Mid timing belt job - oil leaks? What to replace while in here
Discussion in '1st Gen Tundras (2000-2006)' started by inv3ctiv3, Aug 2, 2025.
  1. Aug 2, 2025 at 9:42 PM
    inv3ctiv3
    inv3ctiv3 [OP] New Member
    Jim Bob
    I’ve read the stickies and other threads I don’t have any questions about the timing belt job itself. My question is around common oil leaks on the 4.7 as my motor has a lot of build up and I wanna replace anything inner while it’s apart that I should. I got a crankshaft seal but that’s it so far. Looks like a lot of build up is around there and the oil filter housing.
    G_unit3000 likes this.
  2. Aug 2, 2025 at 9:52 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    G_unit3000 and inv3ctiv3[OP] like this.
  3. Aug 2, 2025 at 10:11 PM
    inv3ctiv3
    Jim Bob
    jerryallday[QUOTED] likes this.
  4. Aug 2, 2025 at 10:40 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Read on here to also do tensioner, pulley (is there more than one?), and radiator. I had a stealership do all that for me. Wallet much lighter afterwards....
  5. Aug 3, 2025 at 7:52 AM
    None of that looks fresh to me? Except for that's above the crank pulley/HB, which Jerry nailed already.
    You should really consider replacing both of your PCV hoses, and do your PCV valve if it hasn't been changed in the last 40k-50k miles.
  6. Aug 3, 2025 at 10:20 AM
    bfunke
    bfunke Tundra Curmudgeon
    In retrospect, I would have cleaned the engine before doing the TB so you can see if anything is actively leaking.
  7. Aug 3, 2025 at 11:55 AM
    inv3ctiv3
    Jim Bob
    yea that’s why I included that photo I need to order that stuff up. Also doing a new radiator and all the tensioners etc just was curious about oil seals I may be forgetting
    shifty`[QUOTED] likes this.
  8. Aug 3, 2025 at 1:34 PM
    I mean, 2006 is VVTi, so doing the cam seals is a bitch. Not sure about crank seal, haven't looked into it on my 2006.
  9. Aug 3, 2025 at 1:37 PM
    bfunke
    Crank seal is easy. If it’s leaking do it. Either use a seal puller of a small screw to pull it so you don’t scratch the crank or the seating surface.
