35x12.5 Tires on Stock 2025 Toyota Tundra TRD Pro
Discussion in 'Wheels & Tires' started by kylejbruce, Aug 4, 2025.
  1. Aug 4, 2025 at 8:56 PM
    kylejbruce
    kylejbruce [OP] New Member
    Kyle
    N/A
    Will 35x12.5 tires fit on a stock 2025 Toyota Tundra TRD Pro?
  2. Aug 5, 2025 at 3:37 AM
    SnowToy
    SnowToy New Member
    2023 Tundra TRD Pro - build in the works...
    295/70/18 Duratracs - more mods being researched...
    I'm running 295/70/18's ( 34.4" OD) and they fit without any rubbing... Jumping to 37's once the lift is on.
  3. Aug 5, 2025 at 8:49 AM
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    OP
    Yes they will fit. You may need to pin back the front mud flap using a zip tie, but an easy fix that takes 5 minutes
  4. Aug 5, 2025 at 7:02 PM
    Hank44444
    Hank44444 New Member
    24 Tundra TRD Pro
    Yes, I can confirm they fit. 35x12.5x20 on mine. They did rub, but I put the Westcott Tire Clearance kit, which fit my ARK mid Mudflaps perfectly.
  5. Aug 17, 2025 at 11:32 AM
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
