It took 8.75 quarts of oil!
Discussion in '2nd Gen Tundras (2007-2013)' started by bradleydavidgood, Jul 28, 2025.
  1. Jul 28, 2025 at 7:17 PM
    bradleydavidgood
    bradleydavidgood [OP] New Member
    2013 Tundra 4.6L Double Cab
    Yesterday I checked the oil in my 2013 Tundra 4.6L. It was at the top dot. Truck on flat surface.
    This evening I changed the oil. First time I have changed the oil myself in this truck.
    When I got the old oil out, of the drain and oil filter, I combined it into a measuring bucket, and it was significantly over 8 quarts. I thought that was odd, because I had recorded 7.9 quarts as the capacity including the oil filter.
    I added 7.5 quarts of fresh oil and drove 5 miles. Went in a store for 15 min, came out, it was low, added some more, drove home 5 miles, parked in my flat spot, waited 10 minutes, added more, kept doing this carefully, waiting about 10 minutes each time. Finally got it exactly to the top dot. Then I carefully added up what I had added and it came to 8.75.
    I did not make a mistake. I was careful to measure everything I added.
    Is this normal?
    Thanks!
  2. Jul 28, 2025 at 7:33 PM
    18" TRD Off Road Wheels
    The marks on the dipstick is a range. Maxing it out is likely going to put you over the spec'd amount. In my experience with vehicles so long as the oil is around the midway point between the two dots or top and bottom of the hashmarks, you're generally good to go.
    Check your owner manual and it will clarify how your truck is set up and what the process for checking it is. Some vehicles say to check it cold, others slightly warm, others at operating temp. You need to check the book to know what yours needs.
    j-utah likes this.
  3. Jul 28, 2025 at 7:39 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    It takes 20-30 minutes after shutdown for the oil to drain back to the pan to accurately show the level on the dip stick.
    Wait an hour and re-check. You’re probably overfilled.
  4. Jul 28, 2025 at 7:45 PM
    blenton
    blenton New Member
    ^^ What these guys said. I wouldn’t fret over it. I would drain off a quart, though; overfilled can actually be an issue. The crank and rods splashing through the oil can cause cavitation if the level is too high, which whips the oil in to a froth. The oil pump will struggle to pump the aerated oil, possibly leading to oil starvation.
    2mchfun, Ebrperk and j-utah like this.
  5. Jul 28, 2025 at 7:46 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    You're way overthinking this man it's an oil change
    You just added an extra .5qt + now your at max level on stick your fine
    I'll bet you $5 you won't be able to see a difference on the stick 15mins vs overnight after shutdown
  6. Jul 28, 2025 at 7:51 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Change it again in 5k miles :)
    Ebrperk, ATV25 and Leo's first like this.
  7. Jul 28, 2025 at 8:03 PM
    It’s like a transmission dipstick. Some room for hot vs cold readings. Add the amount you’re supposed to, use the filter you’re supposed to. You’ll be good. As long as you’re in between the dipstick marks, you are in the appropriate range.
    Mdl and NewImprovedRon like this.
  8. Jul 29, 2025 at 4:27 AM
    bradleydavidgood
    Thanks for all of the input.
    I waited an hour and it was the same. Right at the top mark, which I think is fine.
    I guess I was looking for someone to confirm that their 4.6L uses that much too.
    But it's OK.
    Thanks!
    Ebrperk likes this.
  9. Jul 29, 2025 at 3:55 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    You should be putting in the amount your manual tells you to, not as much as you can.
    Mdl, des2mtn, Fobroader and 1 other person like this.
  10. Jul 29, 2025 at 7:46 PM
    bradleydavidgood
    I want to put it up to the top dot so that I can monitor how much oil it is using. Meaning, how many miles are there before it gets to the bottom dot.
    2mchfun and Ebrperk like this.
  11. Jul 29, 2025 at 8:49 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    If you overfill it, you will start saturating seals and will start leaking prematurely. I only worried 1 time when there was no oil on the dipstick. I added half a quart juat to get it to mid range amd left it alone. Checked periodically and it was within the range.
  12. Jul 30, 2025 at 3:55 AM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Fill to spec only.
  13. Jul 30, 2025 at 4:14 AM
    bradleydavidgood
    I'm not overfilling it. I'm putting it at the top dot.
    Ebrperk, Leo's first and OHwendTrd like this.
  14. Jul 30, 2025 at 4:17 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Best sell it. Buy a new truck with proper oil levels.
  15. Jul 30, 2025 at 9:16 AM
    blenton
    blenton New Member
    Are you currently burning oil? or suspect the truck may be burning oil? My '13 is as 230k miles and does not burn an appreciable amount between oil changes. As long as it doesn't drop below the bottom mark on the dipstick, you are good to go.
    Mdl and AZBoatHauler like this.
  16. Jul 30, 2025 at 10:48 AM
    AZBoatHauler
    So.Arizona
    This.
    blenton likes this.
  17. Jul 30, 2025 at 10:50 AM
    AZBoatHauler
    So.Arizona
    Also this. Probably more likely to have oil level rise from fuel dilution than burn off.
    blenton[QUOTED] likes this.
  18. Jul 30, 2025 at 12:15 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    do you ¯\_(ツ)_/¯
  19. Jul 30, 2025 at 12:17 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    This.
    OP needs to be aware that every .5ml over the specified volume removes 50,000 miles from the engine's overall lifespan.
    Ebrperk, PolishedTRD, kirkb and 3 others like this.
  20. Jul 30, 2025 at 1:09 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    This is a saga I too experience: engine takes more oil than manual states. I will allow longer for the oil to settle and see if that affects things next time I take the truck out.
    Ebrperk likes this.
  21. Jul 30, 2025 at 2:38 PM
    Rathesun
    Rathesun New Member
    Alaska
    2013 Tundra Double-cab 5.7L engine
    I haven't seen anything like this before :eek2:
    The OP has already received the right answers to his questions. On my 2013 Tundra 5.7 L V8 it takes quite a lot of time for the oil to return to the oil pan, so checking the oil level along the way of a long drive is not going to show the right level on the dipstick marks. Once the oil has warmed it also expands or increases in volume, so it can raise slightly above the top mark. But if you just keep on adding more oil than what is recommended in the manual, the excessive amount of oil can damage the seals and even the engine. Some of the posters responding to the OP questions have told that "as long as the oil level is between the low to the top mark, the level is fine", others have told the OP "to check the manual", and so on. All of these responses are correct.
    The proper way to check for oil consumption in an engine is by changing the oil and filter and matching the total amount of oil needed for both an oil and filter change as indicated in the manual. What I do is to drive the truck for a few minutes until the engine has reached the normal operating temperatures and oil pressure shown by the gages, then park it on a level surface and leave the engine running until I have removed the skid plate under the engine, then turn the engine off, and proceed with the oil & filter replacement.
    The only way for me to check the proper oil level in my truck is this way right after an oil & filter change and engine run and shutdown: I lift the dipstick by a few inches, and sometimes remove the cap of the oil port at the top of the engine, and leave them like that for about 20-30 minutes, and then return to the truck and check the oil level. When I remove the cap of the oil port I make sure to place a clean rag over the opening to prevent anything to fall into the engine. If the oil level is on or near the top mark, then I am done with it and make sure that both the dipstick and oil cap are back in place, but if I need to bring the oil level exactly to the top mark like the OP wants, I could measure and add just enough oil to bring the level to the top mark.
    If trying to figure out if the engine is burning or losing oil, I just drive the truck a certain amount of miles, maybe a few hundred miles, and then check the oil level as I mentioned above, on a cold engine. Sometimes I check it after the truck has been parked for a few hours, but always after removing the oil on the dipstick for 5-10 minutes.
    And there is something else to consider as follows: is the engine losing oil, or burning oil, or is the oil zipping into the antifreeze? This is at times difficult to figure, unless you can see oil deposits on the ground under the truck, or just oil deposits on the engine block, heads, covers, or oil pan, or filter housing-all which are difficult to see when on the road.
  22. Jul 31, 2025 at 7:48 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    sounds like a lot of unnecessary steps and wasted time. you really do all that every time?
    Leo's first likes this.
  23. Jul 31, 2025 at 7:58 AM
    Leo's first
    Groton ma
    Let's make a day of an oil change o_O
    2mchfun likes this.
  24. Jul 31, 2025 at 8:31 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    And not one word regarding blinker fluid level.
  25. Jul 31, 2025 at 2:24 PM
    bicklebok
    bicklebok New Member
    Ronnie
    Every vehicle I have ever owned was filled to the top dot on the diptick. I have 5 vehicles, including a Camry with 240,000 miles. I have never had a problem..................ever!
    Bought2Pull and Leo's first like this.
  26. Jul 31, 2025 at 2:44 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    :bananadead:
  27. Jul 31, 2025 at 5:50 PM
    bradleydavidgood
    I am not sure. This is my first time I'm going to check if it is using oil. That's why I want it at the top dot so that I can run it down to the bottom dot and see how many miles are in between dots.
  28. Jul 31, 2025 at 5:51 PM
    bradleydavidgood
    When I waited 10 minutes I got the same reading as when I waited an hour.
  29. Jul 31, 2025 at 5:53 PM
    bradleydavidgood
    The top dot is the max level and I am not over the top dot. Acceptable levels are anywhere between the dots. That's what the dots are there for.
    KNABORES likes this.
  30. Jul 31, 2025 at 5:54 PM
    bradleydavidgood
    So funny!
    Leo's first[QUOTED] likes this.
