Front Differential and Transfer case
Discussion in '2nd Gen Tundras (2007-2013)' started by bradleydavidgood, Jul 31, 2025.
  1. Jul 31, 2025 at 9:30 AM
    bradleydavidgood
    bradleydavidgood [OP] New Member
    2013 Tundra 4.6L Double Cab
    Hi,
    I have a 2013 Tundra 4.6L DC 4WD.
    Do I have a front differential and also a transfer case?
    I've never owned anything with either of these so just wondering what I have and what maintenance I need to do on them.
    I have 121k miles.
    Thanks!
  2. Jul 31, 2025 at 10:27 AM
    Fobroader
    Fobroader New Member
    Alberta
    2020 Platinum
    Howdy, your truck in fact has a front and rear differential and a transfer case that all need fluid replacement at some point. If you don't know if/when its been performed, I would 100% do a full fluid change ASAP.
  3. Jul 31, 2025 at 10:35 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    It's also recommended that you occasionally engage and drive a bit in 4WD to keep things from freezing up.
    Don't do it on dry pavement. (Technically you can if driving perfectly straight, but it's easier and more fun to go find some dirt to play in)
    How many of those 121K miles are yours? If you bought it used, do you have previous owner's maintenance records? Might show if diff(s) & transfer case have ever been serviced.
  4. Jul 31, 2025 at 11:41 AM
    bradleydavidgood
    Great, thank you!
  5. Jul 31, 2025 at 11:45 AM
    bradleydavidgood
    Thanks, yes, I have used 4WD low and high. That makes sense to use it in dirt or a straight line.
    I think it had 118k on it when I got it, and I have no idea what was done before, no records.
    That's why I'm just doing everything.
    Thanks!
  6. Jul 31, 2025 at 11:56 AM
    SD Surfer
    Bruce
    So Cal
    Good plan! You've come to the right place, there's some pretty smart cookies on here.
    Yeah, you never want to do any tight turns on pavement in 4WD, things can bind up. The inside & outside wheels travel different distances in a turn, so one of 'em needs to be able to slip a little when you're in 4WD
    Fobroader likes this.
  7. Jul 31, 2025 at 12:02 PM
    bradleydavidgood
    I have felt that on the pavement and now I know not to do it anymore! Thanks
    SD Surfer[QUOTED] likes this.
