secondary air injection
Discussion in '2nd Gen Tundras (2007-2013)' started by MobileK9Klipper, Jul 22, 2025.
  1. Jul 22, 2025 at 11:11 AM
    MobileK9Klipper
    MobileK9Klipper [OP] New Member
    2007 TRD SR5
    My bank 1 secondary air injection check valve has gone bad. I really think I am just going to replace both valves... However, I can only find 1 of the valves for purchase... do they fit both driver and passenger sides? 07 SR5 TRD 4.7 169k
  2. Jul 26, 2025 at 10:26 AM
    MobileK9Klipper
    2007 TRD SR5
    I am unsure if this thread has been seen? I was hoping to get a knowledgeable person to answer. Thanks.
  3. Jul 26, 2025 at 11:14 AM
    Tundra Chief
    Tundra Chief New Member
    Wichita KS
    2021 SR5
    Not having your VIN to go off of but looking it up without filters it appears they are the same. If I'm reading correctly it looks like 25710-50030 was used for both banks (which supersedes to 25710-50032) but then bank 2, valve No. 2 became 25710-50040 (which supersedes to 25710-50042) that was used for valve No. 2 from 05/2007 to 04/2009. So it depends on your production date.
  4. Jul 28, 2025 at 9:40 PM
    texmln
    texmln New Member
    Get the Hewitt bypass.
    dondino likes this.
  5. Jul 29, 2025 at 1:14 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    2nd the bypass then you don't have to worry about them failing again
  6. Jul 29, 2025 at 5:13 AM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    I installed the Slyfoxx bypass, no problems since then.
    Leo's first likes this.
  7. Jul 29, 2025 at 3:54 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
