2016 rack and pinion hardlines
Discussion in 'Suspension' started by Aprince101, Aug 5, 2025.
  1. Aug 5, 2025 at 11:25 PM
    Aprince101
    Aprince101 [OP] New Member
    2016 tundra
    Was losing power steering fluid so went under the truck and see it leaking out of this fitting from the steering rack in pic 1 Where the hardline goes into the nut.I think I found the hose part but can’t find anywhere where you can buy only that hose or the fitting. Does the entire rack need to be replaced or can you just change the hose. Is it possible to unscrew that hardline and put a new oring or something.feel like I looked everywhere for a “right turn pressure tube” and can’t find anything for a 2016 or similar. Pic 2 and 3 shows part that I think it is
