Toytec / Coachbuilder shackle add-on poly spring bushings
Discussion in 'Suspension' started by 2020_Tundra, Aug 4, 2025.
  1. Aug 4, 2025 at 6:23 PM
    2020_Tundra
    2020_Tundra [OP] New Member
    2020 MGM Platinum Tundra
    Do the ends of the metal center sleeve within the add on poly bushing get pinched in the shackle when you insert the bolt through the poly bushing and tighten it? Or does the metal center sleeve have end play and is allowed to spin on the bolt?
