4.7 limp mode
Discussion in '1st Gen Tundras (2000-2006)' started by Lanemc, Jul 20, 2025.
  1. Jul 20, 2025 at 10:40 AM
    Lanemc
    Lanemc [OP] New Member
    2001 black tundra SR5
    Could anyone help me out I was driving and got almost to 60mph and it slammed and lost power, rpms would go up but didn’t help it
  2. Jul 20, 2025 at 10:48 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Any codes? Theres 100 or so sensors. Recent work done?
    you’re gonna have to dig deeper.
    455h0le_dachshund likes this.
  3. Jul 20, 2025 at 11:05 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Gonna need to get the codes read. I went into limp mode in my 06 about two months ago. Truck was driving fine, then at a stop light it started idling low and CEL came on. Red light turned green and the truck wouldn't berely move
  4. Jul 20, 2025 at 11:11 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Were here to help, but… right now, the best we can do is say, yea you can fix that. And not really mean it, cause…i dunno either.
  5. Jul 20, 2025 at 11:25 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Need more info. Doesn't sound like a limp mode. Sounds more like a transmission failure mode.
    KNABORES likes this.
  6. Jul 20, 2025 at 11:41 AM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    Missing the most basic info. Which engine? 2WD or 4WD? Different transmissions. Really hard to give any comments or places to start without that.
    ATBAV8 and joseph_womack like this.
  7. Jul 20, 2025 at 12:23 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Assuming it's an automatic here, the V6 and the V8 were the same transmission Aisin A340, plus the title says 4.7L, so we know it's an auto A340 4 speed
    Fragman[QUOTED] likes this.
  8. Jul 20, 2025 at 12:34 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    om gonna wing a guess at clogged cats, bad gas, or a bad ground somewhere.
  9. Jul 20, 2025 at 12:59 PM
    Fragman
    Fragman New Member
    Ha! Not sure how I missed the engine in the title!
  10. Jul 20, 2025 at 1:04 PM
    @Lanemc explain "lost power", like it won't move, at all, or it's difficult to move.
    With limp mode, the truck won't shift above 3rd gear and runs like shit. Clearing the code will help until the code sets again. Need to know what the code is before anyone call tell you what it is.
    If you heard a loud bang out back and the driveshaft isn't spinning, then the 2000-2002 are known for having a weak planetary which likes to grenade abruptly. If you heard that and you rev but the driveshaft is spinning, then you either just blew your rear end or pinion.
    Get us three things:
    1. Codes, if the check engine light is currently on
    2. Tell us whether the driveshaft is spinning
    3. Tell us if you're 2WD or 4WD
  11. Jul 21, 2025 at 5:27 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    My experience with limp mode in my Tundra has been a CEL for a knock sensor. When that light comes on, getting the truck to even 35mph is a major chore. I recently had to drive to move a mattress for a family member, drove it with the code reader hooked up so the light could be cleared if it popped on. Yeah, I know a rodent got under my intake and chewed up some wires (confirmed with a borescope camera), just haven't had the time to get to it yet (not my daily driver).
  12. Jul 21, 2025 at 6:48 AM
    I think I mentioned, but we're in similar boats. P0328 here. But no chewing. I suspect one of two things, since it's super random and only happens within the 1st mile of driving (also requires two consecutive trips with same event in order to trigger). I've either got a loose/faulty connection on one of the pins and/or the harness connector is loose, or the knock sensor is on its way out. Either is feasible. I need to look into when it happened. I'm wondering if the alternator burning up may've impacted the sensor upstream. But the code pops so infrequently for me that it hasn't been high on my priority list. I've always got the wireless OBDII dongle plugged in, so if it ever does come up, I confirm the code and clear it and the truck is instantly back to full function, and the code never returns, usually for weeks or months.
  13. Jul 21, 2025 at 7:29 AM
    kentuckyMarksman
    I just know I saw a rodent nest under my intake with the camera, maybe even a dead mouse. I'm assuming the wires are chewed. My P0333 code pops on most often on start up, or within 2.5 miles of start up. It is certainly quite annoying and it has popped on in really inopportune times before. I've parked the truck until I have time to pull the intake off, hopefully this weekend.
  14. Jul 21, 2025 at 7:45 AM
    OP tossed a frag grenade in here and bounced out.
    HBTundra and joseph_womack like this.
  15. Jul 21, 2025 at 7:49 AM
    Fragman
    Fragman New Member
    Nah, thet NEVER happens... :)
    shifty` likes this.
  16. Jul 21, 2025 at 7:50 AM
    Says the Fragman
    shifty` likes this.
  17. Jul 21, 2025 at 9:31 AM
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Yeah, CEL codes would be nice. No matter the code, for the 4.7 I recommend a SAIS bypass.
  18. Jul 21, 2025 at 10:56 AM
    Gah, seems like so much more hassle than it’s worth. We have more people coming in here bitching about still having problems after the bypass than we do people using it. So much so that I honestly would just replace the damn pump and valves and be good for another 20 years.
    bfunke and KNABORES like this.
  19. Aug 3, 2025 at 11:47 AM
    Acedude
    Acedude New Member
    Colorado Plateau
    I bought and installed the slyfox75 bypass kit, no problems on the 2007 and 2008 4.7's. Great guy, great kit for $60.
    I didn't waste money on Rutech or Hewitt, maybe their kits are the problem.
    shifty`[QUOTED] likes this.
  20. Aug 9, 2025 at 9:25 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Identical situation for me too. happened back in Jan of 2020, checked for rodents etc. nothing...at the time I chalked it up to me lightly cleaning the engine bay and water in the valley making a connection it shouldn't after it thawed out. CEL would only come on when I had been driving for almost exactly and hour on interstate each time and it was freezing cold out the entire time this happened.
    I just had it pop on again the other day for no apparent reason. Cleared the code and hasnt came back since. P0328 (knock sensor 1 Circuit high input (bank 1 or single sensor). I also found I have what I believe is the infamous thermostat housing leak. Coolant is dried and doesn't seem to be losing any. Luckily it doesn't look like a super complicated fix other than burping the system after refill even though there is a lack of videos on it.
    I read in my searching that the sais can throw this code too? seemed off to me.
  21. Aug 9, 2025 at 2:47 PM
    I also wondered about that point, fluid in the valley. I'd read it could be the case, maybe I had a colant leak into the valley, but I don't know any leak spots that wouldn't impact the bank 2 sensor first. I saw zero evidence of any water, much less coolant, being down in there.
    But yeah, I should look back to the 1st time this code popped, and see if I cleaned the engine bay not long before. Or if I did anything in the weeks or months prior.
