First Gen Lower Ball Joint(LBJ) Failures
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, May 1, 2024.
  1. Apr 2, 2025 at 6:35 AM
    #601
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
  2. Jun 13, 2025 at 1:12 PM
    #602
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  3. Jun 13, 2025 at 1:27 PM
    #603
    FirstGenVol [OP] Recovering mangler
    Alcohol.
    shifty`, Filthyphil and Sirfive like this.
  4. Jun 20, 2025 at 2:11 PM
    #604
    Baller
    Baller New Member
    '05 Tundra SR5 DC
  5. Jun 21, 2025 at 11:32 AM
    #605
    shifty` You can call 1 (800) PP5-1-DooDoo
  6. Jul 19, 2025 at 9:30 AM
    #606
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd
    Pushing 300k. Never changed LBJs. After seeing several pics in this thread... obviously worthy to do. Only buy LBJs and hardware from Toyota, or do ya'll l have a link to buy all the needed parts from online seller?
    Never should have started reading this forum again... now I'm reluctant to pull out of my driveway! :D
  7. Jul 19, 2025 at 9:44 AM
    #607
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I’m curious, do you have a 2000? Also, we have several sticky threads that have all of the parts needed based on your year. I’m not going to link anything because you did not list your truck info in your profile.
  8. Jul 19, 2025 at 9:49 AM
    #608
    ChattanoogaPhil
    2000 4.7 AC SR5 4wd
    Sorry for the lack of info. 2000 4.7 4wd SR5 accèss cab.
  9. Jul 19, 2025 at 9:51 AM
    #609
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Yup. I went 304,000 miles on my original lower ball joints. The design change came after the 2000 models. This is by no means advocating for not changing them, it’s just interesting that the majority of those with high miles that don’t see a failure are on 2000 models.
  10. Jul 19, 2025 at 11:50 AM
    #610
    ChattanoogaPhil
    2000 4.7 AC SR5 4wd
    Thanks. I now feel a bit better that my Tundra might make it to the store and back without a wheel falling off! :D
    Seriously though, the earlier vid of wheel falling off was disconcertting to say the least. When the truck is lifted up on a rack can the front wheel be rocked back and forth to get an idea of the condition of the BJs? Or is this like a timing belt... replace after xyz miles regardless?
  11. Jul 19, 2025 at 12:03 PM
    #611
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    There is a test that you can do to check. It’s not 100% accurate. The information on how to do that is located in the lower ball joint sticky thread
  12. Jul 26, 2025 at 7:34 AM
    #612
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Welp . . . they didn't go out . . .'BUT', no better time than this to put on the new OEM LBJ's I've been sitting on.
    I had complete brake failure right after launching my boat . . . got SUPER lucky.
    Pedal to the floor, ZERO brakes.
    My buddy came down to the launch ramp and I pulled the trailer off my truck, and put it on his and he pulled my boat out.
    Got home and took the ball joints over to the shop and told them, "Put these on while you're under there".
    Seeing the truck going up on the flatbed 'with' LBJ's still intact told me 'It's Time' LOL.
  13. Jul 26, 2025 at 7:37 AM
    #613
    bfunke
    bfunke Tundra Curmudgeon
    What caused your brake failure?
  14. Jul 26, 2025 at 7:46 AM
    #614
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Pretty sure corroded brake line . . . the guy at the shop said everything in the front brakes was destroyed, rotors, calipers, lines.
    Said the master cylinder was fine.
    I'm totally stupid for waiting so long . . . I knew things were bad, but was waiting till the front pads needed replacing before tackling it all.
    That's why I was sitting on the new LBJ's . . . I was gonna do it all at the same time.
    I'm thankful it didn't happen while on the road . . . or worse 'towing' my boat . . . really a sinking feeling hitting the brakes and the pedal going straight to the floor.
    Funny thing was . . . it was 4:30 in the morning when it happened and my boat was already in the water . . . so no way in hell was I gonna put that truck on the launch ramp. So I said F-it, and went fishing and figured I'd deal with it later. LOL
  15. Jul 27, 2025 at 5:42 AM
    #615
    bfunke
  16. Aug 6, 2025 at 4:08 PM
    #616
    OldGuy03 and Filthyphil like this.
