joonbug's build
Discussion in '2.5 Gen Builds (2014-2021)' started by joonbug, Nov 29, 2016.
  1. Oct 1, 2017 at 2:00 PM
    #241
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Hell yeah. Half those gouges would be on the bottom of my doors. It just makes going over big rocks pretty worry free. If I ever start over, sliders will be my very first upgrade.
    Black Wolf and Jsena[QUOTED] like this.
  2. Oct 7, 2017 at 6:42 PM
    #242
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    The rear being about 3” higher than before the lift, running the bike up the ramp and onto the bed was getting a little sketchy. I’ll still load it on the bed if I’m going far, but for the local riding parks, got me a new hitch rack. Once I get the FRAC installed, it will come in handy to check on the bike while driving.
    Black Wolf, JC303, r4z0r51o and 8 others like this.
  3. Oct 29, 2017 at 6:22 PM
    #243
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    10-28-17
    Barney Riley Trail
    with @16tunterd and @GodlessPro.
    This trail was exactly the opposite of what we were expecting. We thought we were going to plow right through it. Boy, were we wrong. The entire trail was very rocky, tight brush, steep inclines, and big boulders. It took us over 4 hours to travel just 11 miles to the end of the trail. I don’t remember ever getting above 15 mph. And after we got to the end, we had to climb back out of there the way we came in. We had to boogie on out as we were running out of daylight and actually didn’t make it out until the sun went down. A couple of times we were wondering if we were going to make it out alive. Lol. Overall, loved the difficulty... we had such a great time.
    Beautiful sunrise on the way there
    We ignored the recommendation
    Most of the trail looked like this
    Or this...
    Climb to the peak
    From the peak down to the river
    Matt without sliders. This was the average incline on the descent. A few spots got much worse. A couple... downright scary.
    Down at the river
    Best damn burger I ever had... avocado and bacon. mmmmmmm... bacon...
  4. Oct 29, 2017 at 6:36 PM
    #244
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Did incur a little damage. Pushed my bumper in over an inch.
    The bumper is supposed to line up with the trim piece above it. :(
    And more stripes.
    Maybe the RDS bumper will come sooner than planned.
    Black Wolf, JC303, Red@9k and 9 others like this.
  5. Oct 29, 2017 at 6:43 PM
    #245
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Black Wolf, JC303, Y0TA PR0 and 5 others like this.
  6. Oct 30, 2017 at 12:49 PM
    #246
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    NjPro, Black Wolf, r4z0r51o and 3 others like this.
  7. Oct 30, 2017 at 1:25 PM
    #247
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
  8. Nov 5, 2017 at 2:45 PM
    #248
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Took the front apart today to try to straighten the pushed in bumper corner.
    First found the three tabs holding the bumper corner to the center piece broke off. There’s no fixing that without buying a whole new entire center piece. So I just removed the tabs and it lays much more flush now. I think it should be fine without them.
    Also found the metal frame piece the bumpers are attached to is what’s bent and don’t think it’s repairable without a lot of work. So I just yanked on it as much as I could to bend it back as much as possible. Bent it back enough to get the trim piece above it to get back flush with the fender. And enough to get it to stop rubbing the tire at full lock.
    Good enough til I get a new offroad bumper. Oh, and I attached the front camera while I had the grille off and thought about installing the FRAC... but got lazy. Maybe next week.
    Red@9k, TheBeast, r4z0r51o and 8 others like this.
  9. Nov 5, 2017 at 6:00 PM
    #249
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I didn't know you were rubbing.:spy:
    I had my grille off today too, installed the camera and my A.D.D. took me to something else. lol
    Only 19 days 'til bumper day (black Friday). So far, cheapest I've found it is at 4 Wheel parts for roughly 1,050 w/ free shipping
  10. Nov 5, 2017 at 6:30 PM
    #250
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah the bumper was pushed in just enough to make it rub in reverse again. Didn’t realize til I got home and backed out of my driveway. Actually, I probably would have just left it as it was if it didn’t rub.
  11. Nov 17, 2017 at 2:13 PM
    #251
    ScottsBad
    ScottsBad New Member
    Scott
    Free Idaho, escaped Commiefornian
    2018 TRD Limited
    Just a Bed Rug, Soft Topper, Console Safe
    Very nice truck, I'm a long way from getting to your level, but I have a couple questions for you. I think you managed to mount your spare underneath, is there room under there for a narrow 35"? Or is it too tight? And how well does your tire fit?
    Also, I too noticed that the SDHQ sliders look slightly short. I wonder if they would make me a custom set that went closer to the rear tire.
    Thanks,
    Scott
    joonbug[QUOTED][OP] likes this.
  12. Nov 17, 2017 at 2:48 PM
    #252
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Thanks Scott. My 295/70's are about 34.5" and it's pressed up against that bracket that holds the spare tire in place. It's in there really tightly, not sure how the 35's will fit. If you remove that bracket and as long as you don't have the fat Coachbuilder shackles, I think you should be able to get a 35 in there. I'm actually planning to cut that bracket off soon, I don't like the impression it leaves on my spare tire.
    Not sure about the sliders. The reason it's short is because the rear fender drops a little bit lower than the cab area. If it were longer, it would hit it, so they would probably have to completely change the design. I'm sure they could but I would imagine it being pretty expensive for them to make a one off. If anything, I would ask them if they could just weld on a piece on the end that tapers down a little bit to avoid hitting the body. Might not hold up the weight of the truck but will probably push loose rocks out the way.
    ScottsBad[QUOTED] likes this.
  13. Nov 17, 2017 at 3:57 PM
    #253
    ScottsBad
    Scott
    2018 TRD Limited
    Thanks Joon. Maybe I'll go a bit smaller tire. IDK I'm trying to go bigger tires, but I have to be stealthy about it (wife concerns), so I was going to use the stock wheels. I think your tire might be too wide for stock wheels, I'll have to check.
    BTW - Nice family camping pics. Enjoy.
  14. Nov 17, 2017 at 4:01 PM
    #254
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    BAMF sliders.
    $100 rebate on MRDS bumpers starting on Monday. I spoke with N-Fab and they advised shopping the the best deal then sending them the "box top" when the bumper is received. I'm ordering one then.
  15. Nov 17, 2017 at 4:03 PM
    #255
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I'm running the same tire on stock wheels with 1.25" spidertrax spacers.
  16. Nov 17, 2017 at 5:53 PM
    #256
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    I’m ready. Let’s go!!!!
  17. Nov 18, 2017 at 3:37 AM
    #257
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    3.89 for gas.... was that right?
  18. Nov 18, 2017 at 3:42 AM
    #258
    DalTee
    DalTee New Member
    Dal
    That is beautiful, I wish I could experience something like that
  19. Nov 18, 2017 at 3:45 AM
    #259
    DalTee
    DalTee New Member
    Dal
    The drop in reception is worth it for me. I just use my phone
  20. Nov 18, 2017 at 3:57 AM
    #260
    DalTee
    DalTee New Member
    Dal
  21. Nov 18, 2017 at 4:33 AM
    #261
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    Rear Seat:notsure::popcorn: Fold Down Mod How ??? Where??? How Much???
  22. Nov 18, 2017 at 8:19 AM
    #262
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Fold down seat mod is for DC only.
    CJ21[QUOTED] and joonbug[OP] like this.
  23. Nov 18, 2017 at 8:38 AM
    #263
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    I was thinking about returning the antenna, but since discovered Amazon Music. It’s free for Prime members and it’s awesome. Never even knew about it. No more radio for me.
    Sunnier and 831Tun like this.
  24. Nov 18, 2017 at 8:41 AM
    #264
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Like @16tunterd said, can only be done on DoubleCabs. It really is a shame because it’s one of the most useful mods. It’s too bad everyone can’t do it.
    CJ21[QUOTED], 4x4_Angel and 831Tun like this.
  25. Nov 24, 2017 at 11:53 AM
    #265
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Just ordered... Big thanks to Joey @sdhq_offroad. Now the wait begins.
    ICON 3.0 Front Coilover Remote Resis w/clickers
    ICON RXT Multi-rate Leaf Springs
    ICON RXT 2.5 Omega Bypass Rear Resis w/clickers
    ICON UCA Delta Joints
  26. Nov 24, 2017 at 11:59 AM
    #266
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    :jellydance:
  27. Nov 24, 2017 at 12:01 PM
    #267
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Wow. Need all that just to keep up w @dcsleeper408 ?
    :rofl::mudding:
  28. Nov 24, 2017 at 12:06 PM
    #268
    TheBeast
    TheBeast The Beach
  29. Nov 24, 2017 at 12:13 PM
    #269
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Until he goes long travel. :(
  30. Nov 24, 2017 at 12:13 PM
    #270
    bski22
    bski22 New Member
    Rob
    Toy
    Fun coupons
    Looks like a few more months before you get your RTT.
    TheBeast and joonbug[QUOTED][OP] like this.
