Twisted plastic under gear shift
Discussion in '2.5 Gen Tundras (2014-2021)' started by Amarman, May 3, 2025.
  1. May 3, 2025 at 7:59 AM
    Amarman
    Amarman [OP] New Member
    Please help, the plastic under the gear shift has twisted and it is so annoying. It gets caught and we have to force the shift to park and sometimes the key won’t come out. I need to smooth it out but I can’t figure out how. I’ve seen how to remove the plastic cover but not how to remove the hard plastic plate so I can’t tell if that’s permanent or not.
  2. May 3, 2025 at 9:38 AM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Sawzall... just kidding, time for replacement of part.
  3. May 3, 2025 at 10:14 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I wonder if you could remover the plastic piece after taking off the shifter console and reform that piece with a heat gun on a flat surface
  4. May 3, 2025 at 12:17 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    See this thread that shows where to pry up and remove the console piece around shifter knob. Then you should be able to look at the piece that is messed up to see what can be done. https://www.tundras.com/threads/removal-of-shifter-trim.24458/
  5. May 4, 2025 at 1:56 PM
    Amarman
    So I got the top pieces off but can’t figure out how to take the clear plastic piece off without cracking it. One side has clips but not the side closest to the driver seat (and I did crack it a little trying)….and I can see that one of the black plastic sheets is ripped…any clue what that is called so I can order a new one? I’ve literally never worked on a car before so I’m winging it here
  6. May 4, 2025 at 2:09 PM
    bfunke
    bfunke Tundra Curmudgeon
    My guess is food or drink spills caused it to stick. Only way to fix is new part.
  7. Aug 6, 2025 at 10:21 AM
    Scotty3625
    Scotty3625 New Member
    I've been scouring to find someone talking about this piece. Can anyone tell me what it's actually called? I have a very similar issue and likely need a new one but I don't have a clue what to look for online. Any help is appreciated.
  8. Aug 6, 2025 at 1:28 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
