Alpine. He said that since my front speakers work off both front and rear RCA outputs, it sounds like I lost the rear channel on the amp itself. For subs, he said I will need to adjust the level in the head unit.
  26. Aug 12, 2025 at 11:05 AM
    #1856
    shawn474
    MoCo, Maryland
    I would check the fuses at the amp for continuity; may have blown. Did you disconnect the battery while swapping the head units?
  27. Aug 12, 2025 at 11:12 AM
    #1857
    That amp does not have on-board fuses.
    shawn474[QUOTED] likes this.
  28. Aug 12, 2025 at 11:16 AM
    #1858
    shawn474
    MoCo, Maryland
    is there an in line fuse between the battery and amp? I am obviously leaning towards this being an amplifier issue vs a head unit. When I installed my alpine ilx-f511 I removed the factory amp. I purchased a factory amp bypass harness to plug into the aftermarket amp. You know that the front speakers run off of the head unit, so the fact that the rear speakers and sub aren’t working well makes me think the amp isn’t working properly to power them or there is a problem with the wiring that feeds the amp and rear speakers / sub
  29. Aug 12, 2025 at 11:26 AM
    #1859
    Dash speakers are working from the head unit, and front door speakers are working from the 4 ch amp. I think i either lost the rear RCA on the amp or the rear speaker terminals themselves. I can check them for continuity with a multimeter. Subs are on their own amp but I haven't messed with the sub settings yet on the head unit.
  30. Aug 12, 2025 at 11:34 AM
    #1860
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    So I have the older Alpine bass knob (pre-BT) and noticed that the head unit took a lot of the control away from it. My subs came to life once I started farting around with the settings on the unit.
    TGP recommended the newer version of the bass knob because it will do overall volume and bass control.
