  1. Aug 8, 2025 at 5:51 AM
    martiartisan
    martiartisan New Member
    North Texas
    2020 Tundra DC, 2006 Tundra Crew Cab
    Adv fiberglass, king suspension, cbi armor, RLD Cap
    I did use the front seal and noticed very minor gaps on the low points of the bed rails. I don’t think water will get in unless it’s going directly from the side. I was thinking about maybe filling the low spots of the bed rail caps with foam to fill the gaps if it did wind up leaking
    Boneskull420 and BR73 like this.
  2. Aug 8, 2025 at 6:24 AM
    Bham TRD
    Bham TRD New Member
    Birmingham, AL
    2017 Tundra Platinum 4WD CrewMax
    Did the rear differential breather mod yesterday, for anyone who hasn’t done it, don’t overlook it!
    I don’t know what previous owners did with the truck, but my vent was completely stopped up. Hard to tell if it was rust of dirt or both I got out.
    Fortunately, no axle seal damage I’m aware of, I changed the diff fluid recently, it looked great.
    But there’s no question a problem was coming, I’m honestly shocked it hadn’t already damaged something as that hot air expanded and had no where to go.
    Maybe it had enough force to squeeze by the debris that was clogging the breather, more than I could do by just blowing on it, but I couldn’t blow through it. I got a lot of debris out of that thing.
    Really don’t have to buy a new breather, fits the 5/16” line perfectly. Even mine that was clogged up, freed up when I twisted it back and forth, blew through it, and hit it with brake cleaner, good as new now. Opens when I blow, closes when I try to suck air.
    Just get that thing cleaned and relocated, too cheap and simple to avoid the expensive damage.
    This rig spent time up North, while the front should be fine, I will be checking it too, just to make sure it’s not rusted up and possibly causing an issue.
    woods, 23Tundy, Boneskull420 and 2 others like this.
  3. Aug 8, 2025 at 6:57 AM
    martiartisan
    North Texas
    What are your thoughts on this so far? It is on my list of things to do
  4. Aug 8, 2025 at 7:12 AM
    bigmace
    bigmace New Member
    Oregon
    2021 Silver Tundra Limited / 2019 Black Sequoia SR5
    Pretty much exactly what I ordered. Should all be here Monday. Will need to get the same for my wife's 2019 Sequoia, but she still has one more dealership oil change.
    BR73[QUOTED] likes this.
  5. Aug 8, 2025 at 7:17 AM
    bigmace
    bigmace New Member
    Oregon
    Was able to get my bed helper step installed though. Now I dont need to get a running jump start to get in!
    Just decided to cut the old bracket instead of trying take the bumper apart.
    rdiddy5, woods, 23Tundy and 7 others like this.
  6. Aug 8, 2025 at 8:36 AM
    Bham TRD
    Bham TRD New Member
    Birmingham, AL
    I need to do this as well. I’m just gonna cut my bracket too. Maybe it make sense if I had instructions to read, but how does it actually attach to the truck once the bracket is cut?
  7. Aug 8, 2025 at 9:26 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Do it! I recommend it.
    Stronger winds comes out of the vents to keep the interior cool or warm. I’m really happy with it.
  8. Aug 8, 2025 at 9:34 AM
    bigmace
    bigmace New Member
    Oregon
    You unbolt a couple of the bumper bolts (actual metal bumper, not cover) and then thread those bolts through the mounting bracket back to the bumper.
  9. Aug 8, 2025 at 9:36 AM
    mustang67408
    Victor
    Hot dry place in Nevada
    Here's the rough draft version...I have a bed cover not a camper shell, but do want the shell eventually
    Works like a champ with the magnet, and if the magnet doesn't work, I can bolt it to the plate if needed..
    Clears the bed cover by about 2".
    The cab doesn't seem to block the signal, my radio and phone both hooked up right away..
    You can put it in the bed anywhere as long as you have enough wire.
    BlueRibbon4x4, 23Tundy, ATV25 and 3 others like this.
  10. Aug 8, 2025 at 9:37 AM
    martiartisan
    North Texas
    With the increase in airflow do you feel like it’s noticeably louder?
    Y0TA PR0[QUOTED] likes this.
  11. Aug 8, 2025 at 9:48 AM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    No sir not at all. The increased airflow at full blast makes more noise then the blower lol.
  12. Aug 8, 2025 at 11:39 AM
    martiartisan
    North Texas
    How are these lights holding? stumbled upon these in my local HF. The price is very temptin
    woods, Boneskull420 and BR73 like this.
  13. Aug 8, 2025 at 2:33 PM
    French Avocado
    Utah / Wyo
    The 2020 hit 20,000 today
    GAknight, Terndrerrr, Ace96 and 20 others like this.
  14. Aug 8, 2025 at 2:40 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    She doesn't even have hair on her yet! :anonymous:
  15. Aug 8, 2025 at 2:43 PM
    RobertD
    Robert
    DFW, Texas
    I rolled 70k driving home last night.
    Warning is for oil change which I'm hoping to knock out tomorrow morning.
  16. Aug 8, 2025 at 2:54 PM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    I did the mouse-proofing today. I got the cowling off fine but ran into a snag with the JB Weld. Maybe because it’s 92 degrees, but 3 hours after mixing, the stuff was still soupy. I decided to use screws instead. One corner I did with JBWeld but it was dripping off, even at 4 hours. It made a real mess. Screws work much better.
    woods, Tripleconpanna and PKFan like this.
  17. Aug 8, 2025 at 3:19 PM
    SAGE63
    San Diego County
    Damn you dont drive that much
  18. Aug 8, 2025 at 3:23 PM
    SAGE63
    San Diego County
    Got the Solid Offroad Transmission mount installed and new Brakes, Stillen drilled/slotted with R1 ceramic pads...
  19. Aug 8, 2025 at 3:38 PM
    AZBoatHauler
    So.Arizona
  20. Aug 8, 2025 at 4:25 PM
    Fergie
    Fergie New Member
    Mouse proofing? Can you expand on this, please? Or point me to a link to read up on it?
    Boneskull420 likes this.
  21. Aug 8, 2025 at 4:48 PM
    19_Sr5_XSP
    19_Sr5_XSP New Member
    2019 Sr5 XSP
    None for now
    Wrapped my grill....I have a post
    And then today I de-badged my doors
  22. Aug 8, 2025 at 4:52 PM
    Tundra2n3
    Tundra2n3 2.5 Gen
    2015 Tundra DC SR5 TSS Off Road V8 5.7L 4x4
    Installed new license plate lights. I called Rough Country to get replacements and the customer service guy straight up said to get different lights, lots of them are cheaper and better. Got some Rugged Ridge & hopefully the quick disconnect is less of a PITA in the future.
    BR73 and bulldog93 like this.
  23. Aug 8, 2025 at 5:07 PM
    Get the MotivX kit.
    bulldog93, Boneskull420 and BR73 like this.
  24. Aug 8, 2025 at 5:29 PM
    French Avocado
    Utah / Wyo
    Still put majority of miles on the 2008
  25. Aug 8, 2025 at 6:24 PM
    PKFan
    2018 Inferno! DC SR5 4x4
    This is what several of us have done.
  26. Aug 8, 2025 at 7:02 PM
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    Out with the old, in with the new
  27. Aug 8, 2025 at 7:05 PM
    centex
    centex New Member
    Been in England for a week riding trains and it was so nice to come home and crank the tundra and listen to that SPD sing. It sounds so good.
    rdiddy5, BR73, Tripleconpanna and 4 others like this.
  28. Aug 8, 2025 at 7:11 PM
    Boneskull420
    Boneskull420 God loving,Tundra driving,rednek custom joker!
    Mark
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    Looks sweet
  29. Aug 8, 2025 at 7:15 PM
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    It really does! Has such a good tone. Not obnoxious either
    Sounds sweet too. Definitely very well made
  30. Aug 8, 2025 at 7:26 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Is this a 100% diy bolt on kit?
    ATV25 and Tripleconpanna like this.
