dumb question when changing oil
Discussion in '2.5 Gen Tundras (2014-2021)' started by Strider_0284, Aug 4, 2025.
  1. Aug 4, 2025 at 5:20 AM
    Strider_0284
    Strider_0284 [OP] New Member
    Manual states 7.9 qts for my 2017 5.7, How are you guys measuring .9 of a quart?
  2. Aug 4, 2025 at 5:23 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I put in 8 quarts. Start, idle 2 min. Shuts off. Wait couple mins, check dipstick. Add more if needed. I usually dont need to add more.
    8qts puts it lightly above the middle mark on the dipstick. Im perfectly fine with that. Not full and not low either.. never had isue doing it this way for years now.
  3. Aug 4, 2025 at 5:24 AM
    Mr Badwrench
    Mr Badwrench New Member
    I aim for between the dipstick high and low dots and call it a day. Between 7 and 8 quarts.
    NewImprovedRon likes this.
  4. Aug 4, 2025 at 5:33 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    That would be a quart minus 6.4 tablespoons... :D
  5. Aug 4, 2025 at 5:58 AM
    Ericsopa
    Ericsopa Old man and the sea
    ......or, put another way, 6 tablespoons minus 1.2 teaspoons.
  6. Aug 4, 2025 at 6:02 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    What particular brand of lubricant are we measuring?
    @Strider_0284
  7. Aug 4, 2025 at 6:21 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Most quarts of oil anymore have markings on the side that show the number of ounces in the bottle. 1 quart = 32 ounces X .9 = 28.8 ounces for .9 of a quart. Divide this by the seasonal gravitational pull and factor in the day of the week you are changing the oil.
    Tundra2n3 and Tripleconpanna like this.
  8. Aug 4, 2025 at 7:31 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    7.9 to 8.0 is just rounding.
    For me: 5.7L 3UR engine.
    I put in 8.4 quarts of Costco Kirkland brand 5W-30 from their 5 gallon jugs. I dump into the engine a full/new 5 quart jug. I have a 2nd jug with a piece of tape at 3.4 quarts. I fill it up to the mark. Then dump it into in the engine. Away I go.
  9. Aug 4, 2025 at 8:34 AM
    Tripleconpanna
    I would think viscosity would be more important than brand :notsure:
    hagrid[QUOTED] likes this.
  10. Aug 4, 2025 at 8:40 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I'll chalk that up to "lettin' the liquor do the thinkin".
  11. Aug 4, 2025 at 9:01 AM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    Mine is always less than 8 quarts, and is near full.
  12. Aug 4, 2025 at 9:10 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I buy 2 gallons of Amsoil, dump it in, and send it.
  13. Aug 4, 2025 at 9:39 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    So many different answers. I think OP is more confused now then before asking :rofl:
    Best answer OP is to check your years owners manual. My '18 says it's 8.5qt with the filter change and 7.9qt without the filter change.
    Google says:
    2017(your year)
    2018(my year)
    So best answer, check your manual.:thumbsup:
    Tripleconpanna likes this.
  14. Aug 4, 2025 at 9:40 AM
    AZBoatHauler
    So.Arizona
    I’ve always put in 8 and it’s never gone over the top dot on the dipstick. Usually about half way between the two…
  15. Aug 4, 2025 at 12:03 PM
    Strider_0284
    Yea checking my manual led me to post the question, I was wondering if people were measuring out .9 of a quart or dumping in 8 and calling it good. Thanks for all the replies guys
  16. Aug 4, 2025 at 12:29 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Yes and no, you can have a really cheap branded oil that’s the right viscosity but no additives for wear etc
  17. Aug 4, 2025 at 3:37 PM
    grayscale
    grayscale New Member
    DFW
    2013 Tundra CM TSS 4X4 5.7FFV
    Honestly, this conversation is always a black hole as it seems there were many variations and factors in the 5.7 and what was attached to it from 2007-2021. Best advice is I've seen is to start with 7qts and then just watch the dipstick as you put more in
  18. Aug 4, 2025 at 4:11 PM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    My 2021's manual calls for 8.5 quarts. I have found this brings it right to the full line. So I started using 8 qts. It's perfectly in the middle on the dipstick. So now I just toss in 8, double check, and roll
    AZBoatHauler likes this.
  19. Aug 4, 2025 at 4:26 PM
    Retired...finally
    I drive mine up on front ramps and get real close to 9 qts.
  20. Aug 4, 2025 at 6:44 PM
    assfister55
    assfister55 New Member
    Johnny
    Kremmling, Colorado
    '15 Tundra 1794
    6" zone lift. cold air intake. booger welded exhaust 35x12.5 R20 Fuels
    I just add oil 'til it overflows from the fill hole and call it a day :anonymous:
    Baja Mike likes this.
  21. Aug 4, 2025 at 7:39 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    I've always dumped in 8qts. Never had a problem. If there's too much it'll burn off. :D
    assfister55 likes this.
  22. Aug 4, 2025 at 9:24 PM
    Tripleconpanna
    I think you missed the sarcasm in that one... :anonymous:
    hagrid likes this.
