Alternator
Discussion in '2.5 Gen Tundras (2014-2021)' started by mrast3rd, Aug 6, 2025.
  1. Aug 6, 2025 at 5:10 PM
    mrast3rd
    mrast3rd [OP] New Member
    William
    2021 TRDPRO
    Tundra dudes
    Just hit 100K miles on my 2021 TRDPro. Plugs and serpentine belts along with fluids.
    How long are original alternators and water pumps lasting. Thanks
  2. Aug 6, 2025 at 5:27 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    from what I've seen the water pump goes out earlier than expected on the 2.5 gen, I think my brother's went out at 120k
    Alternator a long time though; mine has 270k on it and hasn't failed yet (knock on wood :rofl:)
    mrast3rd[QUOTED][OP] likes this.
  3. Aug 6, 2025 at 5:29 PM
    mrast3rd
    William
    2021 TRDPRO
    Thanks! Im leaning towards replacing then pump and coolant and letting then alt ride a little longer.
  4. Aug 6, 2025 at 5:30 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    By all accounts alternator is an annoying job so id avoid it as long as I can lol
    mrast3rd[OP] likes this.
  5. Aug 6, 2025 at 5:36 PM
    joseph_womack
    Joe
    Louisiana
    that would insane to replace the alternator at low mileage; its a toyota, everythings generally lasts a long time. You don't need to throw parts at it to just throw parts at it you know?
  6. Aug 6, 2025 at 5:44 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Where have you seen the water pump goes out earlier on 2.5 gens? 07-21 have the same water pump (2 and 2.5 gen). No sense in changing a part that’s currently functioning for no reason. You could just as likely install a new pump that fails in 100 miles.
  7. Aug 6, 2025 at 5:50 PM
    joseph_womack
    Joe
    Louisiana
    I agree, I wouldn't recommend changing it to just change it; but I've seen a couple cases personally where the pump fails what would seem like earlier than usual on the 5.7. Happened on my brothers truck and the place he took it to said that its common, we haven't seen many at my shop though
  8. Aug 6, 2025 at 6:01 PM
    mrast3rd
    William
    2021 TRDPRO
    Appreciate it guys!
  9. Aug 6, 2025 at 6:28 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    2nd gen
    Water pump about 250k, but wait until it starts leaking to replace it.. if you change your own oil, you will notice the red/pink stream on the front of the block...
    Alternator I'm at 317k so far, so good
  10. Aug 7, 2025 at 3:44 AM
    mrast3rd
    William
    2021 TRDPRO
    Thanks
  11. Aug 7, 2025 at 5:03 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Here's my regular Public Service Announcement (PSA) regarding alternators in general and Toyota alternators specifically.
    There is a simple wear part inside the alternator: the brushes. This is less than a $20.00 part. The alternator is serviceable. You can pull the cover off the alternator, CAREFULLY remove the two small screws that hold the brushes in place, pop the brushes out, pop the replacement set of brushes in, reinstall the two small screws, put the cover back on and you're good to go. Full disclosure: my 1997 T-100 truck with 277,000 miles has the original alternator. Though I have replaced the brushes twice (last time out of convenience as I had to replace a belt so I was already halfway there).
    Note: Toyota identifies the alternator brushes as: Holder Ass, Alternator Brush. Or some very close version of that.
    In general the whole "industry" alternator instruction "you need a new alternator AND you need to pay us a core charge" is a huge scam. You can save yourself big money by being informed and making decisions accordingly.
    Pic of used/worn alternator brushes for reference:
  12. Aug 7, 2025 at 5:50 AM
    mrast3rd
    William
    2021 TRDPRO
    Thanks for sharing.
  13. Aug 7, 2025 at 6:31 AM
    yakeng
    yakeng 3URFE Apologist
    My 2020's alternator went bad, but it wasn't the brushes, it was the bearings. Anyway, I bought an OEM replacement and held onto the original, going to rebuild it and if/when our other goes out, just swap it.
    It is an absolute PITA to replace though.
  14. Aug 7, 2025 at 6:32 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Had to do my pump at around 75k
    joseph_womack likes this.
