Help building and 04 tundra exhaust system please
Discussion in '1st Gen Tundras (2000-2006)' started by xXShadowTundraXx, Jul 22, 2025.
  1. Jul 22, 2025 at 9:50 PM
    xXShadowTundraXx
    xXShadowTundraXx [OP] New Member
    Hello, I am new to this stuff and I am trying to sort out my exhaust. I have an 04 tundra sr5, 4.7L access cab with the 6.5' bed and I recently had all the exhaust system fall off. the driver side flush with the rear of the Cat and the passenger side is showing signs of the same. I first noticed it when there was a aggressive rattling noise when I closed my door and realized the connector going to my driver cat on the y pipe fell off, as I was patching this the muffler and tailpipe fell off, as I fixed those the sweep from the driver cat fell off. At this point I am just looking into replacing the whole system front to back and I am hoping for some input.
    Headers-
    Flowtech Shorty Headers 91730FLT
    https://www.summitracing.com/parts/...nglhSw2L1VaeQOTQAzH--lMHp6h-BPbhoChGoQAvD_BwE
    Catalytics-
    MagnaFlow 2003-2005 Toyota Tundra HM Grade
    https://www.magnaflow.com/products/...-epa-compliant-direct-fit-catalytic-converter
    and
    Y pipe/resonator -(mine didn't/doesn't have a resonator so I am confuse)
    this is where I need help as I cannot find anything to go with the Magnaflow.
    Muffler- Currently have a Flowmaster super 40
    Tail pipe- I have the original but it looks like the welder was bling and couldn't figure out the voltage on his metal spaghetti machine.
    If you have any suggestions for a matching y-pipe or resonator combo idea I am all ears, I may have to go for a cheap option in the mean time but I appreciate anything, I plan to have this truck for a long time.
    Thank you for your input, any help is greatly appreciated.
  2. Jul 22, 2025 at 10:04 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I could've sworn magnaflow had a y pipe before. Maybe I'm thinking of a different brand. Either way, you can always take it to a muffler shop for a y pipe and resonator. Personally, I don't use a resonator on a chambered muffler (ie: flowmaster 40), only on a straight through style muffler. Resonator is to reduce drone. They are not required though. Totally up to your preference.
    The magnaflow cats are highly recommended here though. I wish I had bought them instead of cheap cats.
    bing5 and xXShadowTundraXx[OP] like this.
  3. Jul 22, 2025 at 10:13 PM
    bing5
    bing5 Long member
    New Mexico
    2004 Double Cab. 270k+
    Like she came out of the factory.
    Concur with above. Don't buy cheapo cats. I made that mistake and it lasted 18 months. It started throwing the dreaded P0420. Ponied up for a Toyota cat to replace it. Available, but painful....I suspect the Magnaflows are a reasonable compromise.
  4. Jul 22, 2025 at 10:21 PM
    xXShadowTundraXx
    455h0le_dachshund likes this.
  5. Jul 22, 2025 at 10:38 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    My mistake it's the JBA y pipe I was thinking about. You might be able to find a better price, but here a link to the first one I found. It's pricey by comparison, but the design should flow better. Might not be worth that price though.
    https://www.jegs.com/i/JBA/578/2011SY/10002/-1?year=2006&make=TOYOTA&model=TUNDRA&submodel=SR5&engine=V8+(+4.7L+/+285+)
  6. Jul 23, 2025 at 5:24 AM
    This is one thing that, if Keith @ DD designed and made, I would definitely pay to change on my truck.
  7. Jul 23, 2025 at 5:26 AM
    As long as you understand you're going to next to zero improvement in performance, so it's really not worth dropping extra coin into it ....
    I would focus on picking up a pair of compatible cats, and a cat-back kit. Magnaflow cats are reported to actually work w/our trucks without throwing codes (Walker and Summit are the other two brands that don't seem to be problematic), and there are a few companies making cat-back kits for our trucks.
  8. Jul 23, 2025 at 6:57 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    He makes an equal length x pipe. It's waaay cooler than a y pipe.
  9. Jul 23, 2025 at 7:14 AM
    I'd rather have the Y-pipe, X-pipes are notorious - across numerous vehicles, not just the 1st gen Tundra specifically - for causing murderous in-cab drone that will drive you insane.
  10. Jul 23, 2025 at 8:22 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I will tell you from my experience with Keith's dual race exhaust with the equal length x pipe, 16" mufflers w/ resonators, and long tubes, there is a break-in period. In that two months or so, the drone around 3k-5k rpm was deafening. Once it's broken-in though... Chef's kiss. I hated my DD race exhaust the first two months. Now I love it. Truck sounds like a race car at WOT and the drone is gone.
