Ugh. I’ve got a noise. Still.
Discussion in '1st Gen Tundras (2000-2006)' started by Gnarbrah, Aug 3, 2025.
  1. Aug 4, 2025 at 8:16 AM
    Not just spin, but jiggle them. Fondle those little bastards. If there's any play, scratchiness, motion, it's time to replace.
    And don't forget: The fan/clutch is mounted to a round plate that contains a bearing also, and it's not uncommon for that bracket to develop noise. But if your clutch is working as expected, it may not be blatantly obvious, because a properly functioning fan clutch would produce enough resistance that the fan shouldn't be able to spin a full rotation on its own.
    2mchfun likes this.
  2. Aug 4, 2025 at 8:26 AM
    2mchfun
    Does this noise seem to come and go with temperature differences? In other words cold starts vs. warm starts or time delays between off and start? Like did oil circulate recently or not or is something changing size based on temps?
  3. Aug 4, 2025 at 9:31 AM
    Gnarbrah
    Gnarbrah [OP] New Member
    2005 Tundra 4WD Double Cab V8
    3" Toytech Lift, Total Chaos UCAs
    Doing the timing belt I replaced:
    Water pump
    Timing idler
    Timing tensioner pulley
    Serp tensioner
    Serp idler
    Fan bracket
    So those should all be good. Only thing that spin that aren’t new are:
    Power steering pump
    Alternator
    AC compressor
    Actual fan clutch
  4. Aug 4, 2025 at 9:32 AM
    Gnarbrah
    Not that I can tell. I’ll start making note of when it happens
    2mchfun[QUOTED] likes this.
  5. Aug 4, 2025 at 9:34 AM
    Gnarbrah
    I’m really hoping it is something to do with the fan. It’s sort of not too much of a pain to get to!
  6. Aug 4, 2025 at 9:35 AM
    Not a pain to get to. But also, you have to tear down a LOT to replace that bracket. To the point I recommend anyone with 200k+ miles to replace it while doing the timing belt, with a new Aisin replacement. I have yet to see any easy solution to replace just the bearing/pulley.
  7. Aug 4, 2025 at 10:19 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Doesn't sound like it, but the intermittent nature and cold start only seems like it could be an SAI issue.
    When it makes the noise if you leave it running does it go away?
  8. Aug 4, 2025 at 1:17 PM
    Gnarbrah
    Yep. I almost didn’t replace the fan bracket but after seeing how much I had to do to get it off I went ahead and ordered a new one!
  9. Aug 4, 2025 at 1:18 PM
    Gnarbrah
    I’ve only let it run with the noise happening a couple times. One was that video I posted on page 1. I shut it off after I took the video. The second time it did stop by itself in just a couple of seconds.
    Next time it makes the noise I’ll let it run and see if it stops.
