Just a bit more torque
Discussion in 'Performance and Tuning' started by Toyfever, Aug 1, 2025.
  1. Aug 1, 2025 at 5:18 PM
    Toyfever
    Toyfever [OP] New Member
    I know what I'm about to post isn't unique. Besides my intro this is my first post so here goes. I have a 2007 5.7L 2WD with an AFE pro dry S cold air intake and Corsa touring catback exhaust. I would like to get a bit more torque out of it but nothing crazy. The truck is very reliable and I want to keep it that way. That said I would appreciate any ideas. I've been surfing the forum and a tune seems to come up a lot but I don't know if there are other options that fit what I'm looking for.
  2. Aug 1, 2025 at 5:53 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Not much bolt on aftermarket performance parts for these motors. Either tune or boost. Or both. Only feasible power adders for these motors.
    But why do you feel you need more torque? If you feel the truck is under powered, then you’re probably going something the truck isn’t rated for.
  3. Aug 1, 2025 at 6:08 PM
    Toyfever
    With all due respect assuming I'm doing something the truck isn't rated for is an incorrect assumption. I simply want a bit more seat-o meter power and I feel with the right tweak it would be easily accomplished without compromising drivability. That's why I'm looking more into a mild tune
  4. Aug 1, 2025 at 6:17 PM
    blenton
    blenton New Member
    Overland Tailor Tuning is the immediate answer. Look on their website for a local tuner in their network. Or @JustDSM can point you in the right direction if needed.
    If you are looking for a noticeable increase in torque, this pairs well with an updated OTT tune:
  5. Aug 1, 2025 at 6:21 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    OTT tune, regear, blower. In order of cost, and of impact.
    RobertD, MVRCA, HulkSmurf14 and 3 others like this.
  6. Aug 1, 2025 at 6:43 PM
    Danman34
    Danman34 New Member
    Danny
    Getting rid of the corsa exhaust will help. It’s been proven that most general cat back systems reduce the mid rpm torque in these trucks. In an otherwise stock N/A truck, you’ll get more seat of the pants power from the stock exhaust. Or going with an exhaust designed just for these motors and their unique power band, like one from Dirty Deeds. There’s plenty of power on hands in these trucks. It’s quite possible the truck just needs a solid tune up, being it’s an 18 year old truck. There isn’t much tweaking you can get out of these motors that will give you any real seat of the pants power increase, aside from going with a supercharger. Like mentioned, there is no real bolt on aftermarket power increasing parts for these trucks.
  7. Aug 1, 2025 at 7:19 PM
    KH1414
    KH1414 New Member
    Kenny
    2019 SR5 TSS
    Alpharex tails, RC nerf steps, TRD Pro rear sway, Klearz 3rd brake smoked lense
    OTT tune and a Dirty Deeds muffler gave me a noticeable difference. SABM will prob be next, just because
    joseph_womack likes this.
  8. Aug 1, 2025 at 7:29 PM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    What are you telling us @blenton, you got a Harrop for your ‘21? Don’t be holding out the details. :popcorn:
    RobertD and HulkSmurf14 like this.
  9. Aug 1, 2025 at 7:42 PM
    Toyfever
    Wow guys on this site are awesome! I really appreciate your help! My last tune up was AT 60K and I'm currently at 120K miles. The last tune I cleaned the MAF and installed Denso iridium Long life plugs. Not much else I know of to do from a tune up aspect. The overland tune has my attention. I'm in La Porte Texas (near Houston) so I'm thinking of doing a tune up then seeking a local Overland tuner so long as the tuner maintains the daily drivability I have now. BTW Blenton that's an impressive engine bay you got there!
  10. Aug 1, 2025 at 8:41 PM
    blenton
    blenton New Member
    Hahah. No. My engine bay isn’t nearly that clean. I don’t think it has EVER been that clean… I’m not sure you would be able to tell what you were looking at. Just a pic off the interwebs I grabbed to make a suggestion. ;)
    Besides, the whole front of my engine is currently scattered around the shop right now. I was THIS close to pulling the trigger on a Harrop, believe you me. But Whipple hooked me up with a 3.0. More to that story but I don’t want be a drama queen. Ha. We’ll see how the Gen IV sings. I gotta get the ‘13 put back together before the ‘21 gets Whipple-fied…
    But I’ll own this engine bay for now.
    But to keep it more relevant @Toyfever, my wife’s sequoia is still naturally aspirated and was tuned by OTT. It made a HUGE difference in driveability. Dyno graphs show something like an additional 40 HP in the lower-mid to midrange power band with the tune, which is noticeable when driving. And since HP is simply a function of torque with respect to time, more HP at the same RPM means more torque at that RPM. Peak HP doesn’t change much, but you have more power under the curve where you can use it. The tune was well worth it. A SC is also well worth it :D
  11. Aug 1, 2025 at 8:58 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    You’re only 60k on the plugs, I wouldn’t say you need to change them again; you could pull the first one just to see what it looks like but you’d just be throwing money away
    HulkSmurf14 and AZBoatHauler like this.
  12. Aug 1, 2025 at 9:56 PM
    AZBoatHauler
    So.Arizona
    This. It would be about time to change the original plugs if they were still in there.
  13. Aug 2, 2025 at 1:12 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    If you can find them the Thorley shorty tri "y"s might net you some low end torque, or at least that is what was advertised. I doubt you would get huge gains out of them since the stock headers are pretty decent for NA setups. You wouldn't have to deal with any O2 issues either.
    Edit: You could keep your stock cats in place.
    HulkSmurf14 likes this.
  14. Aug 2, 2025 at 5:52 AM
    Toyfever
    This may be a question for Overland but I live in a county that requires annual emission testing. I read on their site that the testing facility could detect a CVN mismatch so I'm wondering if they actually look for this and if so would it cause me to fail the emissions test?
    I did by the way notice she perked up a bit back when I put the plugs in
  15. Aug 2, 2025 at 6:56 AM
    Saltyhero13
    you can tag Overland Tuning with the "@" symbol to ask them questions. One of their handles is @JustDSM
    JustDSM likes this.
  16. Aug 2, 2025 at 7:03 AM
    JustDSM
    JustDSM New Member
    Justin
    https://www.tundras.com/threads/ove...nd-tailor-sema-ce-and-carb-eo-pending.158361/
  17. Aug 2, 2025 at 12:19 PM
    Toyfever
    @JustDSM, Thanks a lot! I'll get in touch with the local shop for an appointment
    JustDSM likes this.
  18. Aug 2, 2025 at 1:35 PM
    joseph_womack
    Joe
    Louisiana
    Let us know what you do and how you like it!
  19. Aug 2, 2025 at 6:41 PM
    Toyfever
    I'll keep you posted for sure. To make sure everything is in good order I went ahead and replaced the plugs with Denso Platinum power. The ones I pulled looked ok. One had a tar like black goo on it which I suspect is the plug tube seal breaking down. I also cleaned the MAF sensor and found the air filter snorkel coupling pinched and torn on the bottom on the intake end. I fixed it as best I can for now. It's definitely more responsive but I still want to get the tune done.
  20. Aug 2, 2025 at 7:30 PM
    joseph_womack
    Joe
    Louisiana
    You could also look at doing the SABM or a CAI that actually pipes it into the fender
  21. Aug 2, 2025 at 7:41 PM
    Toyfever
    What does SABM mean? Also I don't understand why AFE designed an additional opening in the air filter housing then offer a block off cover for it
  22. Aug 2, 2025 at 7:55 PM
    joseph_womack
    Joe
    Louisiana
    I’ve seen those, doesn’t make much sense
    SABM: stock air box mod
    you essentially drill a hole in your fender and air box and connect it with tubing to allow more air into the intake, I’ve heard good things about it
    Trooper2 likes this.
  23. Aug 4, 2025 at 5:08 PM
    Saltyhero13
    On the AFE design the air box will pull in some hot air from the engine bay, the plugs are to keep hot air out. They may also offer them for dusty environments or for when crossing deeper waters that could wash into the air box.
    Recommend checking out Stillen's CAI if you are considering an air box and/or SABM.
    YotaEer likes this.
  24. Aug 4, 2025 at 6:35 PM
    joseph_womack
    Joe
    Louisiana
    Woah, so it takes some ram air from the grill and air from the fender? Pretty cool
  25. Aug 4, 2025 at 6:44 PM
    Toyfever
    It would be even more cool if I could use it but it's my understanding it won't fit a 2007 model. BTW they also sell a block off cover.
    joseph_womack[QUOTED] likes this.
  26. Aug 5, 2025 at 1:44 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Go down to a stick 2 3/4” tailpipe paired with that exhaust, that’ll give you a little of the low end torque back that the 3” tailpipe is losing you.
