General Supercharger Thread
  1. Aug 8, 2025 at 4:35 AM
    nags
    nags New Member
    Going there today. Maybe I'll get some more info. At the time of the phone call they didn't know and thought maybe the timing belt kit had an issue out of the box.
    At least when all is said and done I'll have both reman motor and tranny with warranties.
    To add to the awesome news.. I've been driving the Tundra while they have the Lexus and the AC took a total crap on that two days ago.
  2. Aug 8, 2025 at 7:08 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Sounds like you have taken on my luck, I am sorry.
    The rear seat ceiling media deal lock died so when I hit a bump the screen opens, I was back there figuring it out Tuesday & realised the rear air was hot, front is fine, searches were pointless & I moved on yesterday I looked at the unit in the back, it was all as it should be & the air was cold. WTF?
    I looked again this morning, no loose connectors, can't tell if anything is on the bolts sniv showed, The truck feels 80% fine but I hate it not being 100%. I am nearing my wits end.
    Can it be hurt with 0 volts at teh MAF?
    nags likes this.
  3. Aug 8, 2025 at 7:11 AM
    nags
    nags New Member
    Just got home. Zero Freon in the Tundra. They filled er up and put dye in there so if there's a leak we can trace it. At no charge.
  4. Aug 8, 2025 at 7:18 AM
    e30cabrio
    So we have you to thank for the hole in the ozone layer! :p
  5. Aug 8, 2025 at 7:18 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You can but it'll be a dog. Think it defaults to open loop. Which it'll be rich and could lead to knock, misfires, fouled plugs etc. It's usually a get home and diagnose measure.
    Did you verify voltage from the ecu? Continuity from ecu plug to maf?
  6. Aug 8, 2025 at 7:21 AM
    e30cabrio
    Who can I sue for Indeed commercials causing me to immediately think I need indeed????
    HulkSmurf14 likes this.
  7. Aug 8, 2025 at 8:34 AM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Little teaser but 499.03 hp at the wheels after the last dyno run on 93 octane with my 37” tires (going back down to 35’s soon). Heading home within the hour. 9 hours back to NJ. Pumped.
    Jego, M3Tundra-JK, VWTim and 13 others like this.
  8. Aug 8, 2025 at 8:38 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :yes:
    Have fun!!!!
    PS>>> We expect some video!!!
  9. Aug 8, 2025 at 8:39 AM
    WinterWarlock21
    South Jersey
    oh I’ll post the dyno pull after I get home. They’ll load all the pictures and videos on a Google drive for me. Thank you!
    Jego, HulkSmurf14, ssmokedz and 3 others like this.
  10. Aug 8, 2025 at 8:39 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    HulkSmurf14, nags, Mdl and 3 others like this.
  11. Aug 8, 2025 at 8:43 AM
    WinterWarlock21
    South Jersey
    I know! Hate to go down but I have the driver side lean and no more preload available on my king 3.0s to level it back out. I’ve decided to downgrade to 35s to give me the ability to reduce the preload on the coilovers and avoid rubbing issues completely. At least that’s my solution now.
    Tripleconpanna and mustang67408 like this.
  12. Aug 8, 2025 at 8:58 AM
    e30cabrio
    Congratulations!!!
  13. Aug 8, 2025 at 10:05 AM
    e30cabrio
    Traced the wires, saw it also ran through the purge valve which also had almost no voltage, checked the ECM fuse, it was not blown but replacing it got me full voltage everywhere & MAF has voltage!!
    Sending sniv a log!
  14. Aug 8, 2025 at 10:53 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Sometimes those fuses can be deceiving! Glad you found it.
  15. Aug 8, 2025 at 10:58 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  16. Aug 8, 2025 at 1:43 PM
    e30cabrio
    sniv is the man! Truck feels amazing!!!
    Maybe I'm turning a corner????
    IATs are about 18 over ambient (at the MAF) it's 118 & IATs are high 130's low 140s.
    I also figured out the WIFI deal. I have several MESH routers all over including in the garage, when I take the laptop outside, it is on the router inside it was on, I needed to turn WIFI off & back on so it connects to the one in the garage.
  17. Aug 8, 2025 at 1:56 PM
    nags
    nags New Member
    Very common issue when there's too much overlap.
  18. Aug 8, 2025 at 2:01 PM
    e30cabrio
    It's odd, there is still "full "bars" and it was over 60Mbps either way, it just doesn't like when it's on a router further away. (we're talking maybe a 10 foot difference, the one it's on when I go out there is in my office which is in the front of the house, next to the driveway.
    Easy enough to turn wifi off before I go out, easier than what I had been doing, stringing a CAT6 from the garage router to the laptop.
    Mdl and nags like this.
  19. Aug 8, 2025 at 2:05 PM
    nags
    nags New Member
    Gotta get multiple access points wired up and get away from mesh and have that good good WiFi at all times. I've got a full Unifi setup here. I love it.
    Danimal86, Mdl and centex like this.
  20. Aug 8, 2025 at 2:10 PM
    e30cabrio
    I can stream 4K everywhere, (numerous streams) I can have 3 games, a movie, my Wife is upstairs streaming Netflix, kids have been here all summer (when I say kids I am talking 33-40 years old, at least 1 and their spouse) they are streaming playing PS5 etc & the Wife has three iPads with Poshmark shows on each 24-7 it seems like.
    The only time I have had an issue since I got the Mesh was with this. HPT is a brat.
    https://www.tp-link.com/us/deco-mesh-wifi/product-family/deco-x90/
    I have Gigabit & get it, this is the system, I have 5 units all over the 2700 sq ft house & .5 acre lot.
  21. Aug 8, 2025 at 2:18 PM
    nags
    nags New Member
    33-40 kids?!
    Wynnded likes this.
  22. Aug 8, 2025 at 2:19 PM
    e30cabrio
    years old, so not so much kids
    lol
  23. Aug 8, 2025 at 2:20 PM
    nags
    nags New Member
    Oh, damn. I thought y'all were running some crazy day care or something.
  24. Aug 8, 2025 at 2:21 PM
    e30cabrio
    I need to in order to pay for all these motors!
  25. Aug 8, 2025 at 2:38 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    SWEET!!! Always a good feeling when you find out the issue and get her going.
  26. Aug 8, 2025 at 3:45 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You could have them all scrubbing parts! :rofl:
  27. Aug 8, 2025 at 4:53 PM
    e30cabrio
    Took a 50 mile drive, at speed on the freeway IATs are +3-5 of ambient (at the MAF, I know) lol
    It feels good but the transmission isn't dropping down and allowing normal passing when going 70 & needing to pass an asshat in the passing lane at SIXTY FUCKING 5. GAAAa
    Do you guys think it's a learning thing or something else?
    M3Tundra-JK and mustang67408 like this.
  28. Aug 8, 2025 at 5:11 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Learning will take a bit or at least mine does.
  29. Aug 8, 2025 at 5:44 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Was it tuned to hold lock-up longer like the the guys that tow heavier things like theirs to? Honestly, I like mine stock, just a little extra push on the pedal and it unlocks giving me just enough extra RPMs to do what's needed; and I'm never likely to tow anything of significance anyway.
  30. Aug 8, 2025 at 6:01 PM
    e30cabrio
    I doubt there is any trans tune but sniv would need to answer that.
