Firewall breach hybrid and 12v points
Discussion in '3rd Gen Tundras (2022+)' started by Sacul, Mar 25, 2025.
  1. Mar 25, 2025 at 12:50 PM
    Sacul
    Sacul [OP] New Member
    2024 Tundra Limited TRD
    Nothing yet
    If you have a hybrid and have run switches/harnesses
    Where are you breaching the firewall?
    AND are there any 12v hot points so I don’t have to run my harness all the way to the battery under the rear seat?
    Thanks in advance homies :cheers:
    PS: I tried to search this sorry if it has already posted.
  2. Mar 25, 2025 at 1:05 PM
    Sacul
    Nothing yet
    I searched again with different wording and am now finding several posts. I’ll keep this up and try to answer my own questions or this can be deleted
    teab likes this.
  3. Mar 25, 2025 at 6:15 PM
    bailey bulldog
    bailey bulldog New Member
    Post what your best solution was.
  4. Mar 25, 2025 at 7:07 PM
    lapoolboy
    lapoolboy New Member
    There is a hot lug in the passenger side fuse box. You can go through the firewall on driver's side - there is a blank grommet already there.
  5. Mar 26, 2025 at 8:22 AM
    Sacul
    Nothing yet
    I did find that grommet. Thanks
  6. Mar 26, 2025 at 8:35 AM
    Sacul
    Nothing yet
    I spoke with Mitchell over at Blaze Off-road. Super knowledgeable. He pointed me in the direction of a SDHQ harness, specifically made for the 3rd gen hybrid, that brings 12v power up to the engine bay
    https://blazeoffroad.com/products/2022-2023-tundra-hybrid-sdhq-built-under-hood-power-solution-kit
    set up with a fuse or breaker to isolate the power from your factory electrical system and run a Garmin power switch for all your aftermarket electronic gear
    Seems simple enough and beefy. Price is a bit wild but I’m pretty sure this will be the route I’m going.
    here’s the link for the install
    https://cdn.shopify.com/s/files/1/2...K70_-_INSTALL_INSTRUCTIONS_1.pdf?v=1710544690
    Tundrastruck91 likes this.
  7. Mar 26, 2025 at 2:58 PM
    joshua32
    joshua32 New Member
    2024 Celestial Silver Platinum HV TRD OR
    Punched through the driver's side grommet just behind the left side of the brake pedal. Used the kit that came with the Rave Offroad Hidden ARB Twin Compressor kit. Ran 4 ga from the battery to the bus bar.
    AF555 and Sacul[OP] like this.
  8. Mar 26, 2025 at 4:22 PM
    Sacul
    Nothing yet
    Nice. Clean too
  9. Aug 6, 2025 at 9:33 AM
    NimbusDog
    NimbusDog New Member
    Tampa, FL
    2022 Tundra
    Holy shit that price...Hard pass.
  10. Aug 6, 2025 at 10:10 AM
    kamaaina1
    kamaaina1 New Member
    2024 Tundra TRD PRO
    Sacul[OP] likes this.
  11. Aug 6, 2025 at 4:44 PM
    6rian
    6rian New Member
    AF555, Sacul[OP] and FrenchToasty like this.
