Third Brake light/ Cargo light
Discussion in '1st Gen Tundras (2000-2006)' started by AV8R4AA, Mar 26, 2021.
  1. Aug 1, 2025 at 12:06 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    I'm just so tired of replacing bulbs often, having a melted reflector behind the lens, and what seems like not really illuminating the bed well with OE setup (maybe because often 1 bulb down). Lens cover and gasket are ok so was thinking either trying some LED replacements next, or swapping the whole unit with AM.
    Halsted likes this.
  2. Aug 1, 2025 at 12:33 PM
    Halsted
    Halsted New Member
    2004 Tundra 4WD V6 AC Manual
    So you bought that third option?
    After reading here, seems like the cargo lights don’t even really do anything. I swapped the brake light bulb out since I had it apart. But I’m not sure I’ll replace the cargo lights. Seems like this is what we’re stuck with. Aftermarket leaks. OEM melts the plastic and burn out frequently. And for me, I’m going to have to make a big mess breaking the bulbs.
    Are there no LED swaps?
  3. Aug 1, 2025 at 12:40 PM
    ToyotaDude
    ToyotaDude Member
    Think some replace with Sylvania Zevo 921 LED.
  4. Aug 1, 2025 at 12:53 PM
    I did. Then I went out and bought a full assembly during one of the sales, because I've been thru a rodeo with 3rd brake lights in the past with my GMT400. That's in a box. But I swapped the halogens out for LEDs when I popped the cover off, tested to make sure polarity was good, and popped the cover back on. That was around 70k original miles, I think, and yes, my plastics above the old halogen bulbs were melted to shit also.
    ZEVO are the way to go. I think I used some extra LEDs I got in my FyreFlys kit.
  5. Aug 1, 2025 at 1:02 PM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    I went to Napa and got led bulbs to fit the broken ones. The cargo lights are great, but I’m not certain I got the third b light going or not, it’s my neighbor’s rarely driven 2nd vehicle.
  6. Aug 1, 2025 at 1:02 PM
    Halsted
    Halsted New Member
    Wait there's an easy plug n play option with LEDs?? Why doesn't everyone do that? The connector is the same? @shifty` - which LED did you get?
    I just replaced my brake light with the halogen. Just went to O'Reilly's and asked for the compatible bulb. I think it would be worth it to break the glass and pull the old cargo lights if I could swap in LEDs.
    rouxster70 likes this.
  7. Aug 1, 2025 at 1:16 PM
    rouxster70
    04ac2wdv65spd
    It’s on the list verify and correct.
  8. Aug 1, 2025 at 1:17 PM
    rouxster70
    04ac2wdv65spd
    Yeah just go get them from the auto store
    Halsted[QUOTED] likes this.
  9. Aug 1, 2025 at 1:18 PM
    Halsted
    Halsted New Member
    Did you get the Sylvania Zevo 921 LED? Do you happen to have the part number?
  10. Aug 1, 2025 at 1:43 PM
    Halsted likes this.
  11. Aug 1, 2025 at 1:53 PM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    I installed this kit about a month and a half ago. Replaced all the interior lights and the cargo lights with LEDs. Everything works except the glove box, but that didn't work before. And the price is cheap enough that if they all die in 6 months, it's not a big deal. Cargo lights are definitely brighter now.
    https://www.amazon.com/dp/B0CDTTB8M3
  12. Aug 1, 2025 at 2:04 PM
    Halsted
    Halsted New Member
    These were all just plug n play? That's an amazing price. No adapters or anything?
  13. Aug 1, 2025 at 2:10 PM
    Upshot Knothole
    Thatchery
    PDX OR
    Yeah, comes with a trim tool and a paper showing where each bulb goes. A JIS screwdriver would be handy to have as well.
    And no adapters or anything needed. The hardest part was the driver's foot well and the glove box lights.
  14. Aug 1, 2025 at 2:20 PM
    Chris948
    Chris948 New Member
    DFW
    2006 DC
    the only thing you need to know for the cargo light is 194 or 921, which is a very popular bulb in a DC. I think some people use 921 but the last thing I need is more plastic melting. I ordered a bunch from china for less than $1 a piece.
    These are cheap, my 8 year old son loved this project. It’s that easy. Took a pic before I swapped out the reverse light on the left. Even cheap LEDs destroy the old school bulbs. IMG_0683.jpg
  15. Aug 1, 2025 at 4:59 PM
    ToyotaDude
    ToyotaDude Member
    Think the Zevos are this for $26...
    https://a.co/d/8L2QMuf6.
    But if $1 bulbs rock, then looking hard at that. Got a link? Many I've seen have reviews with them burning out soon. How long have you had them?
    Full replacement kit for $24 seems enticing Want to do the kicks, map lights, and backups too. Eventually think I'll go OSRAM Northstar AV Halogen 69378 for the backups, but they just went from about $7 to 16 each, and have two trucks to mod!
    https://www.amazon.com/dp/B001BMUFN8
    Been reading this on backup lights:
    https://www.tacomaworld.com/threads/gy6-35-hir-921-reverse-light-upgrade-vs-high-power-leds.474996/
  16. Aug 1, 2025 at 5:33 PM
    Zach_795
    Zach_795 Master Apprentice
    Virginia
    2002 4.7L Limited 4WD
    K&N Cold Air Intake PowerStop Z36 Extreme Performance Brakes, drilled and slotted, red calipers and drums Midland 75-822 CB w/ 3’ FireStik antenna JBA Silver Ceramic Shorty Headers BFGoodrich T/A KO2 LT265/65R17 tires 4Runner Sport 6 spoke 17” wheels Remote control exhaust cut-out Ruthenium spark plugs 12-hole injectors 20% tint all around 35% windshield Weathertech mats and window flares Grille guard with twin spot light bars, wired to high beams 2.5” RC lift front and back KSP Upper Control Arms Full led replacement 6000k Clear front turn signals, tailights, third brake cover
    Anybody know where I can get a clear third brake light lens? Not one of the janky all-in-one led units, just a clear lens I can put led bulbs behind.
    Also need the same for tail light housings.
  17. Aug 2, 2025 at 5:29 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    The best solution (IMHO) is to put red 921 LEDs behind your existing red lens.
    NewImprovedRon likes this.
  18. Aug 2, 2025 at 6:06 AM
    Zach_795
    Virginia
    I already have color matched LEDs on the whole rear of the truck, (the whole truck actually). I just got clear turn signals for the front and I’ve realized that now the back looks dumb with all the red and amber. Need clear lenses all around, and I’ll just keep the red and orange leds in the sockets.
    shifty` likes this.
  19. Aug 2, 2025 at 6:41 AM
    To that point, if you're buying the Sylvania ZEVO and you want red, blue, or whatever, they use a common system, where they put a letter after the bulb number. Like red is 921R, blue is 921B, orange/amber is 921A and plain white bulbs have no letter suffix.
    This is the difference between a standard yellow halogen bulb and the LED amber/orange ZEVO bulb in the parkinglight ("teardrop") position: https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1800#post-3442809
    Note the packaging: If it doesn't say "ZEVO" on it, it doesn't have the lifetime warranty. I think the ZEVO package is typically black, and the non-ZEVO is white? More info here: https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-2033#post-3529276
    Always look at the package color. And use the Sylvania bulb picker to figure out which is correct.
    Zach_795 likes this.
  20. Aug 2, 2025 at 7:24 AM
    #50
    Chris948
    Chris948 New Member
    DFW
    2006 DC
    I just ordered auxito. You can get them on Amazon or Alix if you want to wait two weeks.
    $26 seems kind of crazy unless they can prove the emitters aren’t coming straight from china. I’ve had expensive LED bulbs go out and the warranty process is just stupid enough to not bother. Not unlike axles I suppose.
    Put one of those cheap amazon kits in my wife’s van 8 years ago and not a single one has had an issue. Pieced together some straight from china bulbs for a Honda and I did lose one dashboard one that needed replaced after 9 years.
  21. Aug 2, 2025 at 7:33 AM
    #51
    I think I paid $18 for mine. I got them at Advance Auto using a coupon I found online, ordered online using that 20% or 25% off coupon, for in-store pickup.
    There's a few reasons I chose the Sylvania:
    • They use a fogged cover, which helps avoid hotspots by diffusing the light equally
    • They come with a lifetime warranty, and in past cases where I had to warranty w/Sylvania it was painless (but I couldn't find anyone online that had to do it w/ZEVO bulbs which is great)
    • They don't have polarity issues like cheaper bulbs, which means you never need to worry about installing backwards
    • They don't have hyperflash/resistance issues like cheaper bulbs, which is another huge plus
    • They have the reputation of a large company behind them
    • Considering it's a bulb critical for safety, I don't want to trust a cheap Chinese brand with my life, when I can trust a major name brand that'd be easy to sue in the event of accident due to part failure
    I guess everyone has their thing, but at the end of the day, paying $18 for a pair of bulbs I should never need to change again, in a safety position, won't have hassles with install, and shouldn't have issues with longevity, it's worth every penny. The number of people I've seen on here who've had cheaper LEDs fail, even from name-brand places like SuperBrightLEDs, is too damn high for my taste. I don't check my brake lights more than a couple times per year. I don't want to find out the hard way, i.e. someone rear-ending me, that my brake lights aren't working.
    YMMV, I'm not knocking anyone's buying choices, and I understand cash is strapped for a lot of us these days. Me spending $18 for a pair of bulbs is partially because I have it on-hand, and partially because the cost to me in the event of failure (with brake lights at least) would be higher if someone hits me.
  22. Aug 2, 2025 at 7:37 AM
    #52
    PS - I ordered my bulb kit from FyreFlys @ https://fyreflys.com/
    I picked it up thru eBay. Only mentioning to say, I'm not really opposed to using cheaper LEDs, and their kits are not only quality, and support is good, but it's generally great bang vs. buck. I just don't usually use them with exterior lighting for safety purposes.
    That said, I wish more of these LED companys would use a frosted diffuser, because it really pisses me off when you can see each emitter's location, and you get way better light cast/distribution from a frosted cover.
    #52
  23. Aug 2, 2025 at 9:17 AM
    #53
    Zach_795
    Virginia
    Every single bulb on my truck is a Zevo. Except for the ones that don’t come in Zevo, those are just the regular Sylvania LEDs. The main headlight bulbs and a few interior ones for example. The only non-led I have is the ashtray light because the LED behind the green film was way too bright and didn’t match all the other greens, so I put the incandescent back in.
    Haven’t had any go out yet, but I lost one of the fog light bulbs when it came unplugged and fell out of the housing somehow. :sadviolin:
    shifty`[QUOTED] likes this.
  24. Aug 2, 2025 at 9:55 AM
    #54
    Yeah, the A/C control lights are way too bright after I installed the ZEVO bulbs, but after a few weeks, I stopped noticing it. I was thinking about possible solutions there, but I do like the white light more than the stock green, and can't bring myself to switch back.
    Zach_795[QUOTED] likes this.
