Factory TRD Lift: Max Tire Size w/o additional mods
Discussion in 'Wheels & Tires' started by drcrazycat, Apr 19, 2024.
  1. Apr 19, 2024 at 3:25 PM
    drcrazycat
    drcrazycat [OP] New Member
    Hi everyone. I recently picked up a new 2024 Tundra Platinum w/ OR Package + TRD Lift. The truck was bought this way from the dealer, I believe this is a factory lift.
    The truck came with the 20-inch TRD alloy wheels and stock Wildpeak tires. I live in Buffalo, NY, and want to upgrade my tires to the Wildpeak AT3W for better snow performance while increasing my tire size.
    What is the maximum tire size I can put on the stock wheels - given the TRD lift - without any additional modifications?
    I do not want to add/remove/trim anything. Don't want any rubs either, I'd like the same driving experience and performance. I would like to simply purchase a set of 4 tires from Sam's Club or another discount retailer and go to my local tire shop to have them install the tires without any additional mods.
    I've read on Reddit that 33" is the max without any mods, but is this true? I'm hoping to find out before spending $1,000+ on tires and realizing I have to make mods. If not, what tire size should I be aiming for then?
    I apologize if this has already been answered - I attempted using the search feature but as a newbie, I kept getting overwhelmed with the amount of info on this forum.
  2. Apr 19, 2024 at 3:34 PM
    lapoolboy
    lapoolboy New Member
    If you don't want to modify anything, stick with 33's.
  3. May 26, 2024 at 6:49 PM
    Sapper406
    Sapper406 New Member
    2024 Tundra Limited, 3in lft, trd package
    TRD Air Intake, TRD Center Cap, 18x8 matte black TRD Pro Forged Alloy Wheels, Tailgate insert black badge, Lomax hard matte black tri-fold tonneau cover, TRD dual exhaust w/black exhaust tips and muffler and TRD matte black badge. 2.5 lift
    285/65/r20 is what Toyota recommends in order to not have any rubbing. I just bought 2024 limited OR pack+3 in factory lift...that is what I am going with. It also does not void the warranty...so if you go bigger and you have something that goes wrong and the mechanics say..."uh it's because of your tire size"...possibly voided. HOWEVER...in the advertisement that Toyota did to promote the factory 3in lift...the truck was on 35x12.5. Interesting...
  4. May 26, 2024 at 7:03 PM
    drcrazycat
    Thanks for your reply. Interesting. Can you please link where Toyota mentions that 285/65/r20 is the recommended size? My stock tires are 265/60/r20 and wondering from where that recommendation is posted.
  5. May 27, 2024 at 2:38 AM
    Sapper406
    https://autoparts.toyota.com/products/product/trd-3-suspension-lift-kit-ptccy34000
    Scroll down to the "disclaimer". IMO...I don't want to leave the decision up to a service manager to determine if my truck's warranty is voided because I wanted 1/2 more inch to say I got 35's.
    285/65-20
    Diameter inches 34.59
    Width inches 11.22
    Circum. inches 108.66
    Sidewall Height inches 7.29
    Revolutions per mile 583.12
  6. May 27, 2024 at 2:48 AM
    Sapper406
    https://www.toyota.com/racing/trd/news/2022/make-your-tundra-even-tougher-with-3--trd-lift-kit
    This links states the same thing...it is just a more specific link from the corporation web site instead of my local dealer. At a minimum...I would buy the tires from them/let them put the tires on and maybe get a written document that states, does not void warranty. Toyota will match price of any tire you find if you bring in advertisement from another tire seller. I am "vested" in this topic because I am doing the same thing with my and I got 7yr/100,000 warranty, so....
    drcrazycat[OP] likes this.
  7. May 27, 2024 at 1:17 PM
    drcrazycat
    Thank you! This exactly answers my question. Thank you again!
    Sapper406[QUOTED] likes this.
  8. Mar 1, 2025 at 9:19 AM
    1stTundraNotLast
    1stTundraNotLast New Member
    Ben
    2024 Lunar Rock 1794
    Factory Lift, Tonneau cover.
    Is anyone rolling on 37s with the factory lift? I've researched the hell out of this and from what Ive seen you need about 2.5" lift to fit 37s but some folks say they needed to do the body mount chop which I am completely opposed to, yet those meaty 37's keep calling my name.
  9. Mar 1, 2025 at 10:12 AM
    Hye_Tundra
    Hye_Tundra Fortune Favors The Bold
    LEV
    Los Angeles, CA
    25’ CSM Limited TRD OR
    I am running factory lift with 37’s, 0 offset wheels. I had to chop the body mount which is an easy DIY at home with no welding etc needed. I also removed metal piece behind the fender liner. All super easy. Nothing else needed to be done.
    aptundra10 likes this.
  10. Mar 1, 2025 at 2:28 PM
    1stTundraNotLast
    Ben
    Wow that looks really clean. I think I can probably get by with 35's but thats not the same look. How bad was the rubbing without the chop?
  11. Apr 2, 2025 at 11:13 AM
    Lil_mac
    Lil_mac New Member
    2025 Tudra SR5
    Factory TRD 3" lift
    I just got a set of 35" installed on my 2025 Tundra with factory lift. At full turn the tires rub the frame.
    I was really hoping this could be avoided. Sounds like 33" is the max.
  12. Apr 8, 2025 at 10:44 AM
    jrramos345
    jrramos345 New Member
    Josh
    Tundra
    How bad is the rubbing? Did you keep with the factory wheels or did you upgrade? What tire did you go with?
    I just picked up a 2025 with a factory lift and I want to upgrade the tires and keep the factory trd wheels, but in not sure what tires to go with.
  13. Apr 8, 2025 at 11:00 AM
    Lil_mac
    Lil_mac New Member
    2025 Tudra SR5
    Factory TRD 3" lift
  14. Apr 8, 2025 at 1:06 PM
    jrramos345
    Josh
    Tundra
    Thanks for the info. Truck look really nice.
  15. Jul 25, 2025 at 3:16 PM
    danmac55
    danmac55 New Member
    Daniel
    2025 Black Tundra Limited
    Factory installed TRD 3” Lift
    What tire size did you end up going with? How’s it working out?
  16. Jul 26, 2025 at 9:07 AM
    1stTundraNotLast
    Ben
    I went with Toyo ATs 35x 11.5 x 17 on Nomad 17's with 0 offset. They rub on the fender liner at full lock or when in reverse. Initially a little rubbing on the frame horn but that went away as the tires settled and wore down. Wheels are machine finish which I know is not the current style, but I feel like they go well with all the chrome on the 1794.
    The only bad thing is that I find myself wanting a steak and a Marlboro red more often...
