Voltagebooster pro Not so professional
Discussion in 'General Tundra Discussion' started by e30cabrio, Jul 25, 2025.
  1. Jul 25, 2025 at 7:03 AM
    e30cabrio
    e30cabrio [OP] I'm e30cabrio, I'm a modaholic
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I'm prefacing this with I am prickly right now. I just wasted 10k on another motor replacement thanks to a scammy junk yard that sold me a 4100.00 "A" grade 70k mile '18 Tundra motor that blew a view hole in the block in 2k miles.
    https://voltageboosterpro.com/?srsltid=AfmBOorUdqineuvLeEBRAkhFNi2H-WmmUlywJZgHuiwOG04-rgXNjGYe
    I got the truck back with a battery light & running at 13.2-6 volts, although my Voltage Booster Pro had been running at 14.2+ From December when I got it to May when the motor died.
    I checked the grounds, verified it was in properly & then put the cheap GM Diode it replaced back. 14.+ volts.
    I'm fine sucking this up, my main reason for posting is the fact their attitude is their product cannot fail, my truck/I must be doing something and the fact that they ignored my last message asking them to keep the product.
    Messaged VBP & here is the exchange:
    Me 7/18
    Hello,
    My Voltage Booster PRO "Spark" (2nd Gen Tundra, 2nd Gen Tacoma, 2nd Gen Sequoia, Land Cruiser, LX570) - C (2007-2021 Toyota Tundra, 2008-2017 Toyota Sequoia)
    Has stopped working. WIth it in on both settings I am between 13.2-13.6, the same as without it.
    I’d appreciate a replacement as it was at 14.x on high which is where my AGM likes it.
    VBP's response:
    Just to clarify, the VBPro does not "stop" working in the sense of like a computer or a TV. It is fully passive and the components don't fail to short. If the booster is physically damaged then this would cause a engine light on the dash. Could you measure your voltages for us?
    Please follow these steps to obtain accurate and consistent voltage measurements. Ensure all readings are taken at the same time interval after starting the engine—ideally, 15 seconds after turning on the vehicle—to account for a consistent point on the charging curve. The measurements required are as follows:
    1. Baseline Voltage Measurement:
      • Use a voltmeter to measure the baseline voltage directly at the battery terminals.
    2. Voltage Measurement with Voltage Booster Pro in Low Mode:
      • Plug in the Voltage Booster Pro and set it to "Low" mode. Take a voltage reading at the battery terminals at the specified time interval.
    3. Voltage Measurement with Voltage Booster Pro in High Mode:
      • With the Voltage Booster Pro still connected, switch it to "High" mode. Again, take a voltage reading at the battery terminals at the same time interval.
    By maintaining a consistent measurementinterval (e.g., 15 seconds after engine start), you ensure that all readings are taken at a comparable point on the vehicle's charging curve, improving the reliability and accuracy of the data collected.
    Please provide those 3 measurements.
    My response:
    Hello,
    Before I contacted you I did all of that on a Fluke voltmeter.
    There is no physical damage. The alternator is an OEM 180 amp unit installed in December 24.
    I also sent this before their next response:
    It is 13.2 at idle regardless of if the unit is there or not in both modes.
    It's suddenly like it's not there.
    I have a diode that brings the voltage up. I got yours because I did not like not having a fuse.
    VBP:
    Ok, thanks for the info. Based on what you are describing, I suspect there is nothing wrong with the booster and there is another variable. But please send it in so I can take a look at it and i'll swap it anyways.
    Mail to:
    VoltageBoosterPro.com
    Address removed
    Include your name and order number please.
    I sent the unit & got this:
    I am pleased to inform you that I have tested and inspected your booster, and it is fully functional. A new unit will be sent to you as a replacement anyways. As previously stated, there is something else downstream causing your symptoms.
    Could you please send a picture of the booster installed in your vehicle?
    I responded:
    That’s great, the cheap GM diode from Amazon is giving 14.2-14.6, how about you keep it and return the money?
    This was 7/23, they ignored the message & shipped 7/25
    Saltyhero13 and HulkSmurf14 like this.
  2. Jul 25, 2025 at 12:37 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    That’s unfortunate to hear, when mine has a slight fitment issue, they were very responsive and helpful, the only thing I’ve noticed with mine is that when the truck is hot the voltage is lower than when it’s cold. It starts off at around 14.6, then drops to 13.8-14.
  3. Jul 25, 2025 at 1:01 PM
    centex
    centex New Member
    I think their response is pretty good actually. They tested it for you, found it was working, but are sending you a new one instead of your old one. That’s better than most places.
    bulldog93, e30cabrio[OP] and Wynnded like this.
  4. Jul 25, 2025 at 1:34 PM
    e30cabrio
    Except it did not work in my application (after working for 5 months) and their position that their product cannot fail/ it's my truck's fault, while ignoring the cheap diode is working and ignoring my response asking them not to send the new one.
    There is never any hint of maybe their product is the issue/ expression approching something emulating sorry their product caused me to spend time diagnosing it/contacting them etc.
  5. Jul 25, 2025 at 2:23 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    That's a good thing. The saturation point drops as temperature rises. The upper echelon maintainers are temperature compensating.
    Ericsopa, Wynnded and e30cabrio[OP] like this.
  6. Jul 25, 2025 at 2:33 PM
    e30cabrio
  7. Jul 26, 2025 at 8:14 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Well this sucks to read as i just put in one of their unit last week. Guess we'll have to see if mine will crap out down the road.
  8. Jul 27, 2025 at 10:17 AM
    e30cabrio
    I seem to be the only one with an issue, mine did work fine for 6 months.
    I hope yours is fine. Again, my issue isn't with the product or fact it stopped working, it is with the response.
  9. Jul 27, 2025 at 10:20 AM
    BrandonL812
    Brandon
    I gotcha. Yeah i would be a little bothered also by their respond. Stand behind your products. Not much to ask. Especially if they know they have a low return rate. Take it back and send a new or or issue a refund when you get your part back.. not that difficult..
  10. Jul 27, 2025 at 10:31 AM
    Seemed like an appropriate response, not the one you’d hoped for. They offered to test yours and to send you a brand new one. They did not offer a refund. I’m not aware of what the return, replacement, refund policy is for this device. But so far, stellar customer service.
    NewImprovedRon likes this.
  11. Jul 27, 2025 at 10:39 AM
    e30cabrio
    I'm glad you are happy with them. My issue is the assertion that the product cannot fail and after testing mine was 100%.
    I am not crazy, lonely, or seeking anything for nothing. Mine stopped working in my car; that is the only place I care if it works.
    Initially, I asked for a replacement, which happened after I paid to return it & they insisted there was nothing wrong. Prior to the replacement being delivered to USPS, I asked them to refund. That message was ignored & it was shipped. I have already spent money replacing it and do not want it.
    The entire thing is about as far from stellar as it can be.
    That is my experience.
    KNABORES[QUOTED] likes this.
  12. Jul 27, 2025 at 10:50 AM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    Kings & Icons
    e30cabrio[QUOTED][OP] likes this.
  13. Jul 27, 2025 at 11:11 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    How old are the batteries in the truck? If an AGM is dead for time they won’t take a charge etc and AGM are more sensitive to this proper voltage etc
  14. Jul 29, 2025 at 5:30 PM
    e30cabrio
    16 months, has never been under 12 volts. (that was only after sitting from r&r ing the motor)
  15. Jul 30, 2025 at 8:56 AM
    e30cabrio
    HKB variable at 0.5
    So it's them not me.
    BrandonL812 likes this.
  16. Jul 30, 2025 at 8:59 AM
    e30cabrio
    Sorry, I missed your response, it's sold.
