Maintenance alert; What changed?
Discussion in '2.5 Gen Tundras (2014-2021)' started by gosolo, Jul 30, 2025.
  1. Jul 30, 2025 at 10:18 AM
    gosolo
    gosolo [OP] You Don’t Know Who I Am But I Know Where You Live
    Ray (or maybe Dale)
    NW Oregon
    For the last 10 years of doing my own maintenance and oil changes, I’ve used the head unit maintenance app. As soon as I finish my job (oil change, tire rotation etc), I set the schedule for 1 year (since I never get 5,000m in a year).
    Previously, after this information is in the system, the dashboard maintenance alert would go away.
    Not this time.
    Any idea why? And how to get rid of it? I will not go to any dealer. I have checked for head unit updates.
    Thanks!
    AZBoatHauler likes this.
  2. Jul 30, 2025 at 10:41 AM
    Try resetting it again.
    gosolo[QUOTED][OP] likes this.
  3. Jul 30, 2025 at 10:45 AM
    MarkM0369
    MarkM0369 New Member
    Mark
    2017 Tundra SR5 4x4
    275/70 KO2, Pro Hood Bulge and grille, OEM fender flares, Fox rear shocks
    May be in the truck computer don’t know about the head unit as I swapped mine in the first month of having the truck. Could be something mileage related longer term, Ie fluids change. May try going to the odometer button and put it on the odometer setting hold the button down and turn the key on, see if that re sets it
    gosolo[OP] likes this.
  4. Jul 30, 2025 at 10:46 AM
    AZBoatHauler
    So.Arizona
    Turn ignition to on without starting. Press the button on the gauge cluster to get to trip 1 on the Odo. Flip key off. Hold down button on gauge cluster and flip key back to on. You'll see the reset timer counting down. Continue to hold until it's clear.
  5. Jul 30, 2025 at 12:48 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Tried, a couple times. No luck.
  6. Jul 30, 2025 at 12:48 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Tried this, no success.
  7. Jul 30, 2025 at 12:50 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Hurrah!! This worked! I still wonder why it wasn’t necessary previously, but at least everything is now good!
    :bowdown::bowdown:
  8. Jul 30, 2025 at 12:51 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I’m printing this and will hole punch it to keep in the tundra notebook.
    23Tundy and AZBoatHauler[QUOTED] like this.
  9. Jul 30, 2025 at 1:13 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    That is a mystery ... I always thought the 5K maintenance required every 5k in MIDS with odometer trip A reset was seperate from the items added into the maintenance section of head unit.:confused:
  10. Jul 30, 2025 at 9:36 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    In my factory head unit app you can set a date and a mileage for when your next service will be required. I set 5000 miles for oil changes and do tire rotation at the same time. I also set the date for service as 1 year, since I usually only get about 3000 miles in a year.
    I have never set a schedule for any of the other items on the factory list of options because they are irrelevant with my low mileage. I just do em when I feel like
    Tunrod[QUOTED] likes this.
