What brand of fluid do you use in your differential and transfer case
Discussion in '2nd Gen Tundras (2007-2013)' started by bradleydavidgood, Aug 1, 2025.
  1. Aug 1, 2025 at 4:42 PM
    bradleydavidgood
    bradleydavidgood [OP] New Member
    2013 Tundra 4.6L Double Cab
    If you use something other than Toyota, what do you use?
    For the differentials:
    The manual specifies LT 75W-85 GL-5 for my 2013 Tundra 4.6L DW 4WD.
    I saw a video and he was using Red Line. I like Red Line.
    https://www.amazon.com/dp/B000J3G8KE
    For the transfer case:
    The manual specifies SAE 75W-90 GL-4 or GL-5
    Redline has this:
    https://a.co/d/3KfQBaK
    And another video I saw the guy was using Ravenol with a handy tube dispenser built in:
    https://www.amazon.com/dp/B00QL31M3O
    But interested in other opinions.
    Thanks!
  2. Aug 1, 2025 at 4:47 PM
    Jaywhy
    Jaywhy Old Member
    Jeff
    2016 SW TRD Pro CM
    Used ravenol for a while, then switch some 10s of thousands of miles ago to Valvoline. It comes in squeezy packs so it's easy to fill. Truck hasn't blown up yet.
  3. Aug 1, 2025 at 5:30 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Redline in the diffs and Ravenol in the transfer case.
  4. Aug 1, 2025 at 8:06 PM
    bradleydavidgood
    WILLINH likes this.
  5. Aug 1, 2025 at 8:07 PM
    bradleydavidgood
    Thanks!
  6. Aug 1, 2025 at 9:09 PM
    blenton
    blenton New Member
    Lots of good options for quality synthetics oils. IME, changing the fluid regularly is as important - or more-so - than what type of fluid you use. I had a limited slip installed at a friend’s shop earlier this year at 220k, replacing a worn out Auburn with 140k miles on it but still setup with original bearings. My friend let me inspect all the parts with him as we tore it down; he laughed at how good everything looked for such high miles with how much towing and hauling I do. He said it looked like it had maybe 50k miles on it, and attributed that 100% to regular fluid changes every 30k miles (or less).
    I used Mobil 1 for the first 80k miles, Castrol and Valvoline Dino oils for a while (per Auburns requirements), more Mobil 1, High Performance Lubricants Diff Life, Amsoil, and finally Mobil Delvac after some break in miles with the Speedmaster limited slip. All have been 75w90 except the Dino oil that was 80w90 in the rear diff. All have protected well as expected. I have some Redline to go in the ‘21 since the transfer case changed in 2014 and calls for a straight 75w, though the dealership uses 75w90 unless it’s a warranty job.
  7. Aug 2, 2025 at 3:48 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Ravenol here
    what is it about ravenol that stinks so bad?
    Getting some on you is like having a stink tattoo for 3days
  8. Aug 2, 2025 at 3:54 AM
    bradleydavidgood
    Thank you!
    So if my diffs call for 75W-85, can I use 75w90 no problem?
  9. Aug 2, 2025 at 3:55 AM
    bradleydavidgood
    It's probably skunk scent which is highly lubricative.
  10. Aug 2, 2025 at 4:01 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    awarding 750 internet credits for using the word
    “Lubricative”
  11. Aug 2, 2025 at 4:19 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    A member posted this.
    I used 75-90 synthetic in the differentials and transfer case. I have no problem with it at all. Also my Toyota dealer doesn’t even stock 75w.
    Jaywhy likes this.
  12. Aug 2, 2025 at 6:00 AM
    bradleydavidgood
    Awesome thank you!
  13. Aug 2, 2025 at 6:14 AM
    bradleydavidgood
    WILLINH likes this.
  14. Aug 2, 2025 at 6:23 AM
    Jaywhy
    Jaywhy Old Member
    Jeff
    2016 SW TRD Pro CM
    WILLINH likes this.
  15. Aug 2, 2025 at 7:27 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
  16. Aug 2, 2025 at 7:29 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
  17. Aug 2, 2025 at 7:46 AM
    bradleydavidgood
    Yay thank you!
  18. Aug 2, 2025 at 9:25 AM
    blenton
    blenton New Member
    Absolutely. 75w85 options are very limited; the Redline product you listed above is what’s going in my ‘21 but that’s just for fun. 75w90 is perfectly acceptable, more readily available, and cheaper.
  19. Aug 2, 2025 at 9:55 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    That’s what I used….definitely more cost effective than the alternatives.
    https://www.amazon.com/dp/B086R57CRP
  20. Aug 3, 2025 at 3:46 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    I used to use Redline. Now I use Valvoline.
    WILLINH and bradleydavidgood[OP] like this.
  21. Aug 4, 2025 at 10:29 AM
    nkyrental
    nkyrental New Member
    Kevin
    2022 Chevrolet Silverado 3.0 Duramax
    Royal Purple here. Expensive but it is a 100 % Polypropylene Glycol so it lasts forever. The stinking smell is the sulfurized additive used in gear oils.
    bradleydavidgood[OP] likes this.
