  1. Jul 25, 2025 at 7:51 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
  2. Jul 26, 2025 at 8:14 AM
    Well this went horribly wrong. ChatGPT can’t tell rear wheels from front wheels…
    G_unit3000, bmf4069, bing5 and 10 others like this.
  3. Jul 26, 2025 at 8:23 AM
  4. Jul 26, 2025 at 12:19 PM
    Recent hymenoptra adventures.
    I mix a pump sprayer with dawn soap and water. Heavy on the soap. Like a 1/2 - 1 cup per gallon or so. Blue. Knocks em down and incapacitates them in 10 seconds or so. Dead.
  5. Jul 26, 2025 at 1:51 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Why does your buddy think he has a TRD pro?
  6. Jul 26, 2025 at 1:55 PM
    Neo
    Neo New Member
    Alabama
    Not too long ago on this thread, we were talking about fixing things ourselves instead of always having to pay someone else. I wanted to share a couple of videos that probably saved me $300 plus the time and effort installing a new microwave. In 2016, our Kenmore over-the-range microwave flat out died. I pulled it apart, troubleshot it, but couldn't figure out the problem. That microwave was in the house when I bought it and had probably been in service since the house was built in the 1990s. I've had good experiences with Kenmore, so I bought a new one and installed it.
    Earlier this year, the "new" microwave started tripping the breaker. After a little research, I discovered this video
    and used the suggested solution. It worked and we got 3 more months out of it with no issues! (Spoiler: The solution has to do with the 3 interlock switches in the door latch bar and the wear and tear on the latch bar itself.)
    Earlier this month, the microwave started running (light, fan, carousel) but not providing any heat. I could tell by the sound that the magnetron was not energizing. During the previous troubleshooting process, I had purchased a new door latch bar, but chose not to install it because the easier fix worked. I hoped this new behavior might be related to further deterioration of the door latch bar and it was. I followed the instructions in this (longer and more tedious) video
    I removed the door latch bar. One by one, I pulled each of the 3 interlock switches from the old latch bar, tested them with a multi-meter for correct function, and then installed them in the new latch bar. Then I reinstalled the latch bar and reassembled the microwave. Once again, this fixed the problem! We have been using the microwave for several weeks now with no issues. The new latch bar cost $38.00.
    So, if your microwave goes on the fritz with the symptoms I described above, perhaps one of these solutions will save you some cash. And that's cash you can be spending on your Gen1 Tundra! :)
    EDIT: To be clear, this is what I'm calling the door latch bar.
  7. Jul 26, 2025 at 2:20 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Thanks for the pro tips. My parent’s radar range just quit working (no heat) last week. They already bought a new one, but i might take apart the old one to see if i can make something happen…
  8. Jul 26, 2025 at 4:32 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Just pulled a rare reverse @bmf4069
    Should have pressure washed the door cards too eh?
  9. Jul 26, 2025 at 5:40 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    I am considering an airbag system for my rear leaf springs. Are there any issues with having a heavier leaf spring that causes the bags to be elongated when unloaded? Looking to have a heavy load in the bed and also the hitch when going to hunt Idaho.. Concerned about the daily.
  10. Jul 26, 2025 at 8:37 PM
    Zach_795
    Zach_795 Master Apprentice
    Virginia
    2002 4.7L Limited 4WD
    K&N Cold Air Intake PowerStop Z36 Extreme Performance Brakes, drilled and slotted, red calipers and drums Midland 75-822 CB w/ 3’ FireStik antenna JBA Silver Ceramic Shorty Headers BFGoodrich T/A KO2 LT265/65R17 tires 4Runner Sport 6 spoke 17” wheels Remote control exhaust cut-out Ruthenium spark plugs 12-hole injectors 20% tint all around 35% windshield Weathertech mats and window flares Grille guard with twin spot light bars, wired to high beams 2.5” RC lift front and back KSP Upper Control Arms Full led replacement 6000k Clear front turn signals, tailights, third brake cover
  11. Jul 26, 2025 at 10:10 PM
    Nimitz_
    Nimitz_ LA face with an Oakland booty
    Sam
    Seattle-ish
    06 DC LTD 4X4 4.7 V8
    Ah that bev is for the passenger? No open container law in VA, right?
  12. Jul 27, 2025 at 7:20 AM
    Zach_795
    Virginia
    Can do whatever you want on private property
    G_unit3000, bmf4069, JakeJake and 4 others like this.
  13. Jul 27, 2025 at 7:58 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That Batman is interestesting. I had to look it up. I'm surprised I don't know him based on what I read.
  14. Jul 27, 2025 at 8:40 AM
    I mean, you could beat it, but not in public.
    Alternately, you could beat it, but it ain't gonna work any better.
  15. Jul 27, 2025 at 9:16 AM
    Redoak
    Redoak New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    Curious to see what mpg turns out to be.
    200 miles on half tank. Better than I expected so far.
    Lot of uphill pulls, and running the air conditioner full blast. Plus driving around a small town.
  16. Jul 27, 2025 at 9:44 AM
    Redoak
    Redoak New Member
    Dave
    none
    @shifty` was it you saying if you window is partially down and you shut door the glass rattles?
    I remember someone saying couldn’t figure it out.
    Mine was doing it and I found the problem when I replaced my door handle.
    The rear portion of window glass was out of the track causing it to bump every time door was closed.
    I pressed it back into the track, was still plenty of good window sealant/glue to hold it, when doing the track lube.
    No more rattle, clang when shutting door with window down.
    Neo, G_unit3000 and KNABORES like this.
  17. Jul 27, 2025 at 9:49 AM
    Has anyone found a solution to keeping these old trucks smelling fresh?
  18. Jul 27, 2025 at 9:50 AM
    New car smell conditioner?
  19. Jul 27, 2025 at 9:54 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Depends on what smells you’re fighting. I just threw these under the seats and it helped. Also used a natural odor eliminator. Trying to be conscious of chemicals with the little one in the back.
    https://a.co/d/gewEPB1
    https://www.amazon.com/dp/B01M07RTKT
    FirstGenVol[QUOTED] and KNABORES like this.
  20. Jul 27, 2025 at 9:58 AM
    I’ve cleaned the carpets, the air ducts, the AC coil etc. keep the seats wiped down with leather conditioner. Smells pretty good in mine. Carpet, headliner, cloth seats would be odor sponges.
    455h0le_dachshund and khooiii like this.
  21. Jul 27, 2025 at 10:04 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That happened to me on a trail at T2S 2023.
    Trail fix
  22. Jul 27, 2025 at 10:29 AM
    Nimitz_
    Sam
    Seattle-ish
    Carpet cleaner on floors and seats. Just remember not to dump it down the drain.
  23. Jul 27, 2025 at 10:31 AM
    Redoak
    Redoak New Member
    Dave
    none
    I use leather seat conditioner in mine, and it smells fairly good.
    If you’re fighting a musty smell I’d be checking for leaks.
  24. Jul 27, 2025 at 10:31 AM
    Nimitz_
    Sam
    Seattle-ish
    Genuwine?
    The Black Mamba likes this.
  25. Jul 27, 2025 at 10:34 AM
    Nimitz_
    Sam
    Seattle-ish
    BroHon likes this.
  26. Jul 27, 2025 at 10:47 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  27. Jul 27, 2025 at 11:21 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
  28. Jul 27, 2025 at 11:33 AM
    I notice a slight odor for a few seconds when the AC kicks on. It goes away quickly. You've seen how clean my interior is so it's not a dirt issue. Just smells like an old vehicle.
  29. Jul 27, 2025 at 11:36 AM
    Clean out the cowl unless you can smell it in recirculating mode?
  30. Jul 27, 2025 at 11:49 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    @The Black Mamba hooked me up with some AC vent cleaning deal a while ago. That helped tremendously. Completely forgot about it. Probably going to order some more once he posts what it is.
