2020 TRD Pro Rigid Fog Lights
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by evann139, Aug 9, 2025.
  1. Aug 9, 2025 at 7:48 AM
    evann139
    evann139 [OP] New Member
    Evan
    2020 Army Green Tundra TRD Pro
    One (driver side) of my stock rigid industry fog lights went out. Two questions.
    Do LED lights like this just go out or is there likely a wiring/connection problem?
    If i need a replacement light, does anyone know the part number? I can't seem to find it anywhere. Appreciate the help.
  2. Aug 9, 2025 at 8:23 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Is a good idea to check the plugs for any water or debris and hope this solves the problem but if the problem is the LED boards then unfortunately buying a new one is the only way to get it fixed they are expensive I would also consider going with the Diode Dynamics SS3 PROs instead but if you want to keep it OEM style here you go
    Right Hand Side
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-fog-lamp-right-hand-tundra-trd-pro-pt22834190ac?c=az0x
    Left Hand Side
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-fog-lamp-left-hand-tundra-trd-pro-pt22834190ad?c=az0x
    https://hotshotoffroad.com/products/type-b-ss3-led-fog-light-kit-tundra
    Or the full colection of Fogs Upgrades
    https://hotshotoffroad.com/collections/14-21-tundra-fog-ditch-light-kits
  3. Aug 9, 2025 at 9:03 AM
    evann139
    Evan
    Awesome- thanks for the help
  4. Aug 9, 2025 at 9:17 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Just a heads up...
    Our Pros (with the OE Rigid fogs) have a square bezel in the bumper.
    Most of the aftermarket fogs such the DD SS3s, etc. are all round, so you'll need to also source some different fog light bezels for a clean install.
    With that being said, SS3 Pros are a HUGE improvement over the OE Rigid LED fogs.
    bulldog93 likes this.
  5. Aug 9, 2025 at 10:37 AM
    iHacker
    iHacker SW TRD PRO
    Mario
  6. Aug 17, 2025 at 8:02 AM
    Spectre_MT6
    Spectre_MT6 New Member
    2020 TRD Pro
    Who makes square amber fogs for the Pro?
  7. Aug 17, 2025 at 8:28 AM
    Tripleconpanna
    Are you asking about the OE Pro fogs... if so those are Rigid LEDs (white)
    Rigid also makes an square aftermarket fog Rigid D-series Pros, probably not quite as bright as the DD SS3 Pro (which are round), but an improvment over the Pro's OE Rigid fogs...
    I believe the part # for the aftermarket Rigids in amber is 504816, which are about $250 for a pair and will require some minor modificaitons for install but you'll be able to at least use the factory Pro bezel
    PS>>> Here's a set that popped up about a month ago on the forum for sale w/the required brackets for mounting and adapters for wiring; not sure if they sold yet or not, but it will give you an idea... 1
