Used motor oil for chainsaw lube?
Discussion in 'Off-Topic Discussion' started by gosolo, Oct 24, 2017.
  1. Oct 24, 2017 at 5:25 AM
    gosolo
    gosolo [OP] You Don’t Know Who I Am But I Know Where You Live
    Ray (or maybe Dale)
    NW Oregon
    Have any of you used the oil from your oil change for the chain lubricant in your chainsaws?
  2. Oct 24, 2017 at 5:32 AM
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    I wouldn't because of particulates and contaminants in the used oil, also because of how thin Tundra oil is. You need enough visocity for it to be distributed properly.
  3. Oct 24, 2017 at 5:33 AM
    For bar oil?
  4. Oct 24, 2017 at 5:39 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yeah, bar oil only.
  5. Oct 24, 2017 at 5:42 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    This will make a oily, slimy, disgusting mess of your saw, you, and anything within a 10ft radius of the saw while running. Bar oil is thick and sticky for a reason. When the chain is moving at a high RPM the oil needs to stick to it, any other type of oil at all is just going to fling off.
    Prostar 190, driverdog, Newm and 2 others like this.
  6. Oct 24, 2017 at 5:47 AM
    Yeah my grandpa used long long ago along with other things.. I'd stick with bar oil
    ColoradoTJ and NewImprovedRon like this.
  7. Oct 24, 2017 at 6:15 AM
    Borgs
    Borgs New Member
    PA
    2017 Limited Crew TRD Off-Road
    Pro Grill and Bulge TRD sway BAK MX4 Tonneau
  8. Oct 27, 2017 at 10:56 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    It'll ruin your oiler on your saw. I only use the stihl or husqavarna bar and chain oil. I never use the garbage at home depot or the hardware store. You can tell the viscosity between the cheap stuff and the good stuff. It's better for your bar and chain to have the good oil it won't over heat and burn out. I've destroyed bars from using cheap oil.
    Unless you're in a pinch I wouldn't do it. Just spend the 20 bucks and get some decent bar and chain oil. A bottle usually lasts me few months and I cut alot.
    ColoradoTJ and driverdog like this.
  9. Oct 28, 2017 at 5:20 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Nope, I wont even use clean motor oil. Like others said bar oil has properties specifically for chainsaw bars
    BOBONTUESDAY and ColoradoTJ like this.
  10. Oct 28, 2017 at 5:43 AM
    As others have stated, I wouldn’t do it.
    Reasons:
    Above all, safety. Personally, with the average chainsaw injury causing 140 stitches, you can about bet your ass I’m always wearing gear and not putting more undo stress on an already abusive tool. I have already wadded up a set of chaps with a saw, and I was still cut.
    Chains are super expensive (not sure what saw you run).
    New bars are even more expensive, not sure if your bar has the option to swap out the end sprocket.
    https://www.thoughtco.com/using-regular-motor-oil-chainsaw-bar-1342724
    Funny, but this same thing came up in the diesel world as well about burning used oil in the fuel tank. I am sure some truckers did and still do (@GNTundra might be able to weigh in on this). Some people started doing this that I know of for fuel system “lube” due to the US swapping to ultra low sulfur diesel. Those same people were also replacing injection pumps & injectors like crazy. Some simple research on oil properties could tell you why.
  11. Oct 28, 2017 at 7:21 AM
    nick2010tundra
    nick2010tundra New Member
    New Brunswick Canada
    2017 Tundra trd crewmax White ( My dream truck )
    Highly suggest using a proper chain oil. It doesn;t have to be an expensive one and a gallon of bar oil will last forever unless your running it professionally. I Have 2 Stihls and would never dream of using motor oil, like said above its the chains and bars that are the real expense
  12. Oct 28, 2017 at 7:28 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Bar oil is like $5....
    not worth it
  13. Oct 29, 2017 at 2:13 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I’m not sure I’ve ever seen a chainsaw with injectors.
    I’ve had maybe 7 chainsaws and always have run the 30w motor oil. This never seemed to cause any problems.
    I just got a new stihl and wondered about other people’s thoughts.
    I’m cutting a LOT less these days and considering the cost of both the saw and bar oil, I will probably just use bar oil going forward. Thanks for the feedback!
    NewImprovedRon likes this.
  14. Oct 29, 2017 at 2:26 PM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    I’ve used motor oil in mine. Whatever I have a little extra of. probably not the best for the chain but at least it’s always lubed. After reading all this I guess I’ll buy a bottle of the correct stuff next time I’m at the hardware store.
    gosolo[OP] likes this.
  15. Oct 29, 2017 at 3:14 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Straight 30w is about the same viscosity as bar oil so it's a solid choice. Bar oil has some different additives though.
    gosolo[QUOTED][OP] likes this.
  16. Oct 29, 2017 at 4:08 PM
    Bar oil goes down to 10W during the really cold northern winter months.
    Bar oil has tackifiers that helps the oil not fling off.
    I for one do not like dulled chains or failing bars due to lack of lube. The chain rolls and can cause issues with cutting.
    https://www.documentingreality.com/forum/f149/chainsaw-injuries-65206/
    Enjoy and remember to suit up.
    OBXTundra likes this.
  17. Oct 30, 2017 at 3:08 AM
    Ps3udonymous
    Ps3udonymous Who is the smart ass that changed the title?
    If you do any plumbing work and find yourself threading pipe, I've used motor oil as threading lube before. Works well enough if you go slow. Just be sure to clean it off if your doing water lines.
