2007 AC code and repair
Discussion in '2nd Gen Tundras (2007-2013)' started by M14 EBR, Jul 27, 2025.
  1. Jul 27, 2025 at 6:40 AM
    M14 EBR
    M14 EBR [OP] Oh No, Rex Kramer!
    Maybe this post will help a fellow member facing a similar problem.
    I pulled this code in December of 2023
    My mechanic replaced the servo motor and one of the HVAC damper control arms snapped during reassembly & function testing... this is not a part you can buy off the shelf, you have to buy the entire expensive HVAC box.
    Faced with that situation, my mechanic performed a field expedient repair to get me back on the road.
    Hot wire welded and sealed with JB Weld.
    It works as it should for almost two years now, and my mechanic will pull a replacement part from a salvage yard if his repair fails.
    Dalandshark and Tunrod like this.
