General Supercharger Thread
  1. Aug 4, 2025 at 9:56 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    You should just drop it off @snivilous let him go through the thing
    Wynnded, bflooks, Mdl and 3 others like this.
  2. Aug 4, 2025 at 10:00 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I'm working on a teleportation device in my spare time.
    M3Tundra-JK and HulkSmurf14 like this.
  3. Aug 4, 2025 at 11:59 AM
    e30cabrio
    It's amazingly well packed is the positive. No way without cutting/ moving the washer fluid reservoir will this monster fit.
    armyoffoo and HulkSmurf14 like this.
  4. Aug 4, 2025 at 12:01 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I wonder if @snivilous can scan something up and one could print a "form-fitting" tank/reservoir around the new tank? That thing is YUGE!
  5. Aug 4, 2025 at 12:03 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Now that's a big brain idea I can get behind, Tundra specific oversized coolant tanks. That would be pretty sick! And I did just get a 5x10 sheet of aluminum and steel in today :D
    ZPhilip, Wynnded, M3Tundra-JK and 4 others like this.
  6. Aug 4, 2025 at 12:44 PM
    snivilous
    SW UT
    Where exactly are you guys putting bigger tanks? Looking in the engine bay there's no decent room. My three initial ideas are a tank that forms around the ECU area behind the intake box, or in front of the intake box but then you need to still access the steering reservoir and dip stick (plus usually where the catch can goes), and third is a dual tank setup where it fits where the windshield washer reservoir is and then relocate that as a custom tank behind the airbox.
    Granted the stock intercooler reservoir is tiny so wouldn't need much to get a lot more fluid, but I was hoping there was an "easy" way to have like a gallon or more in just the reservoir.
    HulkSmurf14 likes this.
  7. Aug 4, 2025 at 12:47 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    You could get an SDHQ washer reservoir like I have below, if the 4Gal would fits where the stock washer res is, that's a big box. Or work on the Lexus washer res like @Mdl is doing.
    Would it fit on the driver's side on a dual-compressor mount that sits above the fuse/relay box? Or is it too tall?
    You could always mount it elsewhere and keep the Maggy res as the fill port.
  8. Aug 4, 2025 at 12:52 PM
    e30cabrio
    The 1.5 gallon I got from Viktor shoehorned between the airbox & firewall.
    It's cap isn't vented (and broke) and I was getting a vacuum after filling the hole Viktor drilled because it was dribbling coolant.
  9. Aug 4, 2025 at 12:54 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Two options for folks not everyone wants a large tank some do. I’d say the multi tank unit is a solid option. We used to this for the cobras. Then then those that want a larger unit can do the large box maybe with a battery relocation or where army has his
    armyoffoo, Mdl, snivilous[OP] and 2 others like this.
  10. Aug 4, 2025 at 2:04 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    HulkSmurf14, e30cabrio and Mdl like this.
  11. Aug 4, 2025 at 2:28 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Using the LC washer fluid reservoir, as a washer fluid reservoir, is a great idea. Especially if it keeps factory sensor/computers happy. That would open up the entire front area for a ram air type of setup and then make space for whatever else on top of the inner fender. Just a thought. I know a lot of you are already opening up the inner fender to get to the air, but doing a more open Stillen front intake type of deal, directly into a box could be a space saver and add a bit of air flow, too. Selfishly, I'm hoping someone says it's not a horrible idea.
    HulkSmurf14, e30cabrio and Wynnded like this.
  12. Aug 4, 2025 at 2:37 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The LC fits in driver side fender. Just gotta fab it up. I'll try and mock it up again and hog out the filler neck in fender. A prospeed style 2.5 gallon tank fits where the washer bottle is could be a little bigger. Has the steering pump attachment. I've even seen a few 3gal fuel cells that are about the same size for $82.
    HulkSmurf14 and e30cabrio like this.
  13. Aug 4, 2025 at 2:38 PM
    e30cabrio
    Sooooooo
    sniv looked at my log, I have 0 volts at the MAF wheeeee.
    I have a sub 20 mile OEM MAF, a sub 2k mile OEM MAF, a sub 1k mile TK MAF & an old from my '10 Tundra JET POS that was in the truck for 20 seconds on a Bully Dog tune. Only the JET gets any voltage sporadically & that's low.
    The connector came back from the 1st motor minus its "fastner pin" and has been on & off more MAFs then I can remember I pushed all the pins down without change, I ordered a new connector with early am delivery so will solder it in in teh morning.
    https://www.amazon.com/Sensor-Connector-Tiltmaster-4Runner-Pontiac/dp/B0DT6XSCPQ?crid=X47WE78IZWRI&dib=eyJ2IjoiMSJ9.ZUNnfiEeEgTSj3e9X85qNV_iOi9HqGWK4Ja5CkLGB0nnUYAAYQ8ayk6JaCDJqH3h0xgofWrxSVScb812itTf9_GVWVChaeY3AmhJKs_FZGXqjdRSn0U1xRMBrdnzSdAb_A8ypiMvHhQMIXOGLe8SDOBMNE-3yh21sLMwAb5g3xGWyDSOzlDPKnzgyXmIcf5TDJUjfGBVJ_j-CyXTLgam_AO6M3yNXbVhPfjtM0q7h9o.Ehry5dHGJHrgg7hAfAcHvnt8xUY88Xvg8TNaQ5NHaGE&dib_tag=se&keywords=2007-2021+Toyota+Tundra+Mass+Air+Flow+%28MAF%29+Sensor+Connector&qid=1754342760&sprefix=2007-2021+toyota+tundra+mass+air+flow+maf+sensor+connector+%2Caps%2C256&sr=8-1
  14. Aug 4, 2025 at 2:50 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I suspect this is a first motor swap installer issue? Isn't that when they were chasing electrical issues? If the harness doesn't work, testing wires to the ECU?
  15. Aug 4, 2025 at 2:53 PM
    e30cabrio
    Yes, they fucked up the connector at the ECU & eventually fixed it.
    Mdl and HulkSmurf14 like this.
  16. Aug 4, 2025 at 3:04 PM
    HulkSmurf14
    2014 Tundra Limited
    "...fixed..."
    mustang67408 likes this.
  17. Aug 4, 2025 at 3:55 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    And wasn't the maf fried?
