PAC Audio AP4-TY14 for 3rd gen with JBL
Discussion in 'Audio & Video' started by turbohardtop, Feb 4, 2025.
  1. Feb 4, 2025 at 12:03 PM
    turbohardtop
    turbohardtop [OP] New Member
    I was wondering if anyone is using this unit. I just installed it but it is giving really low voltage output on the RCA's. it gives out around .04v at 30 volume and at MAX (63) it gives around 1.04V. Let me know if you have ran into the same issue.
  2. Feb 4, 2025 at 3:11 PM
    2017TundraNC
    2017TundraNC New Member
    North Carolina
    2022 Tundra 1794 4x4 6.5'
    I literally just posted in the main forum! Definitely following to know if this is our solution!!
    What year did you do your install in? System details, please.
  3. Feb 4, 2025 at 4:15 PM
    turbohardtop
    My TRD Pro is a 2025. The PAC Audio Amp Pro unit only list support for up to 2024 but I think they are the same. It is the AP4-TY14 unit with their speaker wiring harness to wire from the amplifier to the speakers. I was able to measure the output voltage at the RCA out on the Amp Pro unit but do not have anything to compare it to. It seems the output voltage is not linear but more like exponential. At the moment I have problem with my amp not able to tune to the correct voltage. Changing the input sensibility has no affect on the front and rear channels. I wonder if my amp is bad. It is the JL HD900/5. I am using the test tone of 1000 hertz on a usb key to test and tune the amplifier.
  4. Feb 4, 2025 at 4:39 PM
    turbohardtop
    My system consist of a CDT wideband system 4b for the front stage, CDT HD62 for the rear doors, JL 10W6v3 in a sub box that sits on the floor between the rear passenger area. The current amp is the JL HD900/5. If my amp is bad I will go with the VX1000/5i then connect them using the optical out from the PAC Amp Pro to the amp.
  5. Feb 16, 2025 at 2:52 PM
    FlatWhiteTRD
    FlatWhiteTRD New Member
    2025 Sequoia TRD Pro
    Any update on this. I just ordered this for my 25 sequoia TRD pro so that is interesting and now I am worried lol. Was it the amp?
  6. Feb 17, 2025 at 4:16 PM
    turbohardtop
    I was able to get my system dialed in. Adjusting the minimum sound level will help with the voltage on the rca outputs. My amp is working fine but I am thinking of getting the VX1000/5i so I could see the input if it is clipping or not.
    FlatWhiteTRD likes this.
  7. Feb 17, 2025 at 4:21 PM
    FlatWhiteTRD
    Thanks for the reply !! And that's good to hear! I'll be running the kicker LX1300.7. kinda sad that it doesn't have an optical input as it was just released. But it is what it is. You adjusted the min sound via the software from pac that you can download I presume?
    As a side question does the Pac harnesses plug into the amp under the seat or to the back of the factory radio?
  8. Feb 17, 2025 at 7:55 PM
    turbohardtop
    The PAC unit plugs in at the head unit. It is quite small and everything will fit under that center tray. You will need APH-TY02, which plugs to the amplifer, to wire the amplifier to the speakers through the factory wiring. I thought about running new wires but it would be a pain and you would have to drill through the structure to get the wires through. This harness makes it easy. Let me know if you have any questions. Yes, the software is easy to use and i downloaded it from the PAC-Audio website.
  9. Feb 27, 2025 at 1:02 PM
    beer30
    beer30 New Member
    Would a SMD-DD1 help solve this issue?
    That's how I've tuned my past two amps, rather than trying to adjust with voltage.
  10. Feb 27, 2025 at 1:58 PM
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Another cheaper option is set your amp using this oscilloscope: https://www.amazon.com/gp/aw/d/B07QML4LJL?ref=ppx_pop_mob_b_asin_title
    $35, works like a champ. Used it for two different systems so far, and soon to use it on a third.
    Heres how to use it: https://youtu.be/hQOPP-l3AMo?si=wVIXKRueubUCtOQ6
    I plan to test the factory headunit to see where it starts clipping, then tune my amp from there.
  11. Mar 19, 2025 at 5:40 AM
    beer30
    beer30 New Member
    If you install the PAC to only use single channel for a new sub, will the rest of the sound still come from the existing JBL amp?
    Trying to think of alternatives to needing a crazy amp set up.
  12. Mar 19, 2025 at 5:54 AM
    SilveradoSwap
    Yes, it would.
  13. Jul 28, 2025 at 5:58 AM
    Wtundra2023
    Wtundra2023 Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
    Are any of you using android auto with the PAC AP4-TY14 and experiencing delayed notifications for gps and text? I will get the turn by turn directions but only the last half or less of them and texts just mute the music. I don't think this was an issue prior to installing the AP4-TY14.
    For information I am using a google Pixel 8 Pro with android auto.
  14. Jul 31, 2025 at 1:21 PM
    Wtundra2023
    Did you leave the center speaker in the dash amplified by the factory amp or did you remove it?
  15. Aug 8, 2025 at 1:34 PM
    turbohardtop
    I removed all the speakers including center speaker but kept the amp plugged in. I used the PAC speaker harness to connect to my AMP for 4 channel set up with a sub channel for a 5 channel audio.
  16. Aug 8, 2025 at 3:21 PM
    Wtundra2023
    Did you retain your nav prompts even with all the dash speakers removed?
  17. Aug 8, 2025 at 8:26 PM
    turbohardtop
    Prompts are sketchy with the PAC unit. I have not tried to figure it out since I do not rely on audio for navigation. The audio for the sound system is nice and quiet with no white noise at all.
  18. Aug 8, 2025 at 8:30 PM
    Wtundra2023
    Thanks for the response. That kinda confirms what pac and other installers said regarding the need to keep the center dash speaker. I guess all the prompts get funneled through the center dash when using gps and playing music. I am going to reconnect mine and see if i get them back more consistently.
