Part store says dead battery and dead alternator? Best way to verify?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tumbleweedjoe, Jul 24, 2025.
  1. Jul 24, 2025 at 6:58 PM
    Tumbleweedjoe
    Tumbleweedjoe [OP] New Member
    2021 Tundra 5.7
    • Part store says dead battery and dead alternator? Best way to verify?
  2. Jul 24, 2025 at 8:30 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    Some mid-grade scan tools have a battery and alternator test function, the Harbor Freight model will set you back about $100-150. I would assume the parts store used a similar scan tools to give your diagnosis.
    A shop will give you a second opinion for whatever the charge for diagnostics.
    If you have a decent multimeter, you can perform a voltage check, but that doesn’t always give a full diagnosis on what’s going on without putting the battery and charging system under a load.
    A healthy, fully charged battery should show 12.5-12.6 volts at rest. The alternator can be tricky on newer vehicles because they can vary charge rates based on current draw… you should see greater than 12.5 volts when running, but that doesn’t guarantee the alternator is good. If the battery is discharging while running, that is an indicator of a problem, but not necessarily that the alternator is bad.
    Tumbleweedjoe[OP] likes this.
  3. Jul 25, 2025 at 3:25 AM
    Tumbleweedjoe
    2021 Tundra 5.7
    Youtube video shows disconnecting positive battery terminal while engine is running to test alternator.
    Is this a thing on modern engines? Seems sketchy..
  4. Jul 25, 2025 at 3:47 AM
    red61cj5
    red61cj5 New Member
    wv
    2017 Limited DC Inferno
    More likely one or the other. If its the alternator the battery is probably fine, and vice versa. Either way the battery is dead (but maybe not bad), so charge it and see if it starts.
  5. Jul 25, 2025 at 4:03 AM
    This thread is being way overthought. To start with, don't listen to the idiots at a parts store. Most of them don't know anything about vehicles. How old is the battery? Being that you have a 2021, I'm betting it is the original battery. Most batteries only last on average 3 years before they start going downhill. I highly doubt that your alternator is bad.
  6. Jul 25, 2025 at 4:48 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I agree. My battery did not last 2 years. You can read probably 100 posts on here about similar experiences with OEM batteries. I would put a new battery in it. Start engine turn on all electrical components and then lights on high beam. If lights dim then you probably have an alternator issue.
  7. Jul 25, 2025 at 4:58 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  8. Jul 25, 2025 at 6:29 AM
    The problem with the battery testing scan tools is that they are inaccurate. I put brand new batteries in 2 of our vehicles at the same time and my tester told me that they were both bad and failed the CCA test.
  9. Jul 25, 2025 at 6:38 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    That's odd? My battery tester works great on standard lead acid and AGM batteries. I normally put a brand new battery on a charger before I put them in vehicles.
  10. Jul 25, 2025 at 6:58 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I replace car/truck batteries at, or about, 36 months. Costco Interstate 27F or 24F depending on vehicle. I'm just not gonna try and drag it out and get that last week/day/hour out of a battery. Let's call it: smart maintenance.
    HIGHLY doubt alternator issues. HIGHLY.
    Go get a new battery and truck on.
  11. Jul 25, 2025 at 7:08 AM
    It is odd for sure, and its an Autel unit.
  12. Jul 25, 2025 at 7:16 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Here's the current status of my OEM battery on a truck with 27K that's not driven much. I normally full recharge monthly. Short drives won't cut it.
  13. Jul 25, 2025 at 9:11 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Most places don’t realize the alternators in these trucks are voltage regulated. You’re never going to see 14 volts on a warm truck. If you’re getting over 13 volts, then the alternator is fine.
  14. Jul 26, 2025 at 11:38 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Not sure why wouldn't. Alternators have had regulators for many years.
  15. Jul 26, 2025 at 4:45 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    OEM battery state of charge after driven twice in the last few weeks.
    Battery status after full charge.
    Battery status after Noco G10 repair
  16. Jul 30, 2025 at 9:16 AM
    Tumbleweedjoe
    2021 Tundra 5.7
    It's been 5 day with a new battery. Checked yesterday after driving home.
    13.49 volts with truck running
    12.58 volts with truck off.
    I think the alternator is fine for now.
    Tunrod and yakeng like this.
  17. Jul 30, 2025 at 12:52 PM
    yakeng
    yakeng 3URFE Apologist
    Almost always it is the battery.
    However, I am a poor sucker that had his 2020 alternator go out earlier this year. So it can happen. I blame it on COVID manufacturing.
