Air Shutter Grill Motor ‘Cheat’
Discussion in '3rd Gen Tundras (2022+)' started by 23TRDORP, Jul 9, 2024.
  1. Jul 9, 2024 at 7:11 AM
    23TRDORP
    23TRDORP [OP] New Member
    2023 Lunar Rock TRD ORP
    ICON Stage 9 CBI Skids Ironman Bumper
    Greetings all - are any of you fine, IT-literate people able to share a 3D print file for the little fitting required to add to the front air shutter grill motor?
    I removed my air shutter grill due to a new Ironman Bumper and winch, resulting in flashing Christmas lights all over the dashboard and lots of annoying alarms. Adding this little fix seems to be the only way to give me some peace until I can find a way to refit the shutter grill.
    Also, If anyone has recently discovered another way to fix this, I’d love to know.
  2. Jul 9, 2024 at 9:22 AM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    Can’t you just leave the shutter motor connected without the shutters? (Even if you have to relocate it) This is what people do with the auto air dam. Just leave the motor only and plugged in. No lights/alarms
  3. Jul 9, 2024 at 9:34 AM
    BabyMoose
    BabyMoose New Member
    2023 Tundra Limited TRD Off-Road
    CBI bed rack, Decked storage, OVS Nomadic 2 RTT, Ironman DeltaWing 270
    What made you have to remove the shutters? From what I had seen, it looked to be compatible with those just not the air dam
  4. Jul 9, 2024 at 9:37 AM
    23TRDORP
    Even if you have an Ironman winch, the air shutter need to be trimmed. I have a WARN 12k winch which is bigger. The shutter assembly would need to be trimmed exactly where the motor housing is.
    easy solution is to change the winch, but want to avoid that.
    BabyMoose likes this.
  5. Jul 9, 2024 at 9:38 AM
    BabyMoose
    Gotcha. Even with a remote mounted control box it would need trimming?
  6. Jul 9, 2024 at 9:38 AM
    23TRDORP
    I tried it plugged in and disconnected. The way it appears to work is that there is a sensor in the motor which stops it at 90 degree rotation. Others have made a 3D printed solution to trick the motor limit sensor
  7. Jul 9, 2024 at 9:39 AM
    23TRDORP
    Yes for the Warn 12k
    BabyMoose[QUOTED] likes this.
  8. Jun 30, 2025 at 6:22 PM
    TindraFireGuy
    TindraFireGuy New Member
    25 Tundra
    Ironman bumper, 12000 winch,
    Just added an Ironman bumper and winch over the weekend. I had to cut the bottom fins of the grille shutters. Have the check engine light on now and the grille shutters warning. Anyone have a solution?
  9. Aug 6, 2025 at 6:36 PM
    tundra161
    tundra161 New Member
    2022 tundra limited trd off road
    Arb bumper, elka lift, 35” tires with rhino wheels.
    I’m having the same issue right now with my tundra. I just installed a arb bumper with a 12k winch. Now my engine light is on because of the shutters. I tried to trim the shutters like what arb says to do but I’m pretty sure it messed them up. Did you find any solution to this issue?
  10. Aug 6, 2025 at 7:15 PM
    TindraFireGuy
    25 Tundra
    I ended up restricting the movement of the sensor to 90 degrees with a small bolt put through one of the holes in the mounting tab and then roughly found 90 degrees and superglued another plastic piece from one of the fins that I cut off. Also I kept the original gear that went into the sensor cut it off flat and glued another plastic piece onto it as a “wing” to allow it to contact the bolts. I can take pictures tomorrow if you want to see. The whole thing I zip tied it onto the grill.
  11. Aug 6, 2025 at 7:28 PM
    tundra161
    If you don’t mind please send me a photo. I tried everything to get this shutter to stop giving me an engine light and so many warnings.
  12. Aug 6, 2025 at 7:30 PM
    TindraFireGuy
    25 Tundra
    I will try to remember to take the picture tomorrow. I also have a obd2 scan tool which I reset the codes. At least the active codes. I think scan tool doesn’t delete the permanent codes bit they don’t show up on the dash.
  13. Aug 6, 2025 at 7:46 PM
    tundra161
    What tool are you using ? Carista ?
  14. Aug 9, 2025 at 7:59 AM
    TindraFireGuy
    25 Tundra
    Here are pics. Has been working for over a month or so.
  15. Aug 9, 2025 at 3:50 PM
    tundra161
    Thanks buddy I appreciate it. I’m gonna do the same thing.
  16. Aug 10, 2025 at 4:17 AM
    NimbusDog
    NimbusDog New Member
    Tampa, FL
    2022 Tundra
    What year did they add these shutters? Mine doesn't have them.
