  1. Aug 1, 2025 at 2:08 PM
    They have a 5 year warranty. Send them pics and they may replace them pretty quick.
    BR73 and NewImprovedRon like this.
  2. Aug 1, 2025 at 2:39 PM
    MGMTundra18
    MGMTundra18 New Member
    Charlotte NC
    2018 MGM Tundra 4x4 TRD Sport
    Rescued a mate last night who was having transmission problems.
    ATV25, woods, Tripleconpanna and 5 others like this.
  3. Aug 1, 2025 at 2:56 PM
    Shaken_1
    Shaken_1 New Member
    2015 TRD 4x4 OffRoad CrewMax
    I know im working on it...trying to find a black housing where i dont lose my in cab self level and the led bulbs i already have
  4. Aug 1, 2025 at 3:26 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Got my sticker on the mail today [​IMG]
    Here is the link I used to get mine it was super easy and is a sticker not a window cling like the ones on ih8mud forum were showing.
    https://airtable.com/appJemtc5wT3QKod9/shrlDVU5yF8ooiE2a
  5. Aug 1, 2025 at 3:40 PM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    Monitored transmission temps again today on the 2.5 hr drive to the family cottage.
    76° outside. Towed my boat and a bed full of firewood. Sweet spot was 73moh in S5. The pan never cracked 220° and highest TC I saw was 225°.
    Feeling much better about this than the last time. Obv it was much cooler out and I was driving much slower.
    I'll see what my unloaded #s are when I return home for work without the firewood and boat this week.
  6. Aug 1, 2025 at 3:43 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    If you are still wanting more temperature reassurance, I suggest looking into the PML transmission pan...you gain more quarts of fluid and the I think the fins actually do help in creating a lower operating temperature...
    https://hgmelectronics.com/products...7VhpexHZ0q-Ccg-ci6dHgEjKMjgzGc3hoCR7MQAvD_BwE
    https://yourcovers.com/pml-toyota-a...h3aS2gy_YyWTinxRcnPR-row6eS5ipTftMtYfDZkaqkef
  7. Aug 1, 2025 at 3:51 PM
    Henry1jg
    MI
    Did you go this route vs transmission cooler? Or both?
    Thanks for sharing these links!
  8. Aug 1, 2025 at 3:52 PM
    Henry1jg
    MI
    Nvm, I see you have a 2014 and likely already had the cooler stock
  9. Aug 1, 2025 at 3:52 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    Finally fixed my hood bulge. I had ordered one through Toyota about three months ago, I got an email yesterday from Toyota that "they didn't know when it would be available and that they were going to cancel my order". Earlier this week, before Toyota canceled the order, I ordered an aftermarket one off Ebay with hopes to hold me over.
    It fit pretty well, not perfect! BUT it color matches!
    Old one broke in West Oklahoma when a semi-truck sent a gust of wind into my front in. Snapped the two bolts holes on the end and a couple of the pushpins in the middle. I taped it up, just to keep the wind out and to keep it from popping up.
  10. Aug 1, 2025 at 3:53 PM
    HulkSmurf14
    2014 Tundra Limited
    I have a 2014 and it came with the tranny cooler before the 2019 factory removing of the OE cooler...I have the PML deep pan, yes, paired up with the WAT VB upgrade...it seems to be about 10-20 less in temperatures with the update but I'm not certain which is showing off more...
  11. Aug 1, 2025 at 3:55 PM
    Bham TRD
    Bham TRD New Member
    Birmingham, AL
    2017 Tundra Platinum 4WD CrewMax
  12. Aug 1, 2025 at 4:04 PM
    Henry1jg
    MI
    What temps are you running while towing?
    HulkSmurf14[QUOTED] likes this.
  13. Aug 1, 2025 at 4:42 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    It would’ve been a nicer picture if you showed your flex on that curb. :cool::p
  14. Aug 1, 2025 at 4:49 PM
    SAGE63
    San Diego County
    Did someone say flex?
  15. Aug 1, 2025 at 4:58 PM
    HulkSmurf14
    2014 Tundra Limited
    I've only towed a few times, light trailers with a car on for about 100 miles...I was around 200° the entire time and dipping to the 190°s when empty...over rolling hills at 80 mph +. I was surprised to see the temps this low - but these were only 70-80° days, so I'm not sure if it's been taxed enough to truly see temperature improvements...I have a 3k mile road trip coming up where I'll have a constant load of around 600lbs moving about 75-85 mph up to 7800 ft...I'll have a better understanding after the trip, but 600lbs isn't a weight worth blabbing about. I just know my regular driving temps are 200° or below while before they were 200° and above...
  16. Aug 1, 2025 at 5:30 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    I didn’t want to make the other trucks in the parking lot feel inadequate :D
  17. Aug 1, 2025 at 7:42 PM
    Racer X
    Racer X New Member
    Bob
    North Carolina
    2018 Tundra Limited 4WD 5.7 V8
  18. Aug 1, 2025 at 10:48 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Out with the newer in with the original pos headlights. At least now I can dim the lights. The Morimotos craped out, the flasher relay of theirs disabled my towing lights, that was another pain in the rear. Going to look into the 2018 trd pro led lights. At this point I'm done with Morimotos.20250801_223754.jpg
    HulkSmurf14, BR73, ATV25 and 3 others like this.
  19. Aug 1, 2025 at 10:53 PM
    NWPirate
    Zach
    WA
    My favorite mod by far.
    Over 5 years with my Pro headlights, no problems.
  20. Aug 1, 2025 at 10:55 PM
    AZ Red Nek
    Chuck
    Thank you Sir. Did you get the ihacker harness?
    HulkSmurf14 and BR73 like this.
  21. Aug 1, 2025 at 11:55 PM
    pkeawe809
    pkeawe809 New Member
    PK
    Westside, Oahu
    2018 Super White TRD 4x4 CrewMax
    ~Chrome Delete interior AJT/Tuff skins ~Driver side Grab handle OEM ~Revesol Leather Steering Wheel ~Front Console upgraded to Limited Leather Trim ~Switched Center Instrument panel from silver to black ~Switched black molding trim pieces to Wood grain ~Wood grain Shift Knob ~LED interior lights- meso customs ~Husky X-act Front Driver and Passenger Floor-mats ~Clazzio Seat covers ~Pedal Commander ~Front Windshield heat protection clear film ~VLEDS Footwell LED light kit-driver and passenger sides ~ESP Under Rear Seat storage bins ~4- Door Speakers- JL C1-650 component speakers ~Front Dash Hertz Speakers ~Zapco ST-4X DSP III 100Watt Component Speaker Amp ~Zapco ST-500XM II 500Watt Subwoofer Bass Amp ~1-Rear 10” Subwoofer and Box enclosure ~Sail panel speakers-Hertz tweeters ~Noico 80 mil Sound deadener on all 4 door panels ~Morimoto Headlights-amber DRL ~Diode Dynamics SS3 Pro Foglights ~OEM Tail lights Hot Tails” option A upgrade by Hot Shot Offroad ~Anytime Front and Rear Camera-Trail Grid Pro ~Precision LED lights-rear bed light, lic plate light ~Retrax Pro XR Bed cover ~Auto Rear tailgate lock OEM ~Repaired rust spot and Repainted Roof 7/22 ~De-badged and removed Stickers ~TRD Dual Exhaust w/black chrome tips ~Valhalla Cat Security Shields-Black powder coated ~Black powder coated TRD skid plate ~Red powder coated front Tow Hooks ~Coachbuilder +2 Shackles 1.25” lift ~TRD Pro Grille ~TRD Pro Skid plate ~TRD front/rear Sway Bars ~Bilstein 6112 front shocks ~Bilstein 5160 rear w/resi ~Nitto Ridge Grapplers 35x12.50R17 ~Icon Alloys Rebound Rims 17x8.5 ~Window Tint
    I like this idea! S&B intake Frankenstein Mod :spending:
    Boneskull420[QUOTED] and BR73 like this.
  22. Aug 2, 2025 at 4:04 AM
    WV_21Tundra
    WV_21Tundra New Member
    21 Tundra SR5
    Speaking for every transmission shop owner in the country, THANK YOU GM for the 6L80 transmission.
    Tripleconpanna and BR73 like this.
  23. Aug 2, 2025 at 5:34 AM
    Boneskull420
    Boneskull420 New Member
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    Thanks, I called stillen directly and asked if I could order just the radiator shroud, snorkel tube, rubber tubing piece and clamps. I think for the parts, tax and shipping was around $100. Then I went to my local hardware store and found a flange similar to what they use on the SABM kits to fit the rubber tubing piece, lined everything up to find where to cut the hole. Cut the hole in the air box and mounted the flange with JB Weld plastic bonder. Let it cure and mounted everything up. Screenshot_20250802_082625_Amazon Shopping.jpg
    BR73, Tripleconpanna and HulkSmurf14 like this.
  24. Aug 2, 2025 at 5:41 AM
    Skaufma0
    Skaufma0 Just a little stitious.
    Rock Hill, SC
    2018 MBM Limited CM
    Got mine on Amazon. All this time and it's just now starting to fade a bit.
    Boneskull420 likes this.
  25. Aug 2, 2025 at 6:14 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    I had the same thing happen to my 2015 in Nebraska on a two-lane highway. Luckily, none of the bolt areas broke and only two pushpins let go. I was able to reset the pins and continue on my way.
