Coolant leak
Discussion in '2.5 Gen Tundras (2014-2021)' started by Atl626, Jul 25, 2025.
  1. Jul 25, 2025 at 6:35 AM
    Atl626
    Atl626 [OP] New Member
    2018 black Crewmax SR5
    I have a 2018 sr5 , was getting oil change at dealer and they mentioned i had a coolant leak , it seems to be small , they recommend replacing the hose but it looks good to me , seems like the clamp might be the issue , just curious if anyone had something similar and what the fix was
  2. Jul 25, 2025 at 6:40 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    if you zoom in, it looks like there are "teeth" where the hose attach, and on top, they are not covered like they are everywhere else. I am wondering if you slid it back on further and got it tight again if that would solve it.
    Tundra2n3, Petro and Tunrod like this.
  3. Jul 25, 2025 at 6:43 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Hard to tell but hose does look like it's showing its age. I think you can pick up a hose and clamp for about 60 bucks. I would take a look at the battery and clean terminals if needed. Take care.
    TheBeast and Tunrod like this.
  4. Jul 25, 2025 at 7:46 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Maybe it’s the grainyness of the picture. But is the hose dry rot? It also appears as if it’s been messed with, as it’s not in the position it’s supposed to be on the radiator tube.
    Petro likes this.
  5. Jul 25, 2025 at 10:29 AM
    Petro
    Petro New Member
    2019 Tundra SR5 TRD OR Crewmax
    If definitely looks uneven to my old eyes.
  6. Jul 26, 2025 at 4:42 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    It does look uneven. Open the clamp and reposition the hose, maybe replaced with a regular clamp..
    Petro[QUOTED] likes this.
  7. Jul 26, 2025 at 6:04 AM
    bflooks
    bflooks New Member
    Metrowest MA
    There's a lot of layers to that photo. Everything looks covered/caked in coolant, all the way over to the battery, so I'd assume they aren't lying to you. The visible leak at the bottom of hose supports the issue. You might want to try to reposition it, but as previously stated, new hoses and clamps are cheap and then you don't have to worry about it again. Seems like a good opportunity to just do maintenance on the entire system. Upper/lower hoses, clamps (if you wish), thermostat, new coolant, and don't look back.
    M14 EBR likes this.
  8. Jul 26, 2025 at 6:38 AM
    M14 EBR
    M14 EBR Oh No, Rex Kramer!
    This ^^ and I would also replace the radiator while I was at it... water pump, tensioners, drive belt etc... if they have not been serviced as they should have been.
  9. Jul 26, 2025 at 9:03 AM
    ebg338
    ebg338 New Member
    2016 Tundra 1794
    Had the exact same thing on my '16 with ~100k miles. Replaced the upper hose (Toyota OEM) and problem solved. I reused the original clamp. Been a few thousand miles with no issue.
    Atl626[OP] likes this.
  10. Jul 26, 2025 at 5:45 PM
    Diesel305
    Diesel305 New Member
    2017 tundra trd off road
    I had this just replaced my clamp along with my coolant today will keep u posted
