3rd gen trans temps
Discussion in '3rd Gen Tundras (2022+)' started by Codyw4.6, Jul 30, 2025.
  1. Jul 30, 2025 at 4:55 AM
    Codyw4.6
    Codyw4.6 [OP] New Member
    2025 sr 4x4
    What are you guys seeing avg trans temps? I run 194 while highway driving and 197-202 towing.
    Better than my 19 and 21 ( no real cooler) but still seems a little warm to me
  2. Jul 30, 2025 at 5:09 AM
    LowcountryDave
    LowcountryDave New Member
    ‘23 Limited TRD
    About the same for me. While towing or in 30+ minutes of traffic I'll see it jump up to 203 but haven't seen it get any higher.
    Codyw4.6[OP] likes this.
  3. Jul 30, 2025 at 9:04 AM
    tbird462002
    tbird462002 New Member
    2025 Tundra Limited TRD
    this is normal temp for all the new 10 speeds, if you start trying to run them too cold they will not shift right. The fluid is designed for this temp range, just make sure you flush it on a regular schedule
  4. Jul 30, 2025 at 9:09 AM
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    I have seen up to 210 powering up long upgrades, otherwise around 190-200 most of the time.
  5. Jul 30, 2025 at 9:10 AM
    6rian
    6rian New Member
    Normal. I reached 190 degrees on a 17 hr drive down to SoCal. Hit 200 climbing the mountains. Added a trans cooler since then and haven’t seen beyond 180 on a 90+ degree day.
  6. Jul 30, 2025 at 10:16 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    Normal.
  7. Jul 30, 2025 at 11:24 AM
    bowhuntercoop
    bowhuntercoop New Member
    2025 limited off road
    Yep perfectly normal as mentioned above. ATF+4 would get 225-240 in my drag truck after a pass and the fluid was still cherry red every 10k when I changed it even with 4wd 20psi boosted launches.
  8. Jul 30, 2025 at 1:14 PM
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum Windchill Pearl with AVS
    Pinned stat, on long rans like 100 non stop miles it can get to 165-170F, when get into city traffic it can reach 185-190. As soon as i get to HWay again it drops to 170 again. Outside temps are 85-92F all three times i monitored it.
    Yesterday was 95F and on my 25 HWay miles trip it reached 155F
    Woocawachie likes this.
  9. Jul 31, 2025 at 8:44 AM
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    Can you give step by step how to pin the thermostat on 22+ tundra? Trying to find where its at and can’t find it
  10. Jul 31, 2025 at 4:44 PM
    ElectricMan
    ElectricMan New Member
    I easily go into the red (within 10 seconds) while in reverse, pushing/towing my work trailer up my driveway (uphill). Design flaw?
  11. Jul 31, 2025 at 7:15 PM
    faltszy
    faltszy New Member
    Towing a travel trailer weighing around 4k on hwy, around 170 to 180 temp on a 104F weather outside. Going up the mountains the temp goes around 230 temp and sometimes 233.
  12. Jul 31, 2025 at 8:39 PM
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Highest I’ve seen was 225 going up some grades going out to Moab while hauling a dirtbike and tons of gear (90 degree ambient). Did a trip recently with less gear and only got up to 207 on mountain grades with 100 degree ambient temp. I regularly hit 190ish on my 25 minute commute bc of hills and red lights. I’ve been punting the drain n fill on my 66k mile trans that hasn’t been serviced yet. Keep ending up being busy on weekends
  13. Aug 1, 2025 at 7:57 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    I've seen temps around low 200's with normal driving, 224* is the highest with the thermostat pinned open while towing the Toy Hauler. I have an external cooler to put on, but started to think twice because I don't want that be the reason my warranty to get voided if I do have transmission problems.
  14. Aug 1, 2025 at 9:45 AM
    nkyrental
    nkyrental New Member
    Kevin
    2022 Chevrolet Silverado 3.0 Duramax
    Had a 2022 Silverado 3.0 diesel, trans temp was always around 190-210 even with the trans cooler. I believe the newer 10 speed solenoid acutators are more sensitive to moisture, so keeping this temp doesn't allow moisture entrainment in the fluid.
  15. Aug 1, 2025 at 10:21 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    And the thermostat doesn't open to the cooler until 195*.
    Here's a comparrison of the trans fluid I pulled out vs. new when I did my flush and fill a few weeks ago.
    22whatwedo and Woocawachie like this.
  16. Aug 2, 2025 at 4:09 PM
    JohnF4x4
    JohnF4x4 New Member
    US
  17. Aug 3, 2025 at 10:23 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Do you have a secondary cooler installed?
  18. Aug 3, 2025 at 10:25 AM
    JohnF4x4
    JohnF4x4 New Member
    US
    Nope
    ARB1977[QUOTED] likes this.
  19. Aug 5, 2025 at 8:14 PM
    mrlittlejohn
    mrlittlejohn New Member
    Michael
    2022 Toyota Tundra Limited
    I have been seeing 187-197 generally. My long tow I did to Virginia back in February was the 203. I was shocked, and was pulling a 24' mostly empty race ready car trailer. Probably 4500 #'s.
