Shuddering when accelerating, general lack of power, no CEL.
Discussion in '1st Gen Tundras (2000-2006)' started by Aerindel, Aug 8, 2025.
  1. Aug 8, 2025 at 6:16 PM
    Aerindel
    Aerindel [OP] New Member
    Montana
    This just started.
    Drive into town went fine, pulling out of my parking spot at my second stop there was an odd vibration. Drove around town doing my other stops trying to figure out if I was imagining it for half an hour and then headed home.
    Noticeable lack of power on the highway. Not super dramatic, but maybe 15% less power than I expected and vibration when accelerating. I had a bunch of metal roofing on the ladder rack so I wasn't going fast anyway and it was making a lot of wind noise so made it kinda hard to pin down.
    Made it home and now in the driveway messing with it, it will shudder and hesitate when tromping on the gas in park or neutral before revving up.
    Runs smooth at revs, and at idle but doesn't like to rev up it seems.
    My first thought is spark plugs, as I've never down them in the 40k I've had the truck, and I'm not sure when they were done before.
    Does that make sense though as something that just started between one store and another?
    I have a code reader that will show live data, but I don't know what to look for.
  2. Aug 8, 2025 at 7:05 PM
    Aerindel
    Montana
    Light throttle makes it sound kinda like a steam train.....chugachugachuga.....
  3. Aug 8, 2025 at 7:13 PM
    vmkeith
    vmkeith Slow is smooth, smooth is fast
    Vince
    Clark County, Wa
    2014 Super White Tundra SR5 CrewMax 4x4
    Rhino Lining Cooper Discoverer ATP II LT275/70R18 TRD Pro dual exhaust with TRD exhaust tips Lund 5" Cab Length Oval Curved Tube Steps RealTruck TruXedo Pro X15 Tonneau Cover RealTruck Elevate FS Bed Rack Rhino-Rack Carriers Diode Dynamics SS3 LED Fog Light Kit Auxito LED Headlight Bulbs Rydonair 7" antenna
    Sounds like a similar problem with a 2001 F-150 I had. Turned out to be a torn boot on the ignition coil. Changed the spark plugs and ignition coils and problem went away.
    Aerindel[OP] likes this.
  4. Aug 8, 2025 at 8:41 PM
    Aerindel
    Montana
    Well, damn, this is embarrassing....
    My wife asked, 'could the CEL just be burned out'? And I was like....of course not....
    But then I checked and sure enough....no CEL with the key turned to on. Then I ran my code readers......fuuuq......this is an all time record for me.
    ColoradoTJ likes this.
  5. Aug 8, 2025 at 10:06 PM
    Aerindel
    Montana
    okayyyy....
    I take a look at #8.....and the coil has some writing on it under the dust.....just that coil....
    "Made in China"
    Spark test, nothing, swap with #7, nothing on 7, spark on 8....
    So at least this problem is solved. I will have to dive into the rest. I reset everything, and we will see what comes back. Who knows how old the other codes are?
    Put in a order at the local napa for pickup tomorrow. They had both Denso coils and plugs in stock.
  6. Aug 9, 2025 at 4:27 AM
    vmkeith
    Vince
    Clark County, Wa
  7. Aug 9, 2025 at 5:17 AM
    bfunke
    bfunke Tundra Curmudgeon
    Rock Auto sells Denso coils for half of what Napa does
  8. Aug 9, 2025 at 6:21 AM
    As soon as I read your initial post I thought "ignition coil". I remember PHM describing similar issues and it was a bad coil.
    Now would be a great time to order new ones from Rock Auto. And use a 5% off coupon code.
    bfunke likes this.
  9. Aug 9, 2025 at 6:38 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    @Aerindel : 0
    @Aerindel wife: 1
    She must have been secretly reading posts and using the search bar in this forum!;)
  10. Aug 9, 2025 at 6:54 AM
    Damn
  11. Aug 9, 2025 at 7:56 AM
    Between this and the ball joints, your truck is telling you it needs more preventative maintenance.
    The Black Mamba likes this.
  12. Aug 9, 2025 at 2:33 PM
    Aerindel
    Montana
    Or that I need a new truck....I must admit, I've been eyeing 2nd gens on facebook.
    But actually both problems have the same origin.
    A previous to me replacement with cheap parts.
    Does anyone actually preventively replace all their coils? That is like a $800 job.
  13. Aug 9, 2025 at 2:36 PM
    Aerindel
    Montana
    Damn, you are right. Oh well. This way I don't have to wait for it. Truck will be working again by tonight.
    But I will keep that noted.
  14. Aug 9, 2025 at 3:19 PM
    I did but only because I was going on a cross country road trip and didn't want to get stranded. It was ~$450 from Rock Auto for 8 new Denso coil packs. They had lasted over 20 years at that point. Didn't want to push my luck.
  15. Aug 9, 2025 at 3:53 PM
    Aerindel
    Montana
    Yeah, as far I can tell, all but one of the OEM packs have lasted 25 years.
    I am actually thinking about ordering one spare and keeping it in the truck just in case one blows on a long trip.
  16. Aug 9, 2025 at 3:56 PM
    Aerindel
    Montana
    Ironically, I did notice the other day that my 4WD indictor light was burnt out, and ordered a new bulb, but was irritated I could only get them in an 8 pack from Amazon.....guess I should have checked if any other bulbs had failed at the time....
    Still amazed my CEL went out, because I'm not one of those people who just leave it going all the time.
