Westcott Collar lift with TRD/ SHOCKS
Discussion in 'Suspension' started by Dot1Tundra, Aug 7, 2025.
  1. Aug 7, 2025 at 9:49 AM
    Dot1Tundra
    Dot1Tundra [OP] New Member
    Hey all,
    Just purchased the westcott designs collar lift with the TRD shocks for my 2024 LIMITED OFF ROAD (non-Hybrid). I am a bit confused on running the top Shim or not. For anyone that has done this lift, did you use top shims? Truck is mainly driven on pavement with moderate off-roading every once in a while. just looking to for a lift to clear 35s and better stance, don't really want to compromise drive quality much. I would appreciate the input.
  2. Aug 7, 2025 at 4:23 PM
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    I have a 2024 Platinum non-Hybrid/non-TRD and installed the Westcott 3/1 with the silver CV axles and running 37" tires. I did not install the top shims...no specific reason. Some people use the shims and some don't. I really like the way it drives and truly believe they should have come that way from the factory.
  3. Aug 7, 2025 at 9:25 PM
    Dot1Tundra
    Thanx for the Reply man. your truck looks great. I am just trying to avoid having to put them on then have to take them off and endup paying twice for alignment and install.
    ramnj likes this.
  4. Aug 10, 2025 at 7:03 AM
    dark_knight_sig
    dark_knight_sig New Member
    2023 Toyota Tundra SR5
    https://youtu.be/UJqq9N5sCEQ?si=F7DjaBS9Vo5cOAJp
    This video should help answer your question. If I remember right I think the front shims had his front end a little higher than the rear. Guess it depends if you want to keep some rake. He also has a good video on the Fox 2.5s where he compares them to the wescott trd lift.
    Tundrastruck91 and ramnj like this.
  5. Aug 23, 2025 at 7:10 PM
    Dot1Tundra
    i know for sure the the Washer circled in red is for the Front bump Stop spacer to limit travel, but the yellow washer I am not sure where it goes. May be for the top of the rear shocks. I have watched that video 10 times. He does mention about the front bump stop spacer washer, but nothing about where the other washer would go.
