Low Profile Antenna
Discussion in '3rd Gen Tundras (2022+)' started by romanlegion, Dec 7, 2022.
  1. Dec 7, 2022 at 5:50 PM
    romanlegion
    romanlegion [OP] New Member
    Roman
    Katy, TX
    2022 Tundra SR5 TRD Off-Road Lunar Rock
    Are there aftermarket low profile antennas available to replace the "shark fin" antennas that come standard on the 3rd Gen Tundras? I have an RTT and I want to move the tent over the cab, but I hate the idea of having it 4" above the cab to clear the shark fin antenna.
    Any info or suggestion is appreciated.
  2. Dec 7, 2022 at 6:08 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    GoFastCampers has such a thing for a 4Runner, I wonder if it's cross-compatible?
    romanlegion[OP] likes this.
  3. Dec 7, 2022 at 6:45 PM
    romanlegion
    Roman
    Katy, TX
    It looks like the delete kit is not cross-compatible. :(
  4. May 10, 2023 at 11:33 PM
    trailhunters
    trailhunters New Member
    Bumping this back up. Are there any solutions yet? Trying to mount my RTT as low as possible.
    romanlegion[OP] and Russ_S like this.
  5. May 11, 2023 at 6:39 AM
    RustyBRV
    RustyBRV New Member
    Bump, looking for this as well.
    Russ_S likes this.
  6. May 11, 2023 at 3:01 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Same, moved my yakima fly rod holders over the antenna and my Sirius xm cuts out all the time
  7. May 12, 2023 at 12:32 AM
    trailhunters
    Does anyone know what exactly is used for the shark fin antenna? XM and anything else?
  8. May 12, 2023 at 6:47 AM
    Pat80608
    Pat80608 New Member
    Patrick
    Pretty sure the on board navigation uses it as well.
  9. Jul 9, 2023 at 2:23 PM
    Gerrit
    Gerrit New Member
    The Netherlands
    Any news on this, need to remove or replace it.
    Does anybody know what functions are in the sharkfin (gps, radio, ????)
  10. Sep 23, 2023 at 11:15 PM
    romanlegion
    Roman
    Katy, TX
    I wonder if there's an antenna delete available for the Tundra similar to the once GFC offers for the 4Runner.
  11. Sep 24, 2023 at 2:01 AM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    If you have something like OnX or Osmand on your phone, you really don't need the onboard nav. Dexter, I hope you aren't actually paying for "satellite" radio :rolleyes:
    Hella Krusty likes this.
  12. Oct 29, 2023 at 8:22 PM
    Dtrancrx
    Dtrancrx New Member
    Hi has any one done this delete or conversion yet?..I would like a flatter one .
  13. Jan 23, 2024 at 1:21 PM
    Gerrit
    Gerrit New Member
    The Netherlands
    Did somebody removed of replaced the sharkfin antenna yet. And if so, how? (Pictures would be great)
    I like to remove it so I can have my camper closer to the roof of the car.
  14. Jan 23, 2024 at 1:40 PM
    romanlegion
    Roman
    Katy, TX
    I think someone in Texas replaced the antenna cap with a flat low profile version. He basically designed and 3D printed one. I think I saw it in a Tundra Facebook group.
    Dtrancrx likes this.
  15. Jan 23, 2024 at 1:42 PM
    Gerrit
    Gerrit New Member
    The Netherlands
    Thanks for your reply, any link maybe?
  16. Apr 3, 2024 at 6:05 AM
    badmeat
    badmeat New Member
    Cincy, OH
    2022 Limited
    I'd like to bump this to the top as I've just purchased a new home. The shark fin is literally the reason it won't fit in the garage on my stock suspension/wheels/tires 2022 Limited.
    Has anyone found an available solution for the 3rd gens?
  17. Apr 22, 2024 at 4:23 PM
    Dtrancrx
    Dtrancrx New Member
    Bump, help me also haha
  18. Sep 11, 2024 at 11:15 AM
    rchoi
    rchoi New Member
    2024 Limited TRD OR
    *bump* Would like to get rid of it also.
  19. Sep 11, 2024 at 6:15 PM
    carbinefreak
    carbinefreak New Member
    I swapped mine out for a Panorama multi antenna so I can use my cell amp and LMR radio without drilling my roof. The stock antenna contains the LTE antennas for connected services, GPS for Nav and connected services, XM and finally AM/FM antennas it's pretty impressive what they crammed in there. The hole in the roof is roughly a square inch and is held in by a single bolt accessed by pulling the rear seat roof microphone. The clip is a pain but doable, you can pull the black cover off the antenna and stuff the whole antenna in the headliner through the light hole if you still want to use it, the LTE and FM/XM antennas mostly work there.
  20. Sep 11, 2024 at 6:33 PM
    rchoi
    rchoi New Member
    2024 Limited TRD OR
    So you still have connected services and FM radio signal is good? if so I may just do this as well. Less the panorama multi antenna. I'll need to find something to plug that hole though. Thanks!!
  21. Sep 11, 2024 at 7:14 PM
    carbinefreak
    I live out and the sticks and it still works, obviously it's not going to be as good as on the roof but I don't use the connected services or the FM radio much. I bet if you live in decent FM and LTE coverage you wouldn't notice much of a difference. If none of that matters to you just keep the antenna disconnected, only thing is the red LED is always lit next to the SOS button but it's not annoying.
  22. Jul 30, 2025 at 5:56 AM
    TNTundra25
    TNTundra25 New Member
    2025 Tundra Limited TRD Off-Road Lunar Rock
    3" TRD Factory Lift
    Bump. Any solutions yet?
