Talons Whole Skid Plate install pics with OEM tow hooks
Discussion in '3rd Gen Tundras (2022+)' started by Bucko07, Jun 13, 2025.
  1. Jun 13, 2025 at 11:18 AM
    Bucko07
    Bucko07 [OP] New Member
    2025 Tundra Limited
    OEM Tow Hooks Dual wireless charger Tundra rear/front badging and TRD badge
    Over all the install was easy. The first plate that covers the radiator needed to have the corners ground and cut off in order to fit around the tow hook brackets. Everthing else went as planned. Hard to take photos while getting it installed.
    MAC25Tundra, TFTJ, TheDo114 and 3 others like this.
  2. Jun 13, 2025 at 11:41 AM
    RobertD
    Robert
    DFW, Texas
    Have you let @Talon2006 know that you had issues?? He is normally very responsive and aims to have a product without issues.
  3. Jun 13, 2025 at 6:55 PM
    Bucko07
    2025 Tundra Limited
    Nope…I didn’t think of it but it looks like you tagged him so it should be good to go…thanks
    RobertD likes this.
  4. Jun 14, 2025 at 5:37 PM
    Talon2006
    Talon2006 New Member Vendor
    I think you are the first to install it with OEM toe hooks. Is that new for 2025?
    Looks like I need to make a small adjustment, and send this to my wife.
    Lord Helmet, llm2521 and RobertD like this.
  5. Jun 14, 2025 at 6:34 PM
    Bucko07
    2025 Tundra Limited
    Yes this is 2025. These are the OEM hooks but they don’t come as a standard option….I had to request them before I bought it and they were installed at the dealership.
    RobertD and Talon2006[QUOTED] like this.
  6. Jun 14, 2025 at 9:46 PM
    TFTJ
    TFTJ New Member
    Those look very well done. Did you happen to grab a photo of the oil filter location through the opening?
    Talon2006 likes this.
  7. Jun 16, 2025 at 6:08 AM
    Talon2006
  8. Aug 6, 2025 at 7:16 AM
    llm2521
    llm2521 New Member
    Dfw
    25 limited tundra
    Boring af for now slowly working through the pains
  9. Aug 6, 2025 at 7:54 AM
    grnwdjsn
    grnwdjsn New Member
    2023 Tundra Limited TRD Offroad
    llm2521[QUOTED] likes this.
  10. Aug 6, 2025 at 7:59 AM
    grnwdjsn
    grnwdjsn New Member
    Add a rubber tube to the oil filter drain. It is a life saver. I just jam a rubber stopper in it and tuck it up in the plate when not using. I left enough hose to come out the Talon during oil changes. My arm pretty much fills up the square hole. Thanks again to the brilliant Toyota engineer who placed the oil filter!! Jackass! I also added a Fumoto drain valve and use the supplied hose for it as well. This keeps things nice and clean.
