Dobinsons MRR install.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dew, Jan 16, 2024.
  1. Jan 16, 2024 at 5:58 PM
    Dew
    Dew [OP] New Member
    Hey folks just finished my install of the complete Dobinsons MRR kit. I’ll post some more pictures and let you guys know what setting I’m running after I dial it in.
    Turbo_jimbo87, chugs, excelw and 3 others like this.
  2. Jan 21, 2024 at 5:11 PM
    WrongwayUp
    WrongwayUp New Member
    Andrei
    working on them.
    how would they compare to fox or king over the years ?
  3. Jan 22, 2024 at 9:56 AM
    Dew
    Dew [OP] New Member
    I would think they will do just fine. Dobinsons have been running suspension components since 1953. I have no doubt that they will last longer than a fox or king assembly but time will tell!
    I love them!
    MyActualName and chugs like this.
  4. Jan 22, 2024 at 11:13 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Is that hose routed right above the bumpstop for the rear?
    They look nice. I wish OME or Dobinson would offer a 0" lift. I'd like better suspension but really have no need for a lift.
  5. Jan 22, 2024 at 12:38 PM
    Dew
    Dew [OP] New Member
    No it’s in front of the bump stop bracket, bad picture on my behalf.
    I really like the ride I have set up for road use and I tow a 20’ bass boat most times as well.
    can’t wait to take it on some northern washed out roads.
    _none_ likes this.
  6. Jan 22, 2024 at 12:54 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    They have some color
  7. Jan 22, 2024 at 2:11 PM
    yakeng
    yakeng 3URFE Apologist
    Looks great, nice work. I've been considering Dobinsons myself, but kind of in the same boat as _none_, just not sure if I want a lift. Had a lift on my F-150 and it kind of makes things a bit more difficult for me in my use of the truck and hauling stuff around.
    _none_ likes this.
  8. Jan 22, 2024 at 2:25 PM
    MyActualName
    MyActualName New Member
    +1 for wanting a no-lift setup option from Dobinsons.
    _none_ and blenton like this.
  9. Jan 22, 2024 at 3:31 PM
    blenton
    blenton New Member
    I tried it - or rather tried to stick to 1” of lift - and was chastised by Dobinson. Thing is, the shock body itself is set up to run 0” of lift from a threaded body/collar perspective. The preload collar setting has room to fully engage threads on the shock body, put tension on a coil, and utilize a standard 16”x3.0ID coil such as can be had from Eibach in a multitude of spring rates. AFAIK, most of Dobinsons spring offerings for our trucks are linear rate coils so there should be zero issues using a different brand coul (again, I was also chastised for using my Eibach coils).
    I suspect the 2-3” minimum lift comes from one possible issue - the shock bodies might not offer good bottom out resistance so running too low of ride height could might not give the shock adequate time/travel to dampen the motion and cause the shock to bottom. It’s possible that they are relying on the coil to bind before the piston stroke is fully collapsed. This is speculation, but I don’t think it would be too hard to do the maths and figure it out. I don’t recall if Dobinson provides compressed/extended lengths, but I recall my literature giving some reference dimensions for setting preload collar height correctly. It wouldn’t be to hard to put the other pieces together and see if that’s actually an issue.
    I was simply told after the fact that my horrible ride was due to not enough height and using a different coil that wasn’t Dobinson. Really, it was that their recommended damping settings were far from correct.
    There may be some truth to zoned damping like Bilsteins new 8112 shocks that require 2.25” minimum height to operate correctly, but that’s more of bypass shock feature I would be expect to find on the Dobinsons or most other 2.5” body shocks unless explicitly listed. As their damping logic was explained to me - the adjustments rely on shaft speed and not position unless very close to either extreme of piston travel - which is a product of most any floating piston remote reservoir design since the pressures between the pistons increases exponentially at either end of the shock shaft travel. I could be wrong about that, though.
    But I agree - a stock height shock would be fantastic.
  10. Jan 22, 2024 at 4:01 PM
    Iamsecond
    Iamsecond New Member
    Kevin
    2019 Limited Tundra
    Looking forward to hearing more about the ride and how you like these. I’ve been tempted to get them. I just can’t make my mind up.
    Gents, you can get nicer than stock shocks for your tundra that do not give any lift. You don’t have to lift the truck to get a better than stock ride.
    Bilstien 5100 is a great shock and will do factory height and are awesome struts. granted Robinson may not make any but that’s not their wheel house and honestly the three or 4 of you on here are probably the only ones who would buy them. I wouldn’t spend the coin to upgrade my suspension without any lift.l especially at this price.
    Just a thought or two.
    Torn between the ims and the mrr.
  11. Jan 22, 2024 at 4:06 PM
    blenton
    blenton New Member
    Yes, there are lots of stock height shocks available, but as good as 5100’s are (I’ve run them and currently have them on my sequoia), they aren’t close to the same league as MRR’s.
  12. Jan 22, 2024 at 4:10 PM
    Iamsecond
    Kevin
    2019 Limited Tundra
    I agree but they are worlds better than stock and are a great option for those who don’t want to lift. I just hate for people to ride around on crappy stock struts and shocks. But the 5100 and ome coils are pretty awesome. But I prefer the doninson ims to the 5100/ome lift no doubt.
  13. Jan 23, 2024 at 8:35 PM
    MyActualName
    @Dew the setup looks sick. Are those aftermarket leaf springs too?
  14. Jan 23, 2024 at 9:00 PM
    2mchfun
    Those are in fact Dobinson's spring packs.
    MyActualName[QUOTED] likes this.
  15. Jan 27, 2024 at 4:05 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    I love my Dobinsons MRR’s!
  16. Mar 17, 2024 at 5:51 AM
    Dew
    Dew [OP] New Member
    Hey folks, I wanted to give you guys some feedback. Since installing the MRR kit I have had zero issues with them. I’ve driven from Florida to Texas and back towing my 20’ bass boat. I like to stiffen up the ride when towing and when I’m not I soften things up.
    Next big thing I must do is upgrade the brakes as the stock rotors and pads which were practically new did not like some hard braking I’ve had to do. I’m probably going with DBAs or Cyro treating slotted rotors and hawk pads. Also stainless brake lines all around I will never install drilled rotors on a vehicle ever again.
    I’ll be installing the 38 gal tank too I had filling up every 3 hours when towing.
  17. May 30, 2024 at 12:27 PM
    brodesiansneverdie
    brodesiansneverdie New Member
    2020 White Tundra SR5 CM
    Toytec Aluma 2.5/2.0 SPC UCAs U748s Method 705s Toyo AT3 285/75r17 RCI Aluminum skid OTT tune Softopper Decked V2 Diode Dynamics
    You'll be very happy with the 38 gallon tank. I lucked out when I got my truck and out of the 3 tundras on the lot at the time, the one I was most interested in happened to have the 38 gal tank. I didn't know how much I would appreciate it at the time, but it's been amazing.
    Did you have any wheel fitment issues with the reservoirs?
    This kit is on my short list for upgrading my current setup, but the website says that +18 or less offset is necessary to clear the reservoirs. I'm curious what your experience is?
  18. May 30, 2024 at 12:45 PM
    blenton
    blenton New Member
    I had no issues clearing stock +60mm wheels.
    EDIT: I forgot to note that I needed to relocate the front reservoirs and clock them for clearance.
    brodesiansneverdie likes this.
  19. May 31, 2024 at 3:12 AM
    Dew
    Dew [OP] New Member
    I have no wheel or tire fitment issues. My wheels are 18” with a +15 backspacing. My tires are 275/70R18. I have lots of room to run larger tires but I average 14.4L/100km when not towing and around 18.2L/100kms towing.
  20. Jul 30, 2025 at 3:15 PM
    martinejes
    martinejes New Member
    Jesse
    i installed the Dobinsons Racing MRR to my 3rd gen tundra, and its been awesome so far. I got it paired with my Nomad wheels (zero offset) with Mickey Thompson tires, 35 ish inch tires lol they say its 35", but when measured its closer to 36 and some change.
    make sure you understand the adjustments and just not go with factory settings. i got mine set now and they are phenomenal. perform very well.
    chugs likes this.
